Need LAN connection over several hundred meters - how to do this?
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3259
    • Singapore
    Re: Need LAN connection over several hundred meters - how to do this?
    just adding in my 2 cents. the schematic of your idea in the first post is almost exactly like how we implement the trace together system for malls, buildings, places etc. in singapore so the infected and their contacts can be quickly found and isolated to reduce spread. so the idea is definitely sound and it works in reducing the spread of covid-19.
    the proof is in singapore's flat and non-existant curve. we are an island of 5.5 million people and we currently have 5 straight days of zero community cases and then followed by one day of 1-2 cases, then the pattern repeats over and over again. so well done in doing your part to help flatten the curve in your home!
    and yes singapore too is a covid fortress where no one can come in without first testing negative. thats why singapore is cracking down hard on illegal immigration lest illegals bring covid in here. vietnam was doing so well in containing covid-19 but an infected illegal immigrant from china ended up causing the danang outbreak and ended vietnam's clean sheet of zero covid deaths. ah well... when u snooze against covid, u lose... lol!
    i should get out more and stop working from home like chicken little... i may go out and see if i can figure out a proper detailed schematic of how singapore does the trace together system in buildings to compare and see if improvements in implementation can be done but no promises! if u dont hear back from me, it means im not quite done figuring it out yet. im not going to post in this thread anymore until i have something better to post. lol!
    • CapLeaker
      Leaking Member
      • 7969
      All my network / internet stuff that is spanning anywhere from 300m to a few kilometers is done with wifi bridges. Look at Ubiquiti etc. I have some links going now for more than 10 years. All it ever happened was that the POE power supplies went bad. Or fiberoptic.
      • petehall347
        • Jan 2015
        • 4422
        • United Kingdom
        there are wifi routers that connect together easily .my one will do it . never tried that though i just use it for my internet connection .
          Great Sage é½Šå¤©å¤§č–
          • 30911
          using wifi outdoors in some european country's is very illegal - check your laws.
          • dicky96
            Sun Seeker
            • Mar 2017
            • 1825
            • Spain
            We have that Ubiquity system here - it is how a lot of folks get their internet - from base stations around the hills/mountains
            Strangely enough, the local guy I needed to hep me with this is currently ill with flu - not covid - which is why I posted here as the quotation for solution is now urgent and this is not my area of expertise
            Thanks to all for advice - I do understand this topic is contraversial for some but in the case of our island communities it is essential we find a way to reopen our economies
            Follow me on YouTube
            Learn Electronics Repair
            • CapLeaker
              Leaking Member
              • 7969
              If I would be in your shoes, I'd just slap a ubiquity system there and be done with it.
              • dicky96
                Sun Seeker
                • Mar 2017
                • 1825
                • Spain
                #27
                Yeah I found someone local who installs the Ubuiquity and he is qiving me a quote today
                  • Jul 2011
                  • 6018
                  seems a bit flawed as all hot people are not infectious .
                  Then I would say everyone need to stay home and just be safe
                  But I would hope that everyone is wearing the right type of face mask and and more than 6 feet apart from each other and limiting there exposure in other words only goes some where if you have to
                  • televizora
                    ghettomodmaster
                    • Nov 2016
                    • 957
                    • Bulgaria
                    #29
                    It's very simple. The maximum length of cable in one network segment is 100m.
                    Use POE and put 3 switches, if it is inside a building.
                    Powerline is also an option, although you have to test it. These adapters are not very reliable.
                    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                    • dicky96
                      Sun Seeker
                      • Mar 2017
                      • 1825
                      • Spain
                      #30
                      No its an outdoor market
                      So I got a ubiquity omni directional antenna, and a directional dish shaped one - point the dish at the omni and it works
                      • televizora
                        ghettomodmaster
                        • Nov 2016
                        • 957
                        • Bulgaria
                        #31
                        Then you have no other option, rather than either WLAN or eventually Powerline. Omni or panel antenna BS AP + panel or directional client AP-s.
                        • Woodsworth
                          PS3 CECHC03 60GB YLOD Troubleshooting
                          by Woodsworth
                          I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
                          START
                          Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
                          03-19-2024, 07:58 AM
                        • budwich
                          Lithium 12v tool battery charger... no negative connection?
                          by budwich
                          I have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the...
                          03-18-2025, 09:12 AM
                        • Demetrio87
                          Legion t 5 front audio panel connection problem
                          by Demetrio87
                          Hi everyone, I hope someone can help me solve my problem, I have the case of a legion t5 where I have installed an asus tuf gamig a520m-plus motherboard, the audio connection cable on the case is an F_audio connector with 14 PIN , on my new motherboard the connector is a 10-pin AAFP, I saw that there are adapters on sale but at the moment I have no way of having them available in a short time, I made several attempts and managed to listen from the front headphones, only that there are some problems, the headphones are only detected if the microphone is connected, I definitely got confused with...
                          12-08-2023, 12:06 PM
                        • Nikan.e
                          Inno 3d RTX2070 not detected - no I²C connection
                          by Nikan.e
                          Greetings and Salutations!
                          I have encountered a faulty GPU — an Inno3D RTX 2070 Twin. There was a shorted MOSFET on the Vcore rail.
                          The faulty DrMOS was removed, and the burned PCB area was milled away.
                          All voltages are now good, but the GPU is not being detected.
                          I found that the CS pin of the BIOS (GPU) is not being pulled low, and thus, the GPU isn't detected.
                          I wanted to measure the SM_Data and SM_Clock, but to my surprise, there is no connection at all.
                          I thought these pins were used for communication during startup?!?
                          On all...
                          03-30-2025, 07:21 AM
                        • ktmmotocross
                          Lenovo Legion 5 Pro 16ACH6H bad crystal?, but now wont program. connection lost after 5 seconds
                          by ktmmotocross
                          Hello.
                          Have this Lenovo Legion 5 Pro 16ACH6H that came with no start, only powerbutton light. i reflash bios and ec. no change. i replace one of soc cpu crystals and laptop start to work. but when i assemble it, keyboard not work. so i reflash back bios but when i try to reflash ec i get write error and now i connect to it but always read/write error and connection lost after 5 seconds.
                          IC is ITE8277E - 256 programmer is vertyanov. i try to change back that crystal but still the same
                          NM-D562 rev3.0
                          sn- PF31EESB
                          any ...
                          01-22-2024, 05:33 AM
