ECS G31T-M - First Motherboard repair
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: ECS G31T-M - First Motherboard repair
    what CPU and RAM did you use?
    the P3x and G3x chipsets don't support CPUs with 533MHz (133MHz) FSB (some Pentium 4's and most P4 based Celeron D's) and they also won't work with DDR2 RAM slower than DDR2-667 / PC2-5300.
    • Ritalin
      • Sep 2010
      • 194
      E6750 and 2 X DDR2-800
      • johnis82
        • Apr 2016
        • 22
        • Greece
        Did you solve it mate? I have the same motherboard but a little bit more complicated problem! when i plug the power supply and turn on it's switch the motherbord auto turn on, no power switch pressed and it does not boot or something! It had an intel q6600 quad on it and ddr2-800 kingstone when it was working! The caps looks fine i don't have a Capacitance meter is there a solution to this or some dirrection to troubleshoot this?
        • glovecaps
          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
          by glovecaps
          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
          11-25-2024, 04:23 PM
        • Docus
          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
          by Docus
          Hi everyone 😀,
          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
          1. I already own the exact same model, but its plastic chassis is badly damaged.
          06-10-2025, 04:24 PM
        • Archimedes
          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
          by Archimedes
          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
          Fans are spinning. Blindly could install windows11 and got the device manager...
          07-30-2024, 05:14 PM
          ASUS P5GC-MX motherboard recap
          by momaka
          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
          So here is what the motherboard looked like with its original caps:
          CPU VRM area up close…...
          01-27-2021, 11:59 PM
        • dragon3x
          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
          by dragon3x
          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
          power on.
          Here are some examples :
          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
          switching supply area).
          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
          than 6.3 V.)
          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
          I replaced capacitors with aluminum-polymer.
          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
          03-21-2025, 02:46 PM
