Netgear WPN824 drops off the LAN
  • smason
    • 1652
    My up to now very reliable Netgear wireless router suddenly started dropping off the LAN. Wireless connections stay up, but can't see the LAN. Power off then back on and it's good for a day or 2.
    I cracked it open, and looky there, 2 Teapos and 6 Capxons.
    I wonder if they're the issue. Guess I'll order some replacements and give it a try. I s'pose I should check the wall-wart too.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Netgear WPN824 drops off the LAN
    Did you change or enable any new features on the router? Add any new devices on the LAN side?
    In the enterprise network world, this sounds like a classic memory leak issue. Something has changed and causing the software to slowly consume all free memory until you reboot it.
    When it drops off the LAN, can you ping the router? Does the ARP cache look right?
    Also try hooking up a computer running wireshark to see if it sends out ethernet packets or not.
    --- begin sig file ---
    --- end sig file ---
    • japlytic
      • Oct 2005
      • 2086
      Have you tried the latest firmware update? This may fix this problem.
      • smason
        • 1652
        That's the odd thing, nothing has changed in a year. It defintely doesn't respond to pings, in fact I get an alert from Nagios saying it's down.
        Next time it dies I'll do a tcpdump and see if it's talking at all.
        • Scenic
          o.O
          • Sep 2007
          • 2642
          most likely dried out / baked dry. happened in my router (D-Link DI-604 from 2004) too.
          the caps (Teapo and TBOR (?)) looked fine, but that thing was flaky as hell.
          recapped with panny FC's and never had any problems since then.
          edit: runs quite a bit cooler too. probably due to less ripple/noise..
          • retiredcaps
            • Apr 2010
            • 9271
            It is also possible that something external is causing the wireless side of the software to consume/leak memory which causes the LAN side not to respond.
            Darn, if only these home routers had a show memory command, you could rule out a memory leak!
            tcpdump will also work.
            I think I'm in the minority of people who actually power off their router when not in use. Most of the other people I know leave them on 24/7. So it is possible that your caps are reaching end of life depending on the inside temp?
              • 31010
              not in use?
              most people use the router 24/7
              either for torrent/mule or just to monitor email & stuff.
              • NxB
                • Feb 2009
                • 1595
                wow, getting online would take forever. I don't think I've ever met anyone who powers off their networking gear.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  It takes less than 20 seconds for any modern home router to boot and get a dhcp address from the isp. That is alot faster than my home computer booting up. So I power up the router first and then the home computer.
                  • severach
                    • Aug 2007
                    • 1055
                    20 second or 10 minutes. Having to plug in the router to use the Internet brings back some of the torture of dial-up. The whole point of low power consumption high reliability networking is so it can be left on all the time.
                    If the caps wear out they get replaced.
                    sig files are for morons
                    • ay_erdi
                      Netgear R7500 Router Dead
                      by ay_erdi
                      Hi everybody,
                      My router netgear R7500 is dead.There are four burnt components inside.Can you help me identify?
                      VR8-U17-U78...
                      02-16-2024, 10:58 AM
                    • double_DD
                      Why does my ISP router hate my "homemade" power supply??
                      by double_DD
                      It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                      So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                      For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                      07-12-2025, 03:09 AM
                    • EasyGoing1
                      UPNP, "Standards" and hardware that implements it
                      by EasyGoing1
                      I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                      One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                      So I decided to implement UPNP...
                      07-16-2022, 07:12 PM
                    • gripa
                      looking for netgear WN2500RP schematic
                      by gripa
                      I am looking for a schematic of the netgear WN2500RP repeater.
                      best regards
                      12-17-2024, 12:39 PM
                    • shadow666
                      Router Xiaomi M4A Gigabit
                      by shadow666
                      hello
                      i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
                      Mi Router 4A Gigabit Edition
                      ROM CHIP is 16 MB
                      i attached picture of motherboard​...
                      11-30-2024, 03:49 PM
