Dead NIC's
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Dead NIC's
    Hi, I've got a bunch of dead NIC's
    One in a mini-itx system, integrated on the mobo, it was hit by lightning, no visible damage, no link detected
    Next a small HP thin client, t5000 series, no link detected (also integrated on mobo)
    A Intel Pro 100 NIC, same deal, no link detected
    All these install the drivers fine and as far as Windows and Linux is concerned work just fine, they just can't bring up a link...
    Where would I start to troubleshoot this?
    Reason I ask is that I see allot of these in the field and would love to be able to fix them, especially the smaller systems that don't have room for PCI expansion cards...
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dead NIC's
    Hook up wireshark and see if there are any ethernet packets coming from the devices. If they are working, you will see ethernet packets.
    http://www.wireshark.org/
    Check to make sure your computer bios is up to date. Sometimes a firmware upgrade may help?
    Try disabling the network port in bios, save, cold boot (shut down via power switch), reboot, and re-enable network port in bios and reboot.
    Some computers can also do a network boot. If you enable that, you should see ethernet packets on wireshark.
    --- begin sig file ---
    --- end sig file ---
      • 31277
      Re: Dead NIC's
      i would start by removing and metering the windings on the transformer.
      if you cant see one then it's hidden in the back of the rj45 connector.
      next, search a datasheet for the network chip - they usually have partial schematics of how you connect the socket through the transformer to the chip.
      • seanc
        • Nov 2008
        • 1319
        Re: Dead NIC's
        I have a dead one in a Shuttle.
        Replacing the Realtek chip and swapping crystals didn't help, must be the port which I can't get off of the board.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: Dead NIC's
          Look for blown SMD fuse near jack.
          Mann-Made Global Warming.
          - Dr Seuss
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Re: Dead NIC's
            I looked at the price on those NIC ports, usually they are combined with 2x USB ports (all boards I have with failed NIC's are)
            The price on those at Elfa Sweden was ca $13
            That's a big no thank you!
            Can probably find used complete boards cheaper than that!
            PCBONEZ; I shall look for fuses, but I'll probably need to post a pic for help with identification
            • seanc
              • Nov 2008
              • 1319
              Re: Dead NIC's
              I'll pull my port off the board I pulled the chip from, if I can.
              As far as I know, no SMD fuses on mine.
              The network card reboots all of the time.
              • brethin
                • Dec 2008
                • 1907
                Re: Dead NIC's
                99% of all onboard nics have a SMD fuse.
                Same for the PS/2, USB, Firewire etc.
                They may be hard to find, real tiny but they are there somewhere.
                This is even more true on laptop than desktop boards.
                • NxB
                  • Feb 2009
                  • 1595
                  Re: Dead NIC's
                  There is nothing in the connector to break.
                  • seanc
                    • Nov 2008
                    • 1319
                    Re: Dead NIC's
                    Where's the transformer stj mentions then? Or is he talking about something else?
                    • NxB
                      • Feb 2009
                      • 1595
                      Re: Dead NIC's
                      It should be near it.
                      • kikkoman
                        • Jul 2007
                        • 691
                        Re: Dead NIC's
                        sometimes they're integrated in the jack. but on the Intel Pro, they're external.
                        "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
                        • EvazX
                          ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                          by EvazX
                          I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                          Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                          For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                          However, after some time, the replacement motherboard...
                          08-25-2025, 06:09 PM
                        • glutton4punishment
                          Samsung monitor Installed 1 cap wrong, now menu button dead, "no signal detected" msg
                          by glutton4punishment
                          Samsung synchmaster 226BW.
                          Before I replaced 5 caps, the screen was dim.
                          Sometimes it wouldn't turn on.
                          I opened it up, and found 4 bad caps in the pwr supply section.
                          I unfortunately installee one backwards, i.e. wrong polarity.
                          When I turned it on, I head a loud pop, and I quickly shut it off.
                          The replaced caps are 3 860uF 25V's, and 1 330u 35V.
                          One of the 860uF blew.
                          I didn't have another 860uF at home, so I tried it with a 1000uF 35V cap (I remember the reading of the 1k uF cap was close...
                          03-18-2023, 12:49 PM
                        • howardc64
                          Samsung UN55JU650DF network/streaming problem
                          by howardc64
                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                          07-09-2025, 12:44 PM
                        • double_DD
                          How can I be sure that my EC chip is dead?
                          by double_DD
                          As the title suggests, how can I be sure that my EC chip is really dead?
                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                          03-12-2025, 07:47 AM
                        • davg
                          Home network connection problem
                          by davg
                          I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                          03-06-2021, 07:13 AM
