MSI K7T266 Pro2 Ver: 2.0
  • johnse
    • Dec 2005
    • 9
    I have an MSI K7T266 Pro2 Ver: 2.0.
    A couple of months ago, the power supply died on this system. At that time I noticed that fully half of the caps on this board were either swollen or vented. When I asked at the shop where I got the new PS, they said that event though the board still POSTed on a good PS, it would probably destroy the new PS within a few weeks.
    I replaced both the PS and MB (A Foxconn they had on clearance), reusing all the other components. The system has been running rock-steady since then.
    This system had been running for nearly three years, but I'd had stability problems for at least two of those. It had a tendency to freeze when I would plug in USB devices to the front-panel USB 2.0 connectors.
    13 of 24 capacitors appear to have failed--bulging and/or vented. These caps are all either Tayeh (Wikipedia lists this as a company that doesn't appear to exist) or Lelon. The Lelons are 1000uF 6.3v 8mm cans and all appear to have failed, many venting. The Tayeh's are 1500uF 6.3v 10mm cans and appear to have bulged slightly.
    The others that don't appear to have failed are 10mm cans either 1500uF 16v or 2200uF 6.3v. Their brand name may be KZG. They are dark brown with grey stripes and lettering.
    If I recap, I would replace all of them, even those that appear to have not failed.
    My main questions are:
    1) Is it likely that the bad caps were the cause of the power supply dying?
    2) Is it likely the freezes when plugging in USB devices were due to the bad caps? There are two of the 1000uF caps right at the USB 2.0 headers, both vented.
    3) If I recap, is it likely this MB will be stable? I'm thinking of upgrading an old (PII) system with a new PS and this MB, but would need to add a new CPU and RAM as well.
  • Rainbow
    • Aug 2005
    • 1375
    Re: MSI K7T266 Pro2 Ver: 2.0
    1) No, the PSU probably died by itself
    2) Yes.
    3) Yes.
    KZG is a series of caps made by United Chemi-Con, they should be good. Tayeh and Lelon is crap.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      they were kinda setting you up for a rma refused on the psu......
      1) occasionally it does happen to get other problems along with badcaps. like the psu or perhaps the ram failing. unrelated except for the time that has passed since it was all turned on.
      2) i am with my friend Rainbow on that one also. badcaps can anyway cause wierd problems in software, crashes corruption. best to recap and then start troubleshooting otherwise end up lost and nowhere.
      3) as the board did not die and fail to post it is an excellent candidate for recapping with chance of success depending only on your technique. as long as you use the correct caps it will be perfectly stable and last until nobody wants it.
      forget the wikipedia article. after it was created by our bushytails and developed further by him, it has been edited considerably by others and i dont agree with some of the edits they did, which i guess is why he abandoned it.
      we look forward to helping you to a successful recap.
      • johnse
        • Dec 2005
        • 9
        Thank you both for your comments.
        I put in a request for pricing on the replacement caps. If the KZG caps don't need to be replaced, then I'd only be looking to replace 10 1000uF 6.3v 8mm and 3 1500uF 6.3v 10mm caps.
        I'll take the board home (It's at the office at the moment) and take some good pictures of the failed caps and upload them for you.
        One other question... Your removal instructions said not to use the mechanical solder-suckers. I'm assuming by that you mean the spring-operated, vacuum-type? Why are they likely to damage the board?
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          actually they do a very nice job but there is the problem of recoil against the board damaging a trace or too much suction sucking out the lead port.
          • Rainbow
            • Aug 2005
            • 1375
            I use a cheap plastic mechanical solder sucker with spring. It worked until it broke into two pieces Then I glued it back together and it still works. You have to be careful not to bend the board too much by hitting it with the sucker when it recoils. My instructions:
            1. put the board in a small vise - take a paper, fold it several times and wrap around the bottom edge of the board so it covers the last slot from both the front and back of the board (to avoid damage) and squeeze in the vise by that last slot
            2. remove the bad caps
            3. clean the holes - heat with the soldering iron from one side (add solder if needed), put solder sucker on the other side and fire it - you need to be careful HERE - the soldering iron should support the board enough so the recoil can't bend the board. You also need to be fast as holes can be damaged by too much heat (some boards have more delicate holes than other).
            4. put in new caps, solder them on and cut the leads
            That's it:
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              TC will kill us for talking about desoldering pumps lol.
