Netgear = By far the most horrible support ever!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Netgear = By far the most horrible support ever!
    Originally posted by stj
    and routers dont need to use a "cloud" to administer the settings either!!
    They do that so they can sell you subscriptions....don't pay, you can't control your own hardware until you do.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      My Nighthawk router is still going strong... same model as the one I gave you (Topcat).
      But otherwise, Nutgear can take a hike... I've had hit and miss luck with them myself. I use a lot of thier pro-Safe POE switches in my volunteer work (FIRST Robotics competitions fields use one for powering an Airtight wifi sniffer over POE and connecting up a lot of peripherals to the main server cabinet). Can't say I've ever had to pull one from the case of spares. But with warranty support that crappy, I'd never buy one at market price!
      I'll use TP link for "dumb" devices (unmanaged switches, etc.) but anything smart I steer clear of (unless it's something I can put open firmware on). I don't trust them as far as I can kick them.
      sigpic
      (Insert witty quote here)
        • 31248
        i was looking at these:
        https://www.ebuyer.com/641041-tp-lin...ed-8-tl-sg108e
        it's amazing how cheap you can get a metal cased 8way gigbit switch with user management and diagnostics!!!
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          I'm running that one in my house, set up as a basic access point....it doesn't need to do anything heroic other than provide WIFI coverage in the house. You have an open firmware on yours? If so, what?
          I have tons of those little guys I pulled from a K12 EDU. I haven't pulled a bad one out of the pile yet.....but what wrenches those for my application, I needed POE.
          Team : 49813
          Join in!!
          Team Stats
            • 31248
            yea, they have that option, but POE doubles the price!!
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              DD-WRT.
              That said, I need to redo it on a newer firmware as Kong builds are abandonware. I've been stuck in "if it ain't broke don't fix it mode" except that it is broke (security issues, etc.) At my (as of July) former church I ran a similar R6300 V2 on newer firmwares and for the most part everything worked (it was also a SAMBA and FTP server via a USB 3.0 -> eSata external HDD). The two are so similar that I was able to do an NVRAM dump from my former R6300 (which was what I ran at my apartment) into the R7000 (which I scored right after buying my house) and it ran great and what the current setup was carried over from.
              It's used as a router and AP... a grand total of 3 SSIDs ("main" (2.4 and 5), "guest" (2.4 and 5), and "chromecast 5G" (5 only, to force the chromecast to not use 2.4 which would throttle it).
              sigpic
                • 31248
                i use OpenWRT
                https://openwrt.org/
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  i use OpenWRT
                  I've used it... for me, the potential performance gains aren't enough to warrant the difficulty of setup and maintenance. But I do have a few gigabit N Linksys routers on the shelf that are only supported by OpenWRT and have it installed.
                  Routers are something I want to work and work well... for me DD-WRT fits the bill. To each their own.
                  sigpic
                  • gripa
                    looking for netgear WN2500RP schematic
                    by gripa
                    I am looking for a schematic of the netgear WN2500RP repeater.
                    best regards
                    12-17-2024, 12:39 PM
                  • greatdragon
                    Looking for schematics for Netgear Nighthawk c7500
                    by greatdragon
                    The markings on the board say
                    tmt YAML 1 94V-0
                    e114139
                    1806
                    03-20-2025, 11:58 AM
                  • shovenose
                    Netgear JGS516PE Switch Fan Replacement
                    by shovenose
                    I got a free Netgear JGS516PE PoE switch and it works fine but the fan makes a grinding sound.
                    It uses a 12V 3 pin fan with a non standard pin out. So I took a Noctua fan and moved the wires around in the connector to make it work.
                    Unfortunately, the fan spins for just a couple seconds before it turns off and the Fan Fault LED comes on.
                    I think it's stupid they designed it to stop powering the fan when it detects a fault but I guess that's what they chose to do.
                    Instead of spending $30 on the correct replacement fan, does anyone have a clean...
                    12-12-2024, 03:24 PM
                  • ay_erdi
                    Netgear R7500 Router Dead
                    by ay_erdi
                    Hi everybody,
                    My router netgear R7500 is dead.There are four burnt components inside.Can you help me identify?
                    VR8-U17-U78...
                    02-16-2024, 10:58 AM
                  • suiramix
                    Netgear R7200 (AC2100) no boot up
                    by suiramix
                    Hi there,
                    Netgear router, model R7200 [similar to R6800, R6700v2] pressing power button, the WiFi LED glowing solid white, with NO Power LED light… so no boot up properly! Done the hard reset for 30/30/30sec …no change. Checked the power adaptor voltage output= 12.02V
                    Remove the cover and check all components … no visible damage. The inductors and solid capacitors show reasonable voltages [between 12.0, 5.0 ,3.3 and 1.0V] except L10 and C205 = 0.67V, [my guess is kind of low].
                    The U21 and U23 ICs [voltage reg] have similar application circuit but unable to identify...
                    11-09-2023, 01:00 PM
