Chuwi HeroBox blown components
  • VitalComputing
    • Dec 2021
    • 29
    • Ireland
    I have a Chuwi HerBox that has a number of blown components that I am having difficulty identifying. No schematic available.
    The fault is that the HDMI port does not really function properly, video looks shaky and has lines. The box boots fine on VGA, so I think the problem is isolated to the HDMI.
    The section below is the only section that seems to have damage to three components.
    1. Blue Arrow = I think this was a capacitor (as it is connected to ground) that blew clean off the board.
    2. White Arrow = I think this is an inductor as it is inline, but is not giving any value with multimeter.
    3. Red Arrow = I think this is a fuse, but again is not giving any value with the multimeter.
    This is what it looked like before I cleaned off the board with alcohol.
  • u666sa
    • Jan 2014
    • 87
    Re: Chuwi HeroBox blown components
    What's on the other side? Or more preceisely -- where does the burned stuff going to?
    • VitalComputing
      • Dec 2021
      • 29
      • Ireland
      Here is both sides of the board.
      On the image below, I've marked out the two ports in that area, and with the yellow line marked the path that the input voltage appears to take, across the missing capacitor (I presume), through a small inductor, and through a fuse. I've marked the known grounds on the board also.
      • u666sa
        • Jan 2014
        • 87
        Well here is my plan, doesn't mean it is correct, but this is what I would do.
        This chip
        GST5009
        LF
        2146G
        We need to find schematics from some other device where this chip is used. Caps and resistors and other things that goes with this chip will be the same. Then we figure out what is blown and this way we would know the values.
        For example: I'm not saying this example might give positive results. But ASUS n61vg uses this chip. Here is the boardview for it. If this does not give positive results, find some other schematic with this chip.
        How you know where to look on schematic? You gotta see to which leg or which pin on the network connector the burned stuff goes to.
        • piernov
          • Jan 2016
          • 4439
          • France
          Please attach pictures to your post directly (no link to external host) and post schematics/boardviews in the Schematics subsection.
          This is for Ethernet, unrelated to HDMI, this damage is probably the result of a lightning strike.
          The GST5009 "chip" is the Ethernet transformer, they are all made in a similar fashion.
          If HDMI port looks good, cable is good and it does the same on multiple monitors, the lightning strike may have traveled through HDMI too and damaged some stuff there such as TVS diodes, filters or the HDMI output of the SoC.
          • cheeky2
            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
            by cheeky2
            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
            06-15-2025, 05:12 AM
          • Sam Scarbo
            Sparkle 1200W PSU MAGNA Model: SPM1200AXJ8 - Broken. Need help identifying components. Any schematics available?
            by Sam Scarbo
            My Sparkle (SPI) PC power supply has broken. Originally, there was totally no power output. The 5V-standby was not there. I have replaced a few bulged capacitors but not helping.
            I was trying to do more troubleshooting but burned more components. Some got burned so badly that the markings were gone. And also, the markings of a few transistors were gone because the component surface was worn out somehow.
            If you happened to have disassembled the same PSU model, please help to provide the markings of some of these components.
            See the attached two pictures of the small...
            09-18-2024, 08:29 AM
          • Kyleadonis
            LiteON PA-2911-1-LF Blown Components
            by Kyleadonis
            I opened up a Cisco network switch that no longer powers on and the power supply has three blown components:
            (See Photos Attached)
            -Power switch IC
            -Optocoupler
            -Resistor
            There are no blown fuses, mosfets, diodes. I know its impossible to ask what could cause this without physically looking at the board but does anybody know
            what could have caused these components to blow?
            Also finding a replacement power IC seems to be a bit of a mission as the top blew off and I cannot see the model of the IC. Can anyone help?...
            10-04-2021, 04:15 AM
          • User2025
            Please help to identify the components on Surface Laptop GO3, model 2013, i5-1230U
            by User2025
            I am working on a Surface Laptop GO 3, which is the new release 2024 with a i5-1230U processor. Originally, it had a 256GB SSD, then the owner attempted to upgrade it to 1TB SSD by himself. "Surprisingly", it did not boot afterwards, then changed back to the original SSD, did not boot either.
            It turned out to be that just a couple of components had been knocked off when the owner was trying to get off the SSD cover with his beloved screw driver.
            I do not have another board of same model. Although I have a Laptop Go 2, the layout of that bit...
            04-29-2025, 04:13 PM
          • bastyani
            Apple 85W MagSafe Power Adapter - blown - help with components
            by bastyani
            Hi, I have an 85W MagSafe Power Adapter, Model No: A1343, worked ok,
            then suddenly dead. Opened it up and there are a few components blown.
            Two resistors and a chip.
            You can see more on the attached pictures.
            Unfortunately I can only read the few last characters on the chip - an N on the top and 3261 or 5261 on the bottom (can't rally tell, the character is halfway visible but most probably is a 5261). The chip is blown right on the position where the model/type is printed. The resistors are also hard to tell.
            Can anyone of you experts...
            04-09-2021, 03:30 AM
