Thinking of Recapping a D-Link DSL-G604T router
  • KevinR
    • Jan 2010
    I make good use of old(er) routers with the 3rd party RouterTech firmware. One of these is refusing to recognise 100base-t ethernet but is happy at 10base-t speeds. I've seen on the web a similar model of d-link and some other brands where this problem has been fixed by replacing some of the caps.
    I found one thread here on BadCaps that mentioned the G604T but no feedback about if the recap worked.
    Examination of the router reveals the majority of the Electrolytics are GSC and the rest are TBOR (if I read the logo correctly).
    There are:
    GSC 1000uF 35V x2 - main PSU caps + space for 2 more.
    TBOR 225uF 35V x1
    TBOR 220uF 16V x5
    GSC 100uF 16V x8
    GSC 47uF 25V x4
    None show any obvious damage.
    Supply is 12V AC 1.2A (ie. unregulated). So I think those capacitor voltages are all pretty nominal.
    Some Questions:
    Has anyone recaped a G604T?
    Is it worth giving it a go given the brands involved?
    Is it better to work in sections, testing as I go?
    Or just do all of them?
    I'm assuming an old Oryx-50 iron should be able to pump out enough heat with the aid of some desoldering braid or a cheap sucker?
    Aside:
    One thing I have learn while researching this is that many (most?) smaller capacitors like those above are only rated for 1000 hours at full load. And that was Panasonic FC. In a router left on 24/7 that's only 41 days. Even if we assume they'll last rather longer at more moderate voltages, temperatures, & fluctuations you need a factor of 9 to last a year. These routers were made from about Nov-2003 so some of them need need x53 for 6 years. So to some extent failure can't be surprising, even if its breakdown rather than leakage or blowing.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Thinking of Recapping a D-Link DSL-G604T router
    Can't hurt (as long as it's not a life-or-death piece of equipment). Caps are cheap (depending on where you live,) as long as you don't botch it soldering try it and report back
    As for the life-time:
    Their rated life is at the highest rated temperature, voltage, ripple current, and other factors. Rubycon says that for every 10C drop in temp the life span doubles, and thats not counting lowering other factors like ripple, voltage, etc...
    The lowest rating I have seen on a good cap manufacturer is 2000hrs, even so they can usually last longer than their rating.
    • KevinR
      • Jan 2010
      I will probably give it a go, as #1 is now the spare and its ethernet is now slower than the line sync.
      I may have to change router & especially chipset anyway to get the best out of my ADSL2+ LLU line, so its not much of a risk. The replacement G604T (#2) is doing OK (about 12Mpbs sync), but either the line or it is doing less well than theory suggests (about 12-20Mpbs depending where you look).
      I'll need to get some desolder braid at less than Maplin's mad price, etc!
      The figure on the capacitor life came off Farnell's website for the Panasonic FC range. The small ones were 1000 hours. Rising for the bigger caps. It varies by voltage, capacitance and dimensions. Here's the Spec sheet for the Panasonic FC at Farnell At 25V (and below) the 100uF are only 1000 hours (at max loading ofcourse), the 1000uF are 3000 hours at 16V (and above). At certain values the capacitor proportions affect the lifespan.
      So in these examples the main capacitors at 1000uF may well be ok (with a good brand or cool router) BUT the little 100uF ones are more at risk.
      Even given the rule-of-thumb you quote, to guarantee 6 years out of a 100uF (even an FC) versus 1000 hours continuous operation at 105C we need that factor of 53. Now 2^6 = 64 and is more than 53. So we have to keep the circuit below 45C (105-(6*10)) to get over 3.6 years (41*2^5 days) life.
      Comparing that with a lesser Panasonic with only 85C max temps, we'd lose 20C from the rule-of-thumb and need 25C max temperature to get into the 6 year lifespan. And routers get a lot warmer than that! Assuming the use of cheaper capacitors.... oh look mine's got GSC.... well it does feel iffy.
      • japlytic
        • Oct 2005
        • 2086
        The GSC units are straight after the AC bridge rectifier, so they should be no problems.
        Have you tried updating the firmware in the router? Version notes can be found at:
        ftp://files.dlink.com.au/products/DS...ease_Notes.txt (Revision A units)
        ftp://files.dlink.com.au/products/DS...ease_Notes.txt (Revision B units)
        ftp://files.dlink.com.au/products/DS...ease_Notes.txt (Revision C units)
        Don't forget to perform a factory reset before and after firmware upgrades.
        If you still have problems, try replacing the electrolytics.
        Last edited by japlytic; 02-05-2010, 02:18 AM. Reason: Firmware upgrade Reset procedure
          • 31090
          isnt the Oryx a Butane gas iron?
          • Agent24
            I see dead caps
            • Oct 2007
            • 4981
            • New Zealand
            I was recently given a DSL-G604T which apparently would keep losing settings etc. I figured bad capacitors might be an issue.
            It's full of GSC and TWBOR (that's the correct name) same as yours, though nothing is visually bad. I suspect they haven't got to that stage yet or have dried out instead.
            I'm thinking of recapping in the future and then just seeing what happens.
            -David VanHorn
            • japlytic
              • Oct 2005
              • 2086
              The 8 most important capacitors to replace are:
              C45 (input filter)
              C5, C184 (+3.3V)
              C204, C61 (+3.3V)
              C1 (+3.3V)
              C79, C81 (+12V regulated)
              C132, C151, C152 and C157 are the input filter (should be OK as-is)
              • japlytic
                • Oct 2005
                • 2086
                C81 should be C91. My mistake
                • double_DD
                  Why does my ISP router hate my "homemade" power supply??
                  by double_DD
                  It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                  So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                  For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                  07-12-2025, 03:09 AM
                • shadow666
                  Router Xiaomi M4A Gigabit
                  by shadow666
                  hello
                  i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
                  Mi Router 4A Gigabit Edition
                  ROM CHIP is 16 MB
                  i attached picture of motherboard​...
                  11-30-2024, 03:49 PM
                • EasyGoing1
                  UPNP, "Standards" and hardware that implements it
                  by EasyGoing1
                  I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                  One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                  So I decided to implement UPNP...
                  07-16-2022, 07:12 PM
                • hinisa
                  Xiaomi router freezes at boot after re-capping
                  by hinisa
                  I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                  When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                  After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                  Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                  07-08-2023, 05:58 AM
                • spleenharvester
                  Synology MR2200ac mesh router, UART connection - login details?
                  by spleenharvester
                  This particular unit powers up, LEDs behave normally, but broadcasts no SSID, will not mesh with any other routers. Plugging in an ethernet cable from a Windows laptop results in "unidentified network" with an autoconfigured IP address and no response to pinging 192.168.1.1.
                  I was able to log into serial/UART by connecting the 6-pin header to the GPIO on a Raspberry Pi Zero W (GND to GND, TxD to RxD, RxD to TxD, no connection between +3.3V as it is supplied on both sides) using Minicom, command:
                  Code:
                  sudo minicom --baudrate 115200 --device /dev/ttyS0
                  09-02-2024, 01:19 PM
