Hardening my server.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    As some of you might know, I have a domain. I've signed up for a free account with a security scanning website and they scan my site and find problems. So far, I have 12 low risk security issues and I'd like help to harden the system a bit. Right now, I'm concentrating on the SSL cipher list. I don't know much about SSL and the ciphers. I'm going to post what ciphers my server currently supports and I'm hoping, if there's any that should be removed, maybe someone could let me know? Anyway, here it is:
    Code:
    This test detects which SSL ciphers are supported by remote service for encrypting communications.
    Here is the list of SSL ciphers supported by the remote server:
    - High Strength Ciphers (>= 112-bit key)
    * TLSv1 - DHE-RSA-AES128-SHA Kx=DH Au=RSA Enc=AES(128) Mac=SHA1
    * TLSv1 - DHE-RSA-AES256-SHA Kx=DH Au=RSA Enc=AES(256) Mac=SHA1
    * TLSv1 - n/a Kx=DH Au=RSA Enc=Camellia(128) Mac=SHA1
    * TLSv1 - n/a Kx=DH Au=RSA Enc=Camellia(256) Mac=SHA1
    * TLSv1 - n/a Kx=ECDH Au=RSA Enc=AES(128) Mac=SHA1
    * TLSv1 - n/a Kx=ECDH Au=RSA Enc=AES(256) Mac=SHA1
    * TLSv1 - DES-CBC3-SHA Kx=RSA Au=RSA Enc=3DES(168) Mac=SHA1
    * TLSv1 - AES128-SHA Kx=RSA Au=RSA Enc=AES(128) Mac=SHA1
    * TLSv1 - AES256-SHA Kx=RSA Au=RSA Enc=AES(256) Mac=SHA1
    * TLSv1 - n/a Kx=RSA Au=RSA Enc=Camellia(128) Mac=SHA1
    * TLSv1 - n/a Kx=RSA Au=RSA Enc=Camellia(256) Mac=SHA1
    The fields above are:
    * {OpenSSL ciphername}
    * Kx={key exchange}
    * Au={authentication}
    * Enc={symmetric encryption method}
    * Mac={message authentication code}
    * {export flag}
    Another test shows a bunch of info and then at the bottom, it shows:
    Code:
    This SSLv2 server does not accept SSLv3 connections.
    This SSLv2 server also accepts TLSv1 connections.
    Should I have SSLv2 disabled and only accept SSLv3 connections? And is TLSv1 good? Thank you!
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • Spork Schivago
    • Mar 2012
    • 4734
    Re: Hardening my server.
    Just wanted to add that I have done some reading up on SSL and TLS. My understanding is SSL v1 was never publically released because of some serious flaws. Netscape released SSL v2 but it also had flaws. Then they release SSL v3 which also had flaws and was susceptible to the POODLE attack. Can I disable SSL all together and just use something like TLS v1.2?
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      https://www.ssllabs.com/ssltest/
      what's your domain?
      edit: should look something like this, if not, link the report and I can help you fix it.
      • Spork Schivago
        • Mar 2012
        • 4734
        what's your domain?
        Thank you. I ran the test (had to whitelist the IP because it got blocked). Here's a link to the report:
        https://www.ssllabs.com/ssltest/anal...hideResults=on
        There are some issues with it. I see:
        Code:
        The server does not support Forward Secrecy with the reference browsers. Grade reduced to A-
        So I'd like to fix that. Certificate is perfect, from what I can see. Protocol Support needs some work, Key Exchange needs more work than Protocol Support and Cipher Strength got the same score as Key Exchange.
        I also see:
        Code:
        In trust store	DST Root CA X3  Self-signed
        Fingerprint SHA1: dac9024f54d8f6df94935fb1732638ca6ad77c13
        Pin SHA256: Vjs8r4z+80wjNcr1YKepWQboSIRi63WsWXhIMN+eWys=
        RSA 2048 bits (e 65537)	/ SHA1withRSA
        [B]Weak or insecure signature[/B], but no impact on root certificate
        I'd like to find out how to fix that weak or insecure signature as well, even though it has no impact on root certificate.
        • Spork Schivago
          • Mar 2012
          • 4734
          I see I'm not protected against the BEAST attack, even if it might not exist anymore. Would dropping TLS v1.0 and supporting just TLS v1.1 and v1.2 be an effective option to protect against the BEAST?
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Originally posted by Spork Schivago
            Code:
            SSL v2 was broken a few months after being released 1996, now 20 years later you can take a guess how good it is to use it!
            SSL v3 was broken more recently, but it's still been deprecated for a year and not recommended in new installs for much much longer than that.
            TLS is the continuation of SSL, there are some highly theoretical attack scenarios for 1.0, but usually you would be fine to have it enabled.
            If you don't you will loose WinXP and older browsers like Opera based on the Presto engine.
            This Mozilla page has a pretty good rundown on how to configure things:
            https://wiki.mozilla.org/Security/Server_Side_TLS
            • Spork Schivago
              • Mar 2012
              • 4734
              Thank you. So TLS and SSL are the protocols? And currently, I have SSL v3 enabled, right? So I'd like to disable that. I'm on the fence whether I should support XP or not. When you say I'll loose support for XP, do you mean I'd lose support for IE running in XP? Would Chrome / Firefox on XP still work? I appreciate you teaching me this stuff.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                No, you have SSL v2 enabled according to that tool which is a disaster.
