Radeon X1650pro stops motherboard power up
  • weirdlookinguy
    • Sep 2007
    • 1638
    Re: Radeon X1650pro stops motherboard power up
    That fan looks like a POS...
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      But it's now a re-lubricated POS, which seemed to work OK for the very brief times I've had the card powered on
      Pyr0Beast,
      I did look at Farnell - they said No Longer Manufactured for the Infineon part, and choose a substitute
      But their system didn't suggest anything, apart from the Infineon in different packaging, which was also not available
      That's why I eventually stumbled on the ST part, which is available from RSComponents
      I've lost the original SO8 mosfets - they fell through gaps in my workbench, and I didn't bother searching for them
      better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        Originally posted by Pyr0Beast
        Stick the card in the slot and start it up. If there is nothing (computer still halts), unsolder the other two mosfets on the other end of the card, near the choke, as well. Check if one is connected paralel on the bottom.
        With the MOSFETs near the Molex connector removed, it still won't start
        Just as before, there's a slight twitch from the CPU fan, and that's all there is
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          That means there's still a short and we (read: you ) gotta hunt it down.
          Basically, it all comes down to remove components until any short circuit between 5v/ground and/or 12v/ground disappears.
          Start with the easy components - D1, D3, D4. Then check for short circuit. If still present, continue with any other mosfets and voltage regulators on the card that measure continuity/0 resistance between output and ground or output and 5v/12v.
          Also, referring to the picture I attached below, check resistance between the pads circled in blue and the pads circled in green. What resistance do you get? Now check resistance between the cyan pads and the green pads. Again what resistance do you get?
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            Thanks for the colour coding - I can cope with that (still trying to work out what is the choke, mentioned by Pyr0Beast in post #19 - is it the component marked R68M ?)
            Resistance between the blue & green pads is 85.5 ohm
            And between the cyan & green pads is 87.9 ohm
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #26
              Yes.
              Good. That means nothing else is shorted down the line.
              Next, check for continuity again between the 5v pin and ground on the power connector. Also check for continuity between 12v and ground. If you're still getting a low reading on any of these, proceed to remove D1, D3, D4. Then check for continuity again at the power connector. If you still get a low continuity reading, remove the MOSFETs Pyr0Beast mentioned (one is on the front of the card, near the choke R68M, the other is in the back, right under the first one).
              Then, yet again, check for continuity at the power connector. Post a log of the results you get here.
              Once the short circuit between 5v and ground or 12v and ground is removed, the computer should hopefully start. After this, all you'll have to do is get replacements for the components you removed, and you may get a working video card.
              In the meantime, keep the old components (or try not to loose them ) - some of them, like the diodes, may still be good.
              • Pyr0Beast
                • Feb 2009
                • 406
                #27
                Yes.
                Remove both mosfets. One is on the upper side of the board. Otherone on the bottom.
                With mosfets removed and short still detected I would check tantalum capacitors on input.
                Also replace the PSU if they are shot - as seems voltage surge killed them.
                If they are in stock, no problem with that.
                • pfrcom
                  Oldbie
                  • Jun 2006
                  • 1230
                  Was still getting a continuity beep between 12v & ground, although removal of the first set of MOSFETs near the Molex connector had fixed between 5v & ground
                  Removed the diodes on the back, as per this pic, but no change
                  • Pyr0Beast
                    • Feb 2009
                    • 406
                    #29
                    Remove the small green electrolytic capacitor below white molex connector (if it is for 12V)
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      Removed one MOSFET on the back, as per this pic - was already suspicious of this one, because previous testing showed a continuity beep between the centre (ground?) and right legs
                      No more continuity beeps on the Molex connectors, so on to the acid test ...
                      ... and motherboard powers up with this card in its AGP slot
                      Now I'll need handholding for replacements of the diodes and the MOSFET(s) - am I correct in thinking the one still in situ should be replaced also, being a pair ?
