Dell lawsuit
  • MixMasta
    • Feb 2006
    • 142
    Dell lawsuit
    I guess my question is, are 2003-2005 the only years Dell sold computers with bad capacitors. My gut says no...
    http://www.dailytech.com/article.aspx?newsid=20214
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Dell lawsuit
    They may be the only years they were sold with bad formula... but even the new PCs are effected by poor ventilation cooking good caps to death. The problem is, you usually don't see it manifest itself until 2 years after the PC was purchased, whereas the caps with the bad formula were crapping out in the first year.
    Ludicrous gibs!
    • MixMasta
      • Feb 2006
      • 142
      Re: Dell lawsuit
      And what's the standard warranty on a new pc these days, about 1 year? Figures...
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Re: Dell lawsuit
        yeah its one year.
        standard full-size tower pcs are, in general, quite reliable. hp and dell and other oems do like the occasional crap cap or under-powered psu, along with not putting a fan in the back, but once those easy fixes are performed a standard tower pc will last a long time (if cleaned regularly, etc)...the only truly unreliable parts include hard drives and the over-stressed mediocre psus oems like to use.
        • c_hegge
          • Sep 2009
          • 5219
          Re: Dell lawsuit
          I still see new PCs (*cough* Compaq *cough*) using bad formula junk TK caps and even with good ventilationa and a case fan, they fail fairly early (2-3 yrs).
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Re: Dell lawsuit
            dont tell that to my pc, c_hegge...
            it uses pannies and kzg
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              Re: Dell lawsuit
              the industry wants us to treat them like dixie cups.
              the shop by price alone attitude does not help either.
              let em keep making boxes that die before folks are ready to replace them.good income!
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                Re: Dell lawsuit
                lol yeah if everyone started using Rubycons and designing stuff better nobody could ever have fun (or making a living off) of fixing stuff!
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • Akhlz001
                  by Akhlz001
                  09-20-2025, 07:15 PM
                • master3112
                  by master3112
                  07-29-2025, 01:55 PM
                  Dell Thunderbolt Firmware
                  by SMDFlea
                  Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                  Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                  The SKU is in brackets (****)
                  EDIT: NVM65...
                  01-26-2025, 06:22 AM
                • F R 2568
                  Dell Latitude 5420 does not start (no post) need help to find the reason why
                  by F R 2568
                  Hello all,
                  this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                  I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                  If the laptop is only connected to the AC adapter (battery removed):
                  When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                  The power/battery...
                  01-08-2025, 05:45 AM
