Gigabyte GA-7ZXE, GA-7VAXP
  • Mark19960
    • Nov 2005
    • 5
    Im new to the forum, and I have some images of some boards that
    recently decided to act up..
    This board was in th wife's computer. she told me the other day that it started to act funny, rebooting or freezing.
    So, I cracked it open and behold, one cap vented from the bottom and the others the top.
    When I go to work in the morning I will toss some caps on it.
    To make matters worse, after I yanked this board out I was working on one of my machines when it rebooted during an installation of Visual Studio 2005
    When the system came back up, it had a 'your sytem has recovered from a serious error' dialog.
    So, I crack that machine open and low and behold... bad caps.
    When you look at the images you may notice one thing:
    they are the SAME CAPS. the values are the same, and so is the manufacturer, 'choyo'.
    These are 3300uf/6.3 volt 105c rated caps (well, not anymore )
    What are the chances that 2 machines within hours of one another, failing?
    I am a firm believer in Murphy's law
  • linuxguru
    • Apr 2005
    • 1564
    Re: Gigabyte GA-7ZXE, GA-7VAXP
    Not only did they use lousy Choyos, they also skimped by omitting about half the caps on the GA-7ZXE. I'd suggest using 1500/6.3 or 2200/6.3, and populate all the empty locations as well when you recap it.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      nice clogged hsf in that second pic.and the dust packed around the ram can cause trouble esp with high humidity.
      • Chris1992
        • Apr 2005
        • 561
        Murphy strikes again. When you recap the 7vaxp, clean the dust out of the HSF (both CPU and NB) and RAM sockets.
        The great capacitor showdown!
        • Mark19960
          • Nov 2005
          • 5
          Yeah, the fans are dirty.
          I have removed the motherboard and replaced the fans already, replaced the caps with some Nichicons we have here in the shop.
          It should last awhile longer.
          I just wonder which of my other machines will fail next.
          • Newbie2
            • Sep 2005
            • 885
            Mark19960, did you use low-ESR Nichicon caps? General Purpose caps aren't recommended at all. But, at least your systems are now working with caps they should have had in the first place.
            My gaming PC:
            AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
            ASUS M4A77TD AMD 770 AM3 Motherboard
            PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
            G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
            TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
            WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
            ASUS Xonar DG 5.1 Channel PCI sound card
            Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
            Antec Three Hundred Mid-Tower Case
            Microsoft Windows 10 Pro 64-bit
            Microsoft Windows 7 Ultimate SP1 64-bit
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              i see lots of those nb fans dead on boards that are sent in for recapping.
              gigabyte should have spent the money on a quality fan rather than chintzy gold plating and stupid stickers!
              • Rainbow
                • Aug 2005
                • 1375
                These small fans found on chipsets and graphics cards are generally crap. The most funny thing was a maybe one year old fan with bad bearing (noisy) - with flashing color LEDs on a MSI board. Maybe they should use high-quality fans instead of the flashing LED crap.
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  i second that. the ones on geforce 6000 series cards require complete dissasembly for cleaning. crud even collects on the underneath of the fan blades so bad i used alcohol and a cotton bud to clean it off.
                  • Mark19960
                    • Nov 2005
                    • 5
                    The caps we happened to have here in stock ..
                    (mind you these are for consumer electronics repair)
                    were Nichicon PM series. They look like they will do the job for the time being.
                    Specs here
                    • Chris1992
                      • Apr 2005
                      • 561
                      PM are good but PW, HE are lower ESR. Keep the PM, they are way better than the choyo sh!t.
                      • Jim_IT
                        • Dec 2005
                        Hey,
                        I have a Gigabyte GA-7VAXP than just burst another 5 cps after already sending it back for RMA, November last year when they replaced 2 caps 1000uf 6.3v caps and a mosfet.
                        I replaced it with an ASUS A7n8X-E Deluxe. No problem. I put the RMA'ed Giagbyte MB back into a new system around December 2004. Again, it started giving me prblems, so I swapped in a new Asus A8N-E.
                        I still need this MB back in production, but do not have the confidence in my soldering skills to pull all the remaining caps and replace. I plan on sending it to someone, since thenexperation of my warranty was 4 weeks ago. They should have replaced all the caps, wether bad or not.
                        My question is, as linuxguru states there are a bunch of open spots where it appears additional caps should be, can additional caps be added for additional stability/protection.
                        Jim
                        • willawake
                          Super Modulator
                          • Nov 2003
                          • 8457
                          • Greece
                          yes but if you do that to boards, you have to figure out what values should be there. perhaps looking at review pictures of the same board you can figure that out or with some trial and error testing instead.
                          i have to say a general warning though but concerning other boards with 12v that you have to find where the 12v is going cos thats where you need to put the 16v caps and not 6.3-10v.
                          if you want superior overclock then find the lowest esr caps you can and use those. other things you can try are some little heatsinks on the fets, a superior northbridge cooler, an excellent cpu hsf with only a thin layer of arctic silver, good case cooling and a quality psu with good caps will give you the best performance under air.
                          but if you are talking about stability, even if you just replace the original cap positions with same value caps from a good manufacturer it should be perfectly stable and last for years.
                          was it not posting at that point?
                          • Jim_IT
                            • Dec 2005
                            As far as I can remember, the first time the board would not post.
                            This time, I had a MCE 2005 install running, and it became buggy. (freezing, etc.) I pulled MB and CPU, then tried a new XP install on a new HD. XP Install almost completes normally, i.e. files cannot be copied, then are copied once retried.
