Recap a MS-6540 with Poly?
  • fastvan67
    • Jan 2011
    • 12
    Hey Guys!
    I have an old MSI MS-6540. I have 4 capacitors busted. What I see on them are: 1500uf 16v, 105c H0427, HM(M) size is 10mm x 20mm
    All other capacitors look normal. Should I replace with the exact same type or should I go with Poly? If Poly, is preferred, is there a certain one to go with? What do they run price wise and where do I get it?
    Thanks!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Recap a MS-6540 with Poly?
    These old ones sound like Nichicon? If yes, that batch of caps are known to be problematic.
    You can use Rubycon MCZ sold here at badcaps.net (assuming the diameter and height fit).
    https://www.badcaps.net/store/produc...products_id=38
    --- begin sig file ---
    --- end sig file ---
    • fastvan67
      • Jan 2011
      • 12
      That was Quick! Is there a solid version of this or should I just leave it like it is? Its a High performance system even though its an old P4
      P4 Extreme 3.4ghz
      4gb RAM
      • Scenic
        o.O
        • Sep 2007
        • 2642
        16V caps? that's on the CPU VRM input side (basically directly after the 4pin 12V plug)
        no real benefit putting polys there. on the VRM output side though, those would be an upgrade (if it doesn't have polys or high-end lytics there already..)
        if you really want polys there..:
        https://www.badcaps.net/store/produc...products_id=78
        • fastvan67
          • Jan 2011
          • 12
          Ok, so the Rubycon that retiredcaps suggestion is what I'm gonna go with. Thank You much for your valuable Input!
          • retiredcaps
            • Apr 2010
            • 9271
            Here is the info regarding the Nichicon bad batch with its series and date codes.
            https://www.badcaps.net/forum/showth...=nichicon+2004
            • TheLaw
              • Jan 2011
              • 477
              You could do Rubycons, Nichicon HNs, HMs, Panasonic FMs (Maybe)...among others.
              I think that was a bad batch of Nichicons from back in the day. Doesn't really happen anymore. Nichicon is solid. My favorite cap brand.
              • fastvan67
                • Jan 2011
                • 12
                Thanks guys.. Already ordered a set of Rubycon.. wish me luck!
                • tazwegion
                  • Jun 2006
                  • 444
                  Originally posted by fastvan67
                  wish me luck!
                  Good luck!
                  One tip I'd like to mention is double check you've installed the capacitor is the correct polarity BEFORE soldering it in position
                  Viva LA Retro!
                  • CapLeaker
                    Poly VVX-250 VOIP POE problem not booting fix
                    by CapLeaker
                    I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
                    Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
                    11-25-2023, 10:46 AM
                    ASUS P5GC-MX motherboard recap
                    by momaka
                    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                    So here is what the motherboard looked like with its original caps:
                    CPU VRM area up close…...
                    01-27-2021, 11:59 PM
                    no-name Radeon 9600 XT recap and cooler
                    by momaka
                    I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                    This one was actually suggested to me by ChaosLegionnaire....
                    11-06-2020, 07:54 PM
                  • varunviolin007
                    Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                    by varunviolin007
                    Hi guys,
                    I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                    I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                    Looking for someone experienced with older PC boards who uses...
                    07-29-2025, 11:53 PM
                  • goodpsusearch
                    Got 4 LG L222WS 22" for free - psu recap
                    by goodpsusearch
                    Got 4 CCFL 16/10 monitors for free.
                    The resolution is almost Full HD (1680x1050)
                    VGA Input only is a bummer though.
                    Uses cheap TN panel with terrible viewing angles.
                    Even though this is not 17" 5:4 screen, still has very low resell value here. Can be found for 15-20 euros.
                    All the 4 monitors were not working and needed psu recap. Used mix of mediocre / junk caps to recap them, then donated 3 of them to friends/relatives and kept 1 for myself. Also like to install extra caps on empty spaces to help them last longer.
                    01-15-2022, 05:36 PM
