Netcomm NB6 Routers - Bad G-Luxon
  • c_hegge
    • Sep 2009
    • 5219
    This is the fouth one I've seen get bad caps over the past couple of months. It's always been G-Luxon caps. I've been re-capping them with Panny FM and they've been fine after that. I'm gonna try FK with this one, since the FM caps are taller and I have to lie them down before they fit.
  • japlytic
    • Oct 2005
    • 2086
    Re: Netcomm NB6 Routers - Bad G-Luxon
    Good repair job.
    I also recommend replacing the three other capacitors that are not bulging as well.
    Most equipment with poor quality electrolytics typically fail after three years, but this is an example of a unit which has failed over two years.
    • c_hegge
      • Sep 2009
      • 5219
      Here it is now with the Pannys. I'm using it for this post. I used FC for the three small caps and FK for the two bigger ones.
      • jonesy63
        • Apr 2010
        • 3
        I just repaired my brother's Dynalink ADSL modem last weekend. It was having drop-outs every hour or so. I found it had two bad 220uF caps (the ones at the bottom of that last photo) - which were rated at 85c. Replaced with some Rubycon 105c caps and no dropouts for a week. All the other caps were rated at 105c, so stupid bean-counters strike again. >-(
        Regards,
        Rob (from Sydney, Australia)
        • paul_h
          • Oct 2007
          • 86
          Bumping the thread because the OP seems still active, and is in Australia too.
          I've got the same problem with my netcomm nb6plus4W modem/router/WiFi
          It has a different board layout though.
          Where most of your caps are, I just have one single 12x15mm 25V 2200uF g-lux SM
          And where your Linkcom chip is, mine has 3 caps bunched together
          8x15mm 25v 1000uf g-lux ?? cap
          10x15mm 25v 1000uF teapo SC cap
          10x15mm 25v 2200 g-lux SM cap
          I've had no luck finding anyone selling caps only 15mm high, let alone 8mm or 10mm diameter. I suppose I could bend them over on long legs, but then I would still need small diameter caps I guess. So where can I get them? And what model?
          • mariushm
            • May 2011
            • 3799
            There's a high chance they don't have to be rated for 25v - they probably chose such high voltage rating to get lower ESR/impedance values and higher ripple from those G-lux and Teapo.
            With better series of capacitors, the same low esr/impedance and high ripple values can be achieved by capacitors rated for less voltage and smaller
            Get a multimeter and measure the voltage between the wires of those capacitors. If it's up to 14v, you can safely go with 16v capacitors (smaller and thinner).
            My guess is the router is powered from an unregulated 9V adapter, which means the capacitors will be hit with anything between 9 and ~12v depending on the load, so you can probably go with 16v capacitors without worrying about it. But just to be safe, measure the voltage between the capacitors wires first.
            As for brands, search on element14 for Nichicon HM/HN, Panasonic FM , Rubycon ZLH or ZL*, UCC KZE ... ZLH and HM are probably going to fit there, FM I know it's a bit larger in diameter.
            • paul_h
              • Oct 2007
              • 86
              Thanks, I'll check the voltage in the morning.
              • paul_h
                • Oct 2007
                • 86
                I checked voltage at the caps to the input ground from the 12v external plug transformer, (and I didn't know where else to check to).
                It's 9V at the caps.
                • paul_h
                  • Oct 2007
                  • 86
                  I had a look in the shed as I have heaps of old PCBs for fridges and a/cs. they had a ton of 25v caps on them, all rubycon yxf (so at least one electronics industry has decent caps, sharp refrigerators and daikin a/cs had nihicon)
                  I had a go soldering them in but modem now dead. It turns on, all lights that should be on are on, but can't connect over ethernet.
                  Do you think it's because the yxf is too out of spec or that I probably fried something heating it up so long to try melt the lead free solder - never had much luck with that? Whatever the sharp pcb had for solder was like old solder, but whatever netcomm used was crap.
                  It could be that the yxf is too out of spec, but the modem worked before with completely stuffed and swollen caps. It just dropped out every few hours or when there was an incoming phone call, when connected it ran normally (full speed ADSL, wifi worked etc)
                  • mariushm
                    • May 2011
                    • 3799
                    Those 3 capacitors should all have the same 9v on them.
                    Near the jack, there's a capacitor that "buffers" the power coming in from the 12v transformer, so that one should get 12-14v.
                    From there, there's an actual voltage regulator (I can see the inductor it needs on the left of the capacitors) which converts the input to 9v.
                    But anyway... yes, YXF should be fine. Did you fry anything? Unlikely. Make sure you soldered each one correctly, check the polarity, the minus on each should be as the old capacitors were mounted.
