Super socket 7 Cache unstable? MSI MS5169
  • jhead22
    • Jul 2011
    • 8
    A while ago I was able to save a super socket 7 board from the landfill. It is a MSI MS5169 ver 2.1 with an Alladin V chipset. There is 512KB L2 cache onboard and the board has Chhsi caps. I tested the board with different AMD K6-2 processors and different PC133 memory modules. The board is equipped with the latest BIOS version.
    The board is completely stable on 66FBS with the cache enabled. At 100fsb the board is only stable with the cache memory disabled. No memory errors. With the cache enabled at 100fsb I get errors in Memtest 86+ 4.xx and 5.xx
    I therefore replaced most of the capacitors with new low ESR capacitors. The old capacitors don't measure very bad. Sometimes they have a slightly too high capacity, but they were not very bad.
    Also with the new capacitors I get memory errors in Memtest86+ when the cache is enabled and running at 100FSB. Changing CPU, memory module or memory bank does not help. Disable the cache does help. With the cache disabled i got 0 errors.
    I'm now starting to think that the cache chips on the board are no longer good. The chips are: Winbond W25P222AF-4A chips. Does it happen more often that these chips fail? Was this board originally stable at 100fsb with cache enabled? Does anyone know where I can buy these chips? (Preferably in Europe or China)
    Are there any other tips I can Try?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Super socket 7 Cache unstable? MSI MS5169
    Try changing the cache timing from 1T to 2T if the board allows it.
    • jhead22
      • Jul 2011
      • 8
      Unfortunately, there is no option in the BIOS to adjust the cache latency.
      But I think I found the solution. I downgraded the bios from version 3.1 to version 2.3. And so far I don't get any errors in memtest with the cache enabled. It seems that BIOS version 3.1 is not stable and version 2.3 is stable.
      • jhead22
        • Jul 2011
        • 8
        Mmm with this old bios I run into another problem. My AMD K6-2 500Mhz is seen by the bios as a 350Mhz processor. Windows 98SE is very unstable when I have it set to 500Mhz. It seems stable at 350Mhz. I'm afraid this bios version supports a maximum of 350Mhz....
        I think I need to modify the latest bios and I hope that I can add the cache latency setting.
        • jhead22
          • Jul 2011
          • 8
          I found Bios V3.3 for mainbord v2.1. Let's try that.
          https://theretroweb.com/motherboards...-al9#downloads
          • jhead22
            • Jul 2011
            • 8
            With bios V3.3 I can no longer start memtest 86+. Win XP starts, but futumark crashes immediately.
            When I read the notes of V3.3, I read the following:
            MS-5169 A569MS33 BIOS Release
            1. This is the AMI(r) BIOS ver 3.3 release.
            2. This is only for PCB version 2.1, 3.0 and 4.0
            3. The BIOS fixes the ff. problems of the previous version:
            - Fixed Windows98 SE Standby problem
            - Support AMD(R) K6-2 500Mhz
            - AMD(R) K6-III 450Mhz, AMD(R) K6-III 500Mhz
            ** Please refer to FLASH.DOC for programming notes.
            2.7 indicates the following:
            BIOS MS-5169
            Version: 2.7
            Manufacturers
            MSI
            FileName
            a5169v27.exe (381.0 KB)
            Additional Notes
            Support AMD(R) K6-3 CPU. Support AMD(R) K6-2 450 CPU.
            Support Cyrix(R) MII CPU.
            Special note:1.This is only for PCB version 2.1 and 3.0
            2.PCB version 2.1 can only support up to K6-2 400MHz.
            Set my AMD k6-2 500 to 400Mhz did not help. Maybe bios 2.7 with 400Mhz is stable and maybe it is the max this board can do?
            • jhead22
              • Jul 2011
              • 8
              Update, with bios v2.7 and a K6-2 400 the board is quite stable. Until I want to start a graphics benchmark, the PC crashes. (3dmark 2000 and others)
              I have now replaced all the capacitors. The board is now more stable. I can start a graphics benchmark (3dmark 2000) and it goes a long way. But it is not completely stable. Unfortunately, a different PSU does not help either.
              I'm not sure what to do now. Should i take a oscilloscoop? What are the points to mesure?
              PS: With Bios 3.3: IDE controller 2 is not working. on a MSI-5169 rev 2.1
              • jhead22
                • Jul 2011
                • 8
                Messurements:
                VCCS3 (I/O) = 3.4V
                VCCS2 (core) = 2,2V
                VSS = 0V
                • Destroyer-Br
                  [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                  by Destroyer-Br
                  I'm working on an Acer Nitro 5 unit with the following specs:
                  • Motherboard: LA-J871P Rev: 1B
                  • Model: Acer AN515-55-59MT
                  • S/N: NHQ7JAL00403906A973400
                  • SNID: 03902728734
                  Initial Issue
                  The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                  After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                  04-17-2025, 08:18 PM
                • hinisa
                  Xiaomi router freezes at boot after re-capping
                  by hinisa
                  I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                  When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                  After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                  Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                  07-08-2023, 05:58 AM
                • reformatt
                  Intel iMacs, 3rd party SSD failures and Fusion setups
                  by reformatt
                  I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                  As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                  So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                  12-18-2024, 10:34 PM
                • ongobongo
                  Asus ROG Ally - Super IO Chip replacement
                  by ongobongo
                  anyone here who has experience with replacing the super IO chip of an ROG ally?
                  I have one on my bench which has a burnt super io (ITE 5125VG-192). On some devices the super-io downloads it's firmware from BIOS if it's empty. As i don't have a programmer for this chips i hope someone here has already changed the chip and can give me a hint if it's working with an empty chip if it needs external programming.
                  Ongo
                  11-17-2024, 11:27 AM
                • Mr.Ultimate
                  Dell Precision 5540 - Absolute / Computrace permanently enabled. Need bios fix to disable
                  by Mr.Ultimate
                  Hi, I have Dell precision 5540 laptop from old workplace,decommissioned old stock. its a good spec laptop i9-9880H etc, so I decided to keep it and use it for personal purposes.
                  I was checking bios settings and I found that Absolute (Computrace) is permanently enabled/activated, and field is grayed out, unable to change it to disabled/deactivated state. The laptop status is clean, absolute has no any warnings or messages booting pre-bios pre-OS or post booting, while using laptop, im just not feeling safe having absolute permanently enabled having backdoor on a bios level enabled to my...
                  08-06-2024, 05:24 AM
