[help] Macbook pro 13 820-00840-a: RANDOM KERNEL!!!!
  • phantomEVO
    • Mar 2013
    • 488
    Please help. Never opened before!!
    arrived with black screen (with backlight) . trying to reboot: still the same.
    booted to usb ->ok
    format ->ok
    but a lot of kernel panic!
    tried other os, tried other ssd, no luck
    sometimes it works flawessly, some time a lot of kernel
    I ADD KERNEL PANIC LOG
    PS no error from apple hardware test
  • mon2
    • 14339
    Re: [help] Macbook pro 13 820-00840-a: RANDOM KERNEL!!!!
    820-00840 = A1708 = flexgate (dark screen). You can try to contact Apple and raise a stink about their design. The cable was too short in the PCBA process and breaks over time. We have had the display assembly replaced by Apple without a cost and even the butterfly keyboard replaced on behalf of end clients.
    • phantomEVO
      • Mar 2013
      • 488
      problem is not display....problem is kernel panic.
      screen is perfect
      • mon2
        • 14339
        • phantomEVO
          • Mar 2013
          • 488
          black screen like soft bricked...not an hardware problem
          • sofles
            Macbook Pro 16" A2141 screen artefacts, kernel panic
            by sofles
            Hi there.
            I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
            I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
            Now situation looks like this, If...
            02-05-2025, 05:05 AM
          • prw07
            MacBook Pro A2141 - macOS Kernel Panic
            by prw07
            Mac crashes and restarts with kernel panic. No water damage on board. Board is clean. Memtest86 showing no errors. The installation Ventura or Sonoma is successful, but after 5-10 minutes of operation, the accident occurs again. Did a DFU restore and revive, twice with success and successfully reinstalled Sonoma. After 5 minutes of work Mac crashes with Kernel Panic. Apple Diagnostic (AHT) does not find errors.
            How to localize the problem ?
            12-05-2023, 06:57 AM
          • Wachenaggo
            Macbook Air 2013 820-3437 OSx Frozen and Kernel Panic Missing ME
            by Wachenaggo
            I got 2013 820-3437 that can't boot completely onto OSx and can load EFI ASD BUT can't on OS ASD and it gives this kernel panic error FAILURE missing ME. I already check ME disable strap HDA_SDOUT_R is low
            Also before I reflash the bios I was able to boot osx 10.9 maverick SSD from another client. But when I install a fresh maverick it is frozen.
            I already reflash bios using ch341 with clean me provided by piernov and 2informaticos then I even make my own using piernov's guide. some of those BIOS are boot looping the system.
            I also manage to damage...
            03-29-2022, 07:36 AM
          • kurtspirit
            Macbook Air A1466 2013 reboot and kernel panic
            by kurtspirit
            I currently have a Macbook Air A1466 which has constant reboots or kernel panics without ever wanting to start.
            If I boot from a USB installation drive, everything is fine but when I run a new system installation on a new drive or external drive, it freezes after a while. I was able to detect a small artifact on the screen during the freeze but I'm not sure if it's specific.
            I measured some voltages on the motherboard and I could see that the 1.8V fell to 0V during the reboot but maybe this is normal? The other voltages (5V, 3V, 16V if I'm not mistaken) are ok and...
            06-30-2022, 02:15 AM
          • Instafixx
            Macbook A1707 820-00928 Panic Log
            by Instafixx
            Namaste!
            We have a Macbook A1707 which came in for repair. Someone had already tried to work on it and there were traces oh heat and burns on the board.
            The charger was Stuck at 5v and the there was some caps shorted around U3100.
            Turns out there was corrosion under U3100. Same was Reflowed and the Macbook turned on. Works fine but having 1 issue whenever the Macbook is idle and goes into sleep mode. It will WAKE for 1 Second and then do a restart.
            It will Display a Black Screen with error message saying Macbook Restarted because of a problem....
            01-19-2023, 04:15 AM
