Hey Everyone,
Long time lurker, but I think this is my first time posting.
Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've done lots of recapping but typically have been able to find suitable replacements in existing posts here where someone has already posted a list of part numbers. In the case of these most of the posts for this specific v1.0 board I've found are old and just went to RMA because at the time manufacturers were replacing boards due to the plague
Anyhow, may as well start with an inventory of all capacitors on these boards and list what I have on hand that might be a good replacement if anyone can help confirm?
5x 12mm diameter 6.3v 4700uF KZE (chemi-con caps I think?) - none of these appear bulging so not sure I should change them unless they're known to have some issue over time
I have available already, but only 3300uF
nichicon hm(m) 6.3v 3300uF
nichicon hd(m) 6.3v 3300uF
9x - 8mm diameter 6.3v 1000uF chhsi/tayeh - these are the ones that are bulging on one of the boards. one board has chhsi caps, the other has tayeh. I know these are some of the known no-name caps that were problematic and definitely should be replaced, just need a replacement part #
I have some chemi-con KY caps matching this voltage and capacitance in my stock. Also some Rubicon YXS
5x 10mm diameter 6.3v 1500uF tayeh caps - these appear to be okay, but probably should be replaced I assume simply because tayeh, so just need to identify a replacement part #
3x 6mm diameter 10v 470uF chhsi - probably should replace but need part #
4x Sanyo OS-CON 510 / 4 - these appear fine. found another thread on here that suggested these as a replacement though
https://www.digikey.ca/en/products/d...PC560M/4204187
I thought I had more options in stock for some, but seems regardless I'll need to order from digikey or elsewhere if I'm to replace everything. Any hlp appreciated. I'm also not opposed to polymodding it, although some may argue it's not worth the cost but I like tinkering and I've been on a retro hardware binge and having fun with some of the stuff I've had hoarded away for years and will probably keep for many more years
 for sure.
