I have a MS-6156 mobo from about mid 1999, and the whole board is covered in them, but they all look fine. Should I replace them or leave them be? The reason why I ask is I'm replacing a load of chhsi caps on a few later msi mobos from a 2000-01 which are bulging and was wondering if it is worthwhile changing the ones of this board or not.
Was there a good Chhsi capacitor era, or are they all rubbish?
Tags: None
Re: Was there a good Chhsi capacitor era, or are they all rubbish?
Recently I replaced three Chhsi 560uF 25V, WG(M), -40 +105 'C, 9846 (46th week of 1998) on an IBM PC 300PL Slot 1 motherboard. Visually they were fine but I replaced them because I've seen multiple pictures of them failed on someone else's PCs, however in all those pictures they were dated 9936 instead. It didn't solve any problems for me, so they were not bad caps. I haven't tested them in any way after removing them, though. If your mobo works fine, I would refrain for now.Last edited by ribcage; 10-05-2021, 01:11 AM.
by MORETTIGIANTitle:
Description:
Procedure performed:
- Removed backplate
- Reapplied thermal compound
- Reassembled card
- GPU powers on and operates normally under...11 Photos -
by cookAre there good brands for 'run capacitors' or 'start capacitors' that are used on electric motors or heat pump compressors? ... r are the good capacitor brands for electronics (power supplies, laptops, motherboards, etc.) also the good brands for run capacitors?
Yeah I know this might be a novice question, but I just wanted to be sure. I did do a search on the forum but did not see this question asked before.
Thanks-
by devsignerHi
While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
resistance tests show a rising resistance value, indicating a capacitor.
The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...5 Photos -
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by chth96I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
I know that these capacitor will not last as long as nichicon capacitor...-
- Loading...
