tp-link TD-W8960N router/modem advice
    • 30911
    Re: tp-link TD-W8960N router/modem advice
    ah, i forgot about the streaming problem.
    a number of routers have a security function that tries to scan for viruses - turn it off if you see it.
    streaming can overfill the buffer and lock or lag the router.
    • vinceroger69
      • Mar 2012
      • 6714
      thanks stj ive just looked again the the router settings and could not see anything regarding virus scans on a good note the router rebooted its self last night and my download speed has gone up to just over 10 meg which is good only time will tell if its lasts but it seemed ok last night whilst i was watching the new top gear (the grand tour) through kodi and a addon, if you get chance it was a good well worth watching if your into cars etc.
      • DJ_MIX
        • May 2005
        • 118
        which kodi addon ?
        • vinceroger69
          • Mar 2012
          • 6714
          mats build is my main kodi add on but the top gear one is
          https://www.youtube.com/watch?v=4BR6...ex=143&list=WL
          • vinceroger69
            • Mar 2012
            • 6714
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              Originally posted by DJ_MIX
              which kodi addon ?
              specto is the best add on at the moment for anyone wanting too watch the grand tour its in tv shows/people watching section a reliable stream to and good quaility.
              • sofles
                Macbook Pro 16" A2141 screen artefacts, kernel panic
                by sofles
                Hi there.
                I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
                I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
                Now situation looks like this, If...
                02-05-2025, 05:05 AM
              • prw07
                MacBook Pro A2141 - macOS Kernel Panic
                by prw07
                Mac crashes and restarts with kernel panic. No water damage on board. Board is clean. Memtest86 showing no errors. The installation Ventura or Sonoma is successful, but after 5-10 minutes of operation, the accident occurs again. Did a DFU restore and revive, twice with success and successfully reinstalled Sonoma. After 5 minutes of work Mac crashes with Kernel Panic. Apple Diagnostic (AHT) does not find errors.
                How to localize the problem ?
                12-05-2023, 06:57 AM
              • phantomEVO
                [help] Macbook pro 13 820-00840-a: RANDOM KERNEL!!!!
                by phantomEVO
                Please help. Never opened before!!
                arrived with black screen (with backlight) . trying to reboot: still the same.
                booted to usb ->ok
                format ->ok
                but a lot of kernel panic!
                tried other os, tried other ssd, no luck
                sometimes it works flawessly, some time a lot of kernel
                I ADD KERNEL PANIC LOG
                PS no error from apple hardware test...
                07-07-2022, 08:07 AM
              • ronaldopdias
                A1990 Constant Kernel Panic: AMDFramebufferVIB::setPowerState
                by ronaldopdias
                Hi, I have an A1990, i9 & Radeon 560X. Before it was freezing every few seconds, almost as if failing SSD, even on external macOS installation. I have tried a clean reinstall, revive + restore T2 firmware and it now works fine, other than it seems to kernel panic after some time in sleep.
                Below is the kernel panic log, its similar to a lot of posts online for the same model, with no comments on how to fix the issue, and whether its firmware related or an LB issue. Most seemed to happen running Catalina but I am on the latest version of macOS Ventura....
                07-07-2023, 01:58 AM
              • smic717394
                Macbook Pro 8.2 2015 kernel task 100% and very very slow
                by smic717394
                I need a bit of help. I have a Macbook pro end 2011 8.2. I bought it of a customer cheap because it has a bulged battery. I replaced the battery and upgraded the ram 2x8GB total 16GB, and replaced the HDD with a SSD. What happens with this laptop is very strange and I don't know where to begin. The laptop doesn't panic, tha fans run normal even when the kernel is 100%. If I reset the SMS, will run normal for about 30 to 1 hour then the kernel_task goes to 95% and the laptop become unusable. If I reset the sms agail will run again normally for some time. I thought is the battery,...
                12-14-2024, 01:32 PM