              • johnse
                • Dec 2005
                • 9
                OK... I don't have to go get a more expensive one... I've got that kind already
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  maybe mistake it for that other pump?
                  • johnse
                    • Dec 2005
                    • 9
                    Here's a set of pictures I took of the board. It shows pretty well both the good and bad caps. The good ones are a little crooked because I was pushing them a bit to read the values...
                    • johnse
                      • Dec 2005
                      • 9
                      Whole board with notes showing the different caps
                      Whole board without the notes
                      Good caps on the right, bad on the left
                      Green caps are bad. The 10mm at the very right is just starting to bulge around the scoring at the top.
                      Two by USB headers
                      Another Lelon 8mm and another view of the 10mm Tayeh with the bulging top
                      Another 8mm 1000uF
                      Two Lelon 1000uF 8mm and Two Tayah 1500uF 10mm. Again, the Tayehs
                      are beginning to bulge on top but haven't vented.
                      Another shot showing the good (Brown) KZG caps and the Lelon (green) caps. Note that I'd scraped away some of the leakage on the of the ones between the AGP and PCI slots.
                      • PeteS in CA
                        • Aug 2005
                        • 3581
                        • USA, Unsure of Planet
                        "KZG" is a United Chemicon series, and the shield is UCC's logo.
                        Definitely. The bulging/vented crapacitors are high ESR. When you plug in the USB device, it draws a surge of current, which the crapacitors cannot supply without allowing the voltage to go out of reguation (the regulator cannot respond instantly).
                        PeteS in CA
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          change all but the kzg's
                          even the ones that arent bulging as they soon will.
                          i see a bunch of these boards and they all pass burn in after a recap.
                          even ones that didnt post when i got them.
                          • Tormi2k
                            K7T266 Pro2 (MSI MS-6380), damaged caps!
                            by Tormi2k
                            Hi Guys!
                            For my retro machine I was looking for a mainboard with 3.3V AGP support. Luckily I found several being one a K7T266 Pro2 from MSI. The board runs fine, but after a brief visual inspection I could find physically damaged caps around the socket area. My guess is that during the installation of the CPU cooler they got damaged. To be on the save side I want to replace them.
                            My main concern are the five RUBYCON MBZ 2200uf, 6.3V. But if I start the process I am also looking on the other ones around the socket area.
                            In total there are
                            8x...
                            10-16-2020, 05:18 AM
                          • ssl6
                            MSI K7T266 Pro (Ver. 1.0)
                            by ssl6
                            Hey Everyone,
                            Long time lurker, but I think this is my first time posting.
                            Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
                            I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
                            11-09-2023, 01:00 PM
                          • Acerman123
                            MSI K7T Pro2 Ver1 - capacitors have higher values?
                            by Acerman123
                            Trying to fix this board, MSI K7T Pro2.
                            All Tayeh capacitors showed either as damaged or with uf values which were faf from what they should be so I have replaced them and all other capacitors except those big ones near CPU.
                            The motherboard powers on but doesn't post. My PCI bios code reader will most of the time dsplay some some kind of code if there has been no power to board for a while but I don't think those codes mean anything in this situation. If I power off the board and try powering it on the second time the code reader usually doesn't show anythin. Unplug...
                            08-12-2023, 10:00 AM
                          • notallbad
                            Indesit vented tumble dryer control board dead
                            by notallbad
                            Anyone able to help diagnose the fault with this board please.
                            Hopefully photos are clear enough to give me direction on what readings to take and where.
                            All ancillary components of the dryer have been tested and work i.e heating element, thermostats, sensors, motor, door switch, wiring harness.
                            So theres 230v at the control board but no life whatsoever with or without the ancillaries connected.
                            The on/off/timer dial contacts are clean and make good contact. All the through hole mounted components appear to be good i.e diodes, resistors,...
                            01-04-2023, 05:49 AM
                          • Thabto
                            Pascal S-Pro2 amplifier module
                            by Thabto
                            Hi
                            I was using this module in a Professional Audio Subwoofer. One day it blew and certain small components were burnt such that they cannot be identified by their part numbers. I am a certified Electronics Technician and would like to have the chance to repair my module, if you have a part list for this module, that would be great. I need to know the values of the following components:
                            TRANSISTORS
                            T503, T506, T509, T511
                            DIODES
                            D502, D504, D506, D508, D520, D522
                            IC'S
                            IC501, IC505
                            RESISTORS
                            R500,...
                            05-30-2022, 12:20 AM
