GX520 same board as GX620?
  • torpex505
    • Sep 2010
    • 41
    I have a Dell GX520 USFF that I want to re-cap. Can I just buy the GX620 USFF kit? I could not find any information on the Boards used. I can post the boards model# tonight if that might help.
    Thanks,
    Eric
    • 31087
    Re: GX520 same board as GX620?
    make a list of the caps in it or post a foto.
    • torpex505
      • Sep 2010
      • 41
      I took a close look, and can't seem to find any caps that are bulging or leaking... This may not be a cap issue after all. I tested the PS, but it tests good. The thing just shuts down randomly. Sometimes it will stay on for hours, even days. But other times it won't even make it to the Windows logon screen before shutting down.
      Here is the best pic i could get. Could it still be a cap issue?
      BTW, It looks like they were all Rubycon caps with exception from 6 caps located near the socket and 1 next to dimm2...
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        GX620's will blow the little 4&5 mm caps which don't always bloat.
        Presumably the GX520 will too.
        https://www.badcaps.net/forum/showthread.php?t=6055
        Mann-Made Global Warming.
        - Dr Seuss
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          How did you test the power supply?
          Does the computer really shut down or does it restart (big difference here)?
          • torpex505
            • Sep 2010
            • 41
            I tested using a nifty little powersupply tester that I got on eBay a while back. It does not provide actual voltage, but rather a red or green led that's based on wether it's getting the voltage that it's supposed to get per wire. I probably should go in with a multimeter to verify. It shuts down and flashes an amber light on the power button. It does not restart.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              The problem with those is that they don't put enough load on the PSU to tell you if the PSU is good in a real world application.
              They will tell you if a PSU is stone dead...
              But they won't tell you if a PSU will run a system.
              It's not -> go/no go
              It's -> no go/maybe
              - Dr Seuss
              • torpex505
                • Sep 2010
                • 41
                What would be the best way to test then? Should I just boot the computer and test the wires one by one with a multimeter?
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Check the voltages with a multimeter while the system is doing something beyond just being idle.
                  It's either that or scare up a slew of test loads.
                  - Dr Seuss
                  • seanc
                    • Nov 2008
                    • 1319
                    You have a desktop or small form factor GX520, the GX620 that like to bake caps are usually ultra small form factor - very different systems.
                    Is your cooling fan working correctly? Is the heatsink seated correctly?
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      Or try a different power supply altogether and see if the problem disappears. The power supply needs to be rated for at least 14A on the 12v rail, though.
                      Also check the caps in the original power supply.
                      • torpex505
                        • Sep 2010
                        • 41
                        I'll try with a different PS to see. And check caps in original PS as well.
                        • brethin
                          • Dec 2008
                          • 1907
                          Thanks,
                          Eric
                          Short answer is no, they are not the same.
                          • torpex505
                            • Sep 2010
                            • 41
                            Sorry I've been inactive for a bit. Ok, so it's a GX520 SFF, not USFF... But yeah, deffinatly not teh same board.
                            What program should I run to runup the load to test the PS? Would a Dell diagnostics or memtest scan be suffecient? or is there another program that will give me the load that I would need to get a good test?
                            Thanks for the help,
                            Eric
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              Prime95 for cpu and furmark on the graphics while playing a dvd and doing a drive error check using hdtune. Thatll stress it out as much aa possiblr