                            At power on, there is a high pitch whine is coming from the MB. At first, I thought noise was the from hard drive but another HD sounded the same, resulting in a closer inspection of MB.
                            This is the way it looks now.
                            Jim
                            • willawake
                              Super Modulator
                              • Nov 2003
                              • 8457
                              • Greece
                              can you email me the full pic
                              if you are based in us/canada then Topcat can recap it for you.
                              the whine can be from smt components or the coils when the caps are bad. some boards do that from the coils when new though.
                              • willawake
                                Super Modulator
                                • Nov 2003
                                • 8457
                                • Greece
                                close up from above image
                                busted fets prior to "repair" by gigabyte
                                i wanted to see the big pic cos the fets looked funny but it was just the soldering from the repairs.
                                • Jim_IT
                                  • Dec 2005
                                  Considering that this is an AMD XP MB and the known problems of heat generated by AMD XP CPUs, it's no surprised that cheap caps failed. CPU ran 47c, System around 42c enclosed in the case. I was running the retail HSF because it is very quiet, but lacks big time cooling.
                                  This was a media PC with a ton of components and it needs to be somewhat quiet.
                                  Jim
                                  • willawake
                                    Super Modulator
                                    • Nov 2003
                                    • 8457
                                    • Greece
                                    those purple ones look like GSC?
                                    i have seen GSC fail on an althlon system in a well ventilated case, although not so spectacularly as that but we might have caught that one early
                                    • MD Willington
                                      • Sep 2004
                                      • 702
                                      Originally posted by Jim_IT
                                      Considering that this is an AMD XP MB and the known problems of heat generated by AMD XP CPUs...
                                      Jim
                                      How hot?
                                      Highest thermally speced processor for that board the XP3200+ was ~77W...
                                      K7_Electrical_Specification_Rev_ENG.pdf (application/pdf Object)
                                      Prescott is ??? ... 100W+
                                      The Prescott 3.20E we have has a TDP of 103W. Compare that to a Northwood 3.20C at 82W
                                      Lets not go down that road....
                                      Anyway....same deal Gigabyte 7VAXP Ultra...from a fellow poster at the amd forum...IIRC OST or GSC capacitors onboard...
                                      board is dead right now...he's going to see if he can measure Vcore at the power section of the board...
                                      MD
                                      Ya'll think us folk from the country's real funny-like, dontcha?
                                      The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
                                      • bvchurch
                                        • Mar 2006
                                        MD
                                        That person he is talking about is me.
                                        See here http://forums.amd.com/index.php?showtopic=64285
                                        Anyways I did indeed have a Gigabyte 7VAXP Ultra die on me. However looking at the capacitors I see no damage, no bulging, no leaks etc. Seems to me the board just up and died. Though I am out of the Gigabyte warranty I am dealing with VIsa on it. The visa money will go towards a new computer, but instead of replacing my capacitors on the motherboard i am just going to spend ~$34 for an ECS Kt600 a motherboard.
                                        #1 A64 3200, Gigabyte K8NS Ultra 939, 1GB Corsair VS, 256mb X800XL AIW, Tagan 480
                                        #2 Dell Latitude D810, PM 740, 128mb X600, 1GB Transcend
                                        #3 AXP 2100, Gigabyte 7VAXP Ultra, 1GB mixed, 128mb 9800 pro, Epower Puma II
                                        #3 down.
                                        • DynaxSC
                                          GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                                          by DynaxSC
                                          I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                                          General test conditions:
                                          - Tested with Core i5 6500 and Core I7 6700K - no difference
                                          - Default BIOS settings, but tried also altering several memory setting - does not change anything
                                          What is wrong:
                                          With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                                          When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                                          03-21-2025, 06:23 PM
                                          Thermal pad thickness for various laptop GPU / Graphics Cards
                                          ASUS Dual RTX 2070 OC 8GB
                                          ASUS ROG STRIX RTX 3080 OC
                                          ASUS ROG STRIX RTX 3090
                                          ASUS TUF Gaming RTX 3080 OC Edition
                                          ASUS TUF GTX 1660 S-O6G GAMING
                                          EVGA RTX 3060 Ti XC GAMING 8GB
                                          EVGA RTX 3060 XC GAMING 12GB GDDR6
                                          EVGA RTX 3080 FTW3 ULTRA GAMING
                                          EVGA RTX 3080 TI FTW3 ULTRA GAMING
                                          EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                                          Gainward RTX 2080 Phoenix GS Specs
                                          Gainward RTX 3070 Phoenix 8GB
                                          Gainward RTX 3080 Ti Phoenix
                                          GIGABYTE AORUS RTX 3080 MASTER 10G
                                          02-09-2024, 08:08 AM
                                          A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                                          by momaka
                                          More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                                          And a shot of the label:...
                                          01-26-2022, 03:26 AM
                                        • nikovmiroslav
                                          Gigabyte A5 X1 Need Bios
                                          by nikovmiroslav
                                          Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                                          Gigabyte A5 X1
                                          From motherboard:
                                          S/N: 1TNH55ER1350895
                                          P/N: 6-77-NH55ERQY-D02-2CGB
                                          On sticker from the back of the laptop:
                                          S/N: SN21351J000657...
                                          08-24-2025, 09:15 AM
                                          Gigabyte Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the boardview and schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte Notebook is accurate, safe,...
                                          09-07-2024, 07:19 AM
