Fiber bridge?
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Fiber bridge?
    I've been asked to deploy a small LAN at a local non-profit. As there are several "remote" buildings, I'll have to run optical fiber to connect them (reliability).
    Normally, I'd just cable together a pair of switches and that would be the end of it. But, here, they are concerned with power consumption and have few nodes in each building. The idea of installing a fiber-capable switch just to get that interface comes with a high price tag (in terms of power consumption).
    So, any experience with Gbe/fiber "bridge" appliances (aka "media converters")? Or, will I have to roll my own?
    • 31009
    Re: Fiber bridge?
    that's strange, i'm sure a laser running at a few mW is far less than the current through standard ethernet.
    • Curious.George
      • Nov 2011
      • 2305
      • Unknown
      Re: Fiber bridge?
      It's not the power for that SINGLE interface but, rather, using a fiber capable switch (instead of a smaller, more efficient NON-fiber capable switch) just to get the fiber interface.
      Single-link, unmanaged media converters are more acceptable in terms of power budget. But, less likely for me to encounter in my "rescues" so that would require them to PAY for kit with very limited (to them) perceived value. ("Why can't we just run a cable??")
      • diif
        • Feb 2014
        • 6978
        • England
        Re: Fiber bridge?
        https://www.tp-link.com/lb/products/...43_MC220L.html
        Max power consumption 3.95W.
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          Re: Fiber bridge?
          Originally posted by diif
          Excellent! Thanks!
          Now the trick will be to get them to ante-up $100 to buy two sets...
          But, at least I can ask my other contacts for anything similar sitting on a shelf!
          • Ross Kohler
            Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
            by Ross Kohler
            I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
            - There's no sign of any attempt to power on when pushing the power button.
            - No PSON signal is reaching the 24-pin ATX connector.
            - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
            - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
            - If I pull the Super IO S_SLPS#_R pin...
            04-16-2024, 09:36 AM
          • Roman555
            Asus H77 LGA1155 mainboard stopped working with Ivy Bridge CPUs
            by Roman555
            Bad symptoms when Ivy Bridge CPU (3rd-gen 22nm) is installed:
            • Won't boot OS (just blank screen or stucks at asus logo, monitor is turned on) with hangs at debug (post) code A3;
            • USB stick with MS-DOS can be loaded via F8 boot menu;
            • Other OSes won't load - hangs or goes reboot;
            • Postponed for several seconds reaction to Alt-Ctrl-Del, Reset and Power buttons;
            • An operating system starts loading but won't finish if it's left only 1 CPU core in BIOS settings;
            What I've already done and it hasn't helped:
            • Cleared CMOS many times;
            • Flashed different versions of BIOS in a CH341 programmer;
            • Updated
            01-18-2024, 06:26 AM
          • Byte_76
            Gainward GTX 295 SLI Bridge
            by Byte_76
            I have a Gainward GTX 295 with two PCB's which has a broken SLI bridge ribbon cable. As a result, the card is entirely useless and I'd really like to fix it if possible.
            I've searched eBay and AlieExpress but haven't been able to find the part.
            I believe this same SLI bridge cable is used on the Nvidia 9800 GX2 and the GTX 295 which both have two PCB's.
            Can anyone help me on where to get a replacement SLI bridge cable please?
            05-10-2024, 03:07 AM
          • davidebeatrici
            Sony M851 MBX-217 no POST and restart loop
            by davidebeatrici
            Before proceeding with a component level repair, the usual troubleshooting process was followed:
            1. Disassemble and unplug everything except the power connector.
            2. Replace RAM.
            3. Replace CPU.
            4. Rewrite BIOS.
            Unfortunately the board was still stuck with a 0.75A power consumption at 19V.
            After reflowing both GPU and north bridge in one shot (it can't hurt) there was an instant improvement with a constant 1.75A power consumption, but I immediately noticed smoke and the typical smell coming from the GPU area.
            I thought to myself "Well,...
            07-03-2025, 04:19 PM
          • Steph.hen
            Bridge rectifier identification part number KPB305G
            by Steph.hen
            Hi all, a newby question about a bridge rectifier I'm trying to identify.
            I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
            08-29-2024, 09:52 AM