                    Check the dc adapter with a multimeter - is it really 12v or around that value? Maybe the adapter is gone.
                    Can you connect to the router using a network cable and try to access the internal interface (usually http :// 192.168.1.1 or .100.1 or something like that) ?
                    • paul_h
                      • Oct 2007
                      • 86
                      I can't connect with a pc at the IP address 198.182.1.1 i could before.
                      Cap polarity is fine.
                      I think I did a bad solder job with my old 30W iron though, really hard to desolder the original caps.
                      So I'm looking at getting a decent soldering station.
                      Most here are $200, but I noticed I can get a weller DES51 solder station from US amazon shipped to australia for $100.
                      Is it worth it as $100 is the max I can spend, and I need to recap a PC mobo soon anyway so I'm looking to upgrade the iron anyway.
                      I will get some proper matching caps and wait for the soldering station to arrive if it's worthwhile, probably get a new modem tomorrow anyway as well, and just practice on this one I likely stuffed.
                      It could be a adapter, as i couldn't read 12V anywhere, 9V was the highest, most places only read 7V. Strange I couldn't measure any voltage with no load, ie the bare plug from the adapter was 0V when unplugged from the modem but still plugged into the wall??? Using my fluke 87 iii.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        is your wallwart ac?
                        that would be right if it uses a bridge and the input caps are open.
                        if its dc then the walwart/smps is bad.
                        • paul_h
                          • Oct 2007
                          • 86
                          Yeah, I'm retarded. Sorry, it is an AC wallwart with 15VAC out of it, so used to testing DC ones.
                          I'm not crazy after all power wasn't coming from thin air, it's just that I am an idiot sometimes.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4951
                            • New Zealand
                            Is it still working?
                            Can you tell me which model capacitors you used (sometimes there are multiple versions of one value with different can sizes etc)
                            -David VanHorn
                            • c_hegge
                              • Sep 2009
                              • 5219
                              We still use that router at work, and it still works to this day. IIRC, I used http://australia.rs-online.com/web/p/aluminium/0571656/ to replace the two bigger ones, since they were the only ones with a high enough voltage which would fit. Any Panny FC should work for the smaller ones.
                              EDIT: http://newzealand.rs-online.com/web/...inium/0571656/ for RS New Zealand
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4951
                                • New Zealand
                                Thanks, I'll have to give those a try
                                -David VanHorn
                                • Hornnumb2
                                  Home routers
                                  by Hornnumb2
                                  Is it just me or does it seem like the routers just dont last anymore. It seems like about 1 1/2 years mine starts dropping signal and losing connections. I am not buying the cheapest but middle of the road around $100. Any suggestions for one that will last? Thanks Michael
                                  07-01-2024, 07:36 AM
                                • double_DD
                                  Why does my ISP router hate my "homemade" power supply??
                                  by double_DD
                                  It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                                  So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                                  For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                                  07-12-2025, 03:09 AM
                                • BOSCHNJAK
                                  by BOSCHNJAK
                                  ABOUT ME INTRODUCTION FILE
                                  2
                                  024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                                  2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                                  2022 BEV, PROJECT ?
                                  2021 BEV, PROJECT ?
                                  2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                                  2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                                  12-28-2023, 02:09 PM
                                • Russ1
                                  Starlink GEN2 Router Internal Power Supply Chicony UTP-211C Schematic
                                  by Russ1
                                  Sick of seeing big numbers of these routers dead no power light underneath.....
                                  Chasing Schematic of this power supply I have searched high and low....
                                  Already spotted a few swollen caps, but Ac fuse ok.....
                                  This is a dual output 50Vdc 2.5A and 12Vdc 1.25A psu
                                  Can anyone help with any type of schematic and parts list ?
                                  Thanks and Regards, Russ
                                  07-10-2025, 11:01 PM
                                • Babo Tech
                                  Need bios bin Hp g42 daax1jmb8c0 rev:c
                                  by Babo Tech
                                  Hola a todos,
                                  Llego al taller una notebook, Hp g42 daax1jmb8c0 rev:c, que enciande mas no da imagen, ya probamos con las ram, voltajes, salidas hdmi y nada, y por lo que veo es problema de bios,
                                  si alguienme puede ayudar con dichas bios, se lo agradeciaria mucho.
                                  A notebook arrived at the workshop, HP g42 daax1jmb8c0 rev:c, which turns on but does not give an image, we already tried with the ram, voltages, hdmi outputs and nothing, and from what I see it is a bios problem,
                                  If anyone can help me with these...
                                  02-03-2025, 07:19 AM
