Zyxel WiFi VDSL VMG1312-b30b dsl port off
  • perseus142
    • Jun 2017
    • 30
    • Czech republic
    Dear all,
    I am experiencing troubles with my wifi zyxel router VMG1312-b30b
    DSL port is off, DSL cable isnt detected.
    WiFi, Ethernet ports are working well, GUI accessible.
    After inspection of the box is obvious, that resistors R8, R16 are damaged/burned. Unfortunatelly, I am not able to find electronic schematic so I dont know the resistance.
    Could anyone help me with identification of SMD R8, R16 please ? These are next to DSL (RJ-11)and Ethernet(RJ-45) ports, close to H2001dg.
    Also, could you help me with identification of GA1 which is parallel to DSL port ?
    Pictures are attached.
    Thank you in advance.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Zyxel WiFi VDSL VMG1312-b30b dsl port off
    I would make an educated guess that R14 is the same as R8 and possibly R16.
    GA1 looks like a diode to me. Does it measure like one ?
      • 31015
      ga1 is a spark gap and should meter open-circuit.
      • perseus142
        • Jun 2017
        • 30
        • Czech republic
        Thank you.
        Right, I did measure open circuit in both directions, so it might be ok ? Or is there anything else what I could test/measure here ?
        For education purposes, is there a way how to decode the color code/strip on it and find out the exact model ?
          • 31015
          400v
          • perseus142
            • Jun 2017
            • 30
            • Czech republic
            400v
            Thank you very much.
            • perseus142
              • Jun 2017
              • 30
              • Czech republic
              Another broken part - could you help me with identifiacion please ?
              SMD diode HD1, HD2: O8W 4X - unable to find on google
              Have you seen it before ?
                • 31015
                MM5Z10V if it's a letter "O"
                MM5Z4V3 if it's numeric "0"
                • perseus142
                  • Jun 2017
                  • 30
                  • Czech republic
                  Amazing
                  How did you decode the diode ?
                    • 31015
                    https://www.badcaps.net/forum/showthread.php?p=507366
                    • perseus142
                      • Jun 2017
                      • 30
                      • Czech republic
                      An idea how to determine whether is this 10V or 4,3V ?
                      0 and O looks similar
                        • 31015
                        desolder a working one and stuff it on a zener tester.
                        • perseus142
                          • Jun 2017
                          • 30
                          • Czech republic
                          Right. After desoldering the working one I measured Uz=9.36 V
                          My new 10V zener diode has got Uz=9.6V.
                          Is that suitable replacement part ?
                            • 31015
                            close enough.
                            zeners are only acurate to the last 5% usually anyway.
                            • howardc64
                              M557-G0 no WiFi/Bt no WIFIVendor file?
                              by howardc64
                              Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
                              • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
                              • Service Menu shows many Bt/Wifi info missing
                              • Vizio app shows no WIFIVendor file
                              Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
                              • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
                              10-15-2024, 01:12 PM
                            • fredyjbi
                              please help, friend, thinkpad L480 NM-B461 rev 1.0 JDOCK1 type C port 5volt only, thank you
                              by fredyjbi
                              I have a thinkpad L480 NM-B461 rev 1.0 laptop functioning normally with Type 1 port (JUSBC1)
                              if you use port type C 2 (JDOCK1) with a usb type meter it only displays 5v, thank you
                              I tried to look at the schematic diagram USBC_VBUS20, which is the port path from JusBC 1 to U4701 then goes to the system2 charging IC, why is there no system2 path leading to the charging IC on the TYPEC_VBUS20 port which is JDOCK1, thank you for your help.
                              if you look at the power sequence there must be 2 types of port type C a (JUSBC1) via U4701 and port type C b (JDOCK1)
                              On the type...
                              07-09-2024, 11:28 PM
                            • k3wf3w
                              HDMI port component identification - Samsung NU7100 UN58NU7100F - Kant M2E - BN94-13065G
                              by k3wf3w
                              Hey Badcaps,
                              Hoping someone can help me identify this HDMI port, and/or a suitable substitute. I have scoured the internet, but no luck.
                              Is the circle "T" symbol a manufacturers logo?
                              Thanks!
                              05-22-2024, 11:52 AM
                            • ugamazing
                              820-00850 & 820-01949, No WiFi *In Recovery*
                              by ugamazing
                              I've got two boards with the exact same issue, and it's confusing the hell out of me. In short:
                              1. Both boards behave *exactly* the same; they will show WiFi networks to connect to, and will boot fully to Internet Recovery, but they each show zero available WiFi networks once booted to Internet Recovery. I also cannot switch WiFi "off", as in, the toggle will not move.
                              2. Both boards will erase perfectly fine using the "erase mac" function; I can wipe them with disk utility, but if I try to install MacOS from Internet Recovery, it says to connect...
                              01-25-2023, 05:39 PM
                            • AlexVG
                              Replacing the WiFi module on a vacuum cleaner iROBOT i7
                              by AlexVG
                              I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
                              I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
                              (This board does not respond, only the LEDs light up in a circle.
                              The liquid damage is catastrophic and restoration is impractical).
                              (I bought this board to get the WiFi module and camera).
                              The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
                              If...
                              10-22-2024, 07:20 AM
