Radeon X1650pro stops motherboard power up
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: Radeon X1650pro stops motherboard power up
    Originally posted by Pyr0Beast
    Check voltages on that rail to see if it works.
    The replacement 70T03H shows voltages on its S D & G pins, using a mounting hole on the motherboard as ground reference
    Rather than risk throwing good money after bad, I cannibalised a pair of IR F7413 (data sheet attached, if anyone's interested) from an artifacting 9800XT
    This pic shows them in place (what a fiddly job that was)
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Replaced the original electrolytics with recycled (dislike wasting new money on obsolete consumer cr*p) trio of Rubycon MCZ and a Nichicon HM with A0601 date code
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        Still no continuity beeps from the Molex pins, so on to the acid test
        The motherboard powers up, shows POST stuff on the screen, and freezes
        It's an old Socket370 CUV4X-C which won't detect IDE devices, so no great loss if it fried
        Time for the P4C800-E from another thread - it POSTs and boots into XP
        Now I need to get a driver - wasted time downloading Catalyst WDM 10.2 from ATI-AMD, looks like I need the 75.6 MB of bloatware - graphics makers have become too sophisticated for their own good, what happened to K.I.S.S. ?
        My thanks to everyone who made relevant posts - especially momaka, Pyr0Beast and Th3_uN1Qu3 for your ongoing patience
        • Agent24
          I see dead caps
          • Oct 2007
          • 5068
          • New Zealand
          #44
          The software is the reason why I don't like ATi cards. It's far too bloated AND it requires .Net framework. Also the drivers are usually pretty crap anyway.
          But if you want to forget about CCC, you can download a separate package which installs just the driver. You should still be able to configure resolution etc through Windows, but probably won't be able to change advanced 3D stuff etc.
          Anyway, Good job!!
          -David VanHorn
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            #45
            Don't see why all the bashing, you can always grab the Omega drivers and use ATi Tray Tools. ATi drivers have gone a long long way.
            nVidia's new control panel (well, it's been there for several years but for some it may be "new") also runs like crap and has like only half the stuff that you need, so just help yourself to some Omegas and enjoy.
            A working TV? How boring!
            • Agent24
              I see dead caps
              • Oct 2007
              • 5068
              • New Zealand
              #46
              I don't know about you but I have never managed to get Omega drivers to work well for me. That was a while ago, they might be better now.
              But it's just stupid things.. for example I tried to play Call of Duty (the first one) the other day, on an HD5770 - it wouldn't even run. Turned out I had to rename the executable to that of some other game so that it would actually work.
              Apparently it's been like that for quite some time now. I'm not saying nVidia wouldn't have those kinds of problems, it's just that they fix them. And Call of Duty isn't exactly some random game nobody has heard of, either.
              And yes, the new nVidia control panel is horrible, but at least it doesn't require .Net (which is what annoys me the most about CCC)
              -David VanHorn
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                #47
                I finished COD1 again on my 3870 last month, no problem. They will fix it. As for nV... the big 8000/9000 series fiasco, the renamed GT100s and 200s which are the same as the old cards, the driver update that killed several thousands of cards due to slowing down the fan instead of speeding it up, the powermizer DPC latency issues (crackly/stuttery audio) and that they've been behind ATi for the past 2 years yet their cards are still more expensive than the reds, well... sorry but no more nVidia for me.
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  #48
                  Ati = Quality
                  • Pyr0Beast
                    • Feb 2009
                    • 406
                    #49
                    Glad to hear it works.
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      #50
                      Nice job!
                      Wasn't bad money after all, was it ? Sure it took some time and effort, but you probably learned something from it too.
                      Anyways, good to see another item saved from the trash (extra points here for using recycled parts too ).
                      • pfrcom
                        Oldbie
                        • Jun 2006
                        • 1230
                        Certainly did - now I should be able to do some straightforward electronic troubleshooting on my own next time
                        Compared to buying something, plugging it in and having it work - how effete is that
                        ~ 3 hours to end of 2010 here - Happy New Year everyone
                          AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
                          The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
                          10-01-2024, 12:46 PM
                          AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
                          The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
                          10-01-2024, 01:07 PM
                          AMD Radeon RX 470 / RX 580 Schematic & Board View
                          The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
                          10-01-2024, 12:52 PM
                          AMD Radeon R7 340 / R7 430 Schematic & Board View
                          The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
                          10-01-2024, 12:36 PM
                        • glovecaps
                          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                          by glovecaps
                          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                          11-25-2024, 04:23 PM
