Chuwi HeroBox blown components
  • VitalComputing
    • Dec 2021
    • 29
    • Ireland
    I have a Chuwi HerBox that has a number of blown components that I am having difficulty identifying. No schematic available.
    The fault is that the HDMI port does not really function properly, video looks shaky and has lines. The box boots fine on VGA, so I think the problem is isolated to the HDMI.
    The section below is the only section that seems to have damage to three components.
    1. Blue Arrow = I think this was a capacitor (as it is connected to ground) that blew clean off the board.
    2. White Arrow = I think this is an inductor as it is inline, but is not giving any value with multimeter.
    3. Red Arrow = I think this is a fuse, but again is not giving any value with the multimeter.
    This is what it looked like before I cleaned off the board with alcohol.
  • u666sa
    • Jan 2014
    • 70
    • Russia
    Re: Chuwi HeroBox blown components
    What's on the other side? Or more preceisely -- where does the burned stuff going to?
    • VitalComputing
      • Dec 2021
      • 29
      • Ireland
      Here is both sides of the board.
      On the image below, I've marked out the two ports in that area, and with the yellow line marked the path that the input voltage appears to take, across the missing capacitor (I presume), through a small inductor, and through a fuse. I've marked the known grounds on the board also.
      • u666sa
        • Jan 2014
        • 70
        • Russia
        Well here is my plan, doesn't mean it is correct, but this is what I would do.
        This chip
        GST5009
        LF
        2146G
        We need to find schematics from some other device where this chip is used. Caps and resistors and other things that goes with this chip will be the same. Then we figure out what is blown and this way we would know the values.
        For example: I'm not saying this example might give positive results. But ASUS n61vg uses this chip. Here is the boardview for it. If this does not give positive results, find some other schematic with this chip.
        How you know where to look on schematic? You gotta see to which leg or which pin on the network connector the burned stuff goes to.
        • piernov
          • Jan 2016
          • 4437
          • France
          Please attach pictures to your post directly (no link to external host) and post schematics/boardviews in the Schematics subsection.
          This is for Ethernet, unrelated to HDMI, this damage is probably the result of a lightning strike.
          The GST5009 "chip" is the Ethernet transformer, they are all made in a similar fashion.
          If HDMI port looks good, cable is good and it does the same on multiple monitors, the lightning strike may have traveled through HDMI too and damaged some stuff there such as TVS diodes, filters or the HDMI output of the SoC.
          • cmlewis89
            LG 47LB5DF blown power supply board
            by cmlewis89
            Hi folks,
            I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
            09-03-2024, 07:50 PM
            by momaka
            03-12-2025, 03:42 PM
          • drscoot
            HP X360 convertible battery blown fuse error, not charging
            by drscoot
            HP Modelnumber: 14-dh0061nb​
            This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
            The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
            I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
            And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
            All these 3 batteries are charging...
            12-15-2023, 05:54 AM
          • MrzPdlch
            Blown fuses on Gigabyte GTX 980TI 6GB
            by MrzPdlch
            Hey everyone,
            I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
            Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
            Find some pictures of the actual GPU together with a picture of how it should look like.
            I also wonder whther it might be a problem that there...
            03-10-2024, 04:14 PM
          • cheeky2
            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
            by cheeky2
            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
            06-15-2025, 05:12 AM