                      Anyway, the diodes are marked with a W logo, and underneath that M72, and underneath that 383 or 3B3
                      The removed capacitor is marked D452 and BA627H
                      The capacitor still in situ, on the fan side of the card, is marked D472 and BA632G
                      • Pyr0Beast
                        • Feb 2009
                        • 406
                        #31
                        Seems ok now ?
                        I would then replace one rail by one. They both work independently.
                        First the SO8 mosfets.
                        • pfrcom
                          Oldbie
                          • Jun 2006
                          • 1230
                          I'm looking to buy all the replacements at one time, to minimise shipping charges
                          • Pyr0Beast
                            • Feb 2009
                            • 406
                            #33
                            Yes yes.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              #34
                              Nice. Next step, replacement parts .
                              Yes.
                              As a matter of fact, check the rest of the large MOSFETs as well (circled in blue, see attached images). That is, get their datasheets first, see which pins are Source and which are Drain, then measure resistance between Source and Drain. Those that show very low resistance (less than 20 Ohms) should be removed from the board and measured again. If they measure normal out of circuit, you can put them back on the card.
                              Check them for continuity with your multimeter. They should show continuity only in one way, but open circuit/infinity when the probes are reversed.
                              If they pass this test, you can put them back on the card.
                              Are these tantalum capacitors? Where were they located?
                              If they aren't shorted, I think you can put those back in as well (though it would be good if someone else could confirm that this is okay).
                              • pfrcom
                                Oldbie
                                • Jun 2006
                                • 1230
                                Sorry, Senior moment on my part, plus wife on my case to get off the bl.... computer
                                Should have read:
                                The removed MOSFET is marked D452 and BA627H
                                The MOSFET still in situ, on the fan side of the card, is marked D472 and BA632G
                                • pfrcom
                                  Oldbie
                                  • Jun 2006
                                  • 1230
                                  To me, the D452 and D472 MOSFETs appear functionally equivalent (datasheets attached)
                                  If that's correct, would 70T03H MOSFET(s) which I can cannibalise from a dead motherboard, also be OK ? (datasheet attached)
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    #37
                                    Yes the 70T03H should work.
                                    A working TV? How boring!
                                    • pfrcom
                                      Oldbie
                                      • Jun 2006
                                      • 1230
                                      The removed MOSFET marked D452 has been replaced, as per picture, by one marked 70T03H cannibalised from a dead motherboard
                                      I wasn't sure what normal should be for "measure normal", so I selected a 70T03H which gave a short beep for Continuity/Diode test between Drain & Source (which, in my limited experience, indicates a working MOSFET)
                                      Afterwards, no continuity beeps between 12v or 5v and ground pins on the card's Molex connector
                                      And a motherboard still powers up with the card in its AGP slot
                                      • pfrcom
                                        Oldbie
                                        • Jun 2006
                                        • 1230
                                        The three diodes passed this test, so they're back on the card, as per picture
                                        Again, no continuity beeps and motherboard powers up
                                        Now I have to buy some replacement SO8 MOSFETs and see what happens - those parts don't seem to be used on motherboards, and possible to cannibalise
                                        Pyr0Beast, I haven't disregarded your advice about replacing the electrolytics - it's on my list of things to do
                                        • Pyr0Beast
                                          • Feb 2009
                                          • 406
                                          #40
                                          Check voltages on that rail to see if it works.
                                            AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
                                            The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
                                            10-01-2024, 12:46 PM
                                            AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
                                            The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
                                            10-01-2024, 01:07 PM
                                            AMD Radeon RX 470 / RX 580 Schematic & Board View
                                            The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
                                            10-01-2024, 12:52 PM
                                            AMD Radeon R7 340 / R7 430 Schematic & Board View
                                            The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
                                            10-01-2024, 12:36 PM
                                          • glovecaps
                                            Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                            by glovecaps
                                            I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                            My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                            The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                            11-25-2024, 04:23 PM
