8800gts cap broke off :(
  • Supersteve
    • Feb 2011
    As you can see (Sorry about quality) 1 of the capacitors has come off. This happened the other day My monitor lost output signal so I restarted and it happened 2 more times so I thought something was up and took the card out and noticed the capacitor was not seated correctly and wobbly then it broke off in my hand lol. I hope it can be repaired as I'm too poor to replace and am having to rock a crappy old PCI only FX5200 which is utter balls. I was told on another forum I can just solder a couple bits of wire from the pads to the legs of the Capacitor as it's fine just decapitated. Would this really be able to repair my card?. I got a borrow of a solder kit but is missing the 40w Iron just has a 100w gun in it lol
    Edit I have read through 10 pages and you guys like to know what caps they are
    642
    SVP
    180
    16
    Is what the cap has written on it I heard these are good 1's?
  • POM_MJ
    • Aug 2009
    • 228
    Re: 8800gts cap broke off
    Those are good caps, Sanyo's Solid Polymer Capacitor SVP series.
    just solder back to the PCB.
    | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
    | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
    | 2xWD7500AYYS | 2xHD322GJ Raid0 |
    • Supersteve
      • Feb 2011
      I have never solderd anything before and cant find a video that shows how to put 1 of those SMD cap's back on. I saw a guide but to be host didn't understand it. If I can use 2 small bits of wire to put it back on it would be easier for me as my CMOS battery is vertical in my mobo and pretty much touches/rubs the cap wich I think is the reason the cap became loose in the first place. Thanks for reading by the way and the quick response
      • Ritalin
        • Sep 2010
        • 194
        Do you have the right equipment and some old boards? Just take an old board and take parts off and put them back on for practice, after about an hour you'll get the hang of it and can fix that video card w/o a problem.
        EDIT: BTW... take a can of air to your fan :P and maybe computer if you're GPU fan was that bad :P
        • steve2
          • Dec 2010
          • 121
          If you have a TV repair shop nearby, call and ask them if they will solder it back on.
          • Supersteve
            • Feb 2011
            I dont really have any other boards to play with I'm going to get a 40w iron tomorrow hopefuully, yeah the fan is pretty choc full of crap lol didn't think it was as bad until I opened the case to inspect my card
            • Supersteve
              • Feb 2011
              I have a PC shop but they couldnt do it for me and the nearest TV repair place is 30 mins away for me so Looks like im gonna have to do it myself
              • Pyr0Beast
                • Feb 2009
                • 406
                Your card is messed up.
                Just look at the fan. Dirty.
                If you would remove the heatsink you'd see heatsink completely clogged.
                GPU chip died most probably. You would need to reflow it.
                • corrize
                  Best way to solder LVDS connector for beginner (and qfn) ?
                  by corrize
                  Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                  I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                  I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                  See the test :
                  https://youtu.be/bNAzC-EvqHs?t=1767
                  With hot air from bellow the board, that's...
                  03-09-2023, 02:57 AM
                • petemanuk
                  BGA solder balls not connecting - help pls
                  by petemanuk
                  So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                  I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                  I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                  11-16-2022, 05:21 AM
                • myth77
                  UV solder mask - high temp resistent, recomendation?
                  by myth77
                  Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                  Is there any solder mask...
                  03-28-2022, 04:04 AM
                • acedogblast
                  by acedogblast
                  11-02-2024, 05:13 PM
                • sircastor
                  Solder not reflowing - what am I doing wrong?
                  by sircastor
                  I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                  For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                  03-03-2024, 02:44 AM