                See for example this weeks latest exploit: DROWN
                https://isc.sans.edu/forums/diary/Ex...y+DROWN/20789/
                https://drownattack.com/
                https://access.redhat.com/security/v...bilities/drown
                As for XP support if you run the "modern" cipher XP wont be able to connect because it only supports TLS 1.0
                With the intermediate cipher that enables TLS 1.0 it will work with IE8.
                You really don't want to enable the backwards compatible one, let IE6 die already!
                Some browsers have their own TLS implementation, Fiefox is one, Chrome might too but look it up first.
                So with Firefox on XP you can have the modern cipher enabled and the customer will still see your site...
                • ddscentral
                  • Mar 2008
                  • 151
                  • Lithuania, EU
                  I'm using these on my server (Apache 2.4.7 with Haproxy as frontend):
                  EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:ECDHE-RSA-AES128-SHA:DHE-RSA-AES128-GCM-SHA256:AES256+EDH:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES128-SHA256:DHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES256-GCM-SHA384:AES128-GCM-SHA256:AES256-SHA256:AES128-SHA256:AES256-SHA:AES128-SHA:DES-CBC3-SHA:HIGH:!aNULL:!eNULL:!EXPORT:!DES:!MD5:!PSK:!RC4
                  I also have disabled SSLv3, enabled OCSP stapling and HTTP Strict Transport Security.
                  A+ in SSLLabs test.
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    I understand. So TLS is a cipher. What are the protocols then? I agree, IE 6 should die. If I'm not mistaken, XP _can_ run IE8. When I tried downloading it an off-line installer from Microsoft for it, it errored out saying it wasn't compatible with XP, however, after I found a way to get Windows Update working, it did install IE 8. Hopefully, there aren't too many users still using XP.
                    I thought SSLv2 and 3 were disabled. In WHM, I see:
                    Code:
                    TLS/SSL Cipher List
                    ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA
                    This is a standard format list of the TLS/SSL ciphers cPanel Web Services should use. Typically this will only need to be adjusted for PCI compliance.
                    TLS/SSL Protocols
                     SSLv23:!SSLv2:!SSLv3
                    This is a standard format list of the TLS/SSL protocols cPanel Web Services should use. Typically this will only need to be adjusted for PCI compliance.
                    I thought the ! meant that it was disabled. Also, now my subdomain redirects are messed up and not working. I have to have Proxy Sub-Domain redirects turned off. I had the subdomain redirects setup manaully, so when went to places like whm.jetbbs.com, it'd forward it to the correct port. Now, when I go to any of the subdomains, I get
                    Code:
                    The server at cpanel.jetbbs.com can't be found, because the DNS lookup failed. DNS is the network service that translates a website's name to its Internet address. This error is most often caused by having no connection to the Internet or a misconfigured network. It can also be caused by an unresponsive DNS server or a firewall preventing Google Chrome from accessing the network.
                    Before, it was setup to automatically create something called a A name or something whenever I created a subdomain. I don't think the subdomains are registered with the DNS server now. I'd like to figure out how to manually set that stuff up.
                      • 30991
                      wouldnt it be better to ditch all the short keys like 128bit
                      force browsers etc to use larger keys like 384.512 or even 1024bit keysize.
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        Is that question for me? If so, I honestly don't know enough about this to answer the question. If it's for someone else, I'd also like to know. My SSL cert uses a 2048 bit RSA key I think? Would that mean I should set the key size to 2048 bit? Or is that for something else?
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          No, you want to use the lowest cipher that is considered safe.
                          Or more appropriately the "cheapest" cipher to generate CPU wise.
                          For example AES256-GCM is prioritized above the 128 bit variant.
                          The reason is the former has a considerable market penetration with CPU's that can offload the generation.
                          Meaning the 256bit is actually "cheaper" to generate...
                          Realize that when we talk about actually brute-forcing these keys (and not exploiting a weakness in the cipher)
                          Then you would need enormous resources to do it.
                          I was for example part of the Distributed.net project which is just like Seti@Home or Folding@Home to brute force the 56bit key.
                          That was successfully done after 250 days, later they worked on a 64bit key which took almost five years.
                          Currently they are trying to brute force a 72bit key and have been at it for 13 years, at their current rate it would take around 200 years to try all possible keys...
                          But the example is a bit silly, because the way these things are broken are through a weakness in the implementation.
                          Meaning the key wont have to be brute forced at all.
                          That's the case with high profile exploits like DROWN & Heartbleed for example.
                          Another good example of an implementation that was considered safe but no longer is is the 1024bit Diffie-Hellman.
                          But it's only because the same keys for signing was part of each distribution.
                          (To save on CPU resources back in the day, because generating such a key on hardware of "moderate" capabilities in most BCN users mind would take several hours).
                          But the end result is that since the same 1024bit key is on so many systems it's considered that a government sponsored attacker might expend the resources to brute force it...
                          • junktv
                            • Nov 2010
                            • 3065
                            Well there is your problem. You have no brute force measures in place. Are you fighting a 100,000 nerds or a few guys on a mission?
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              Are you just trolling or whats your problem tonight?
                              Key attacks (by professionals) are done offline, but nevermind what I wrote more:
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                Also, I do have on-line brute force protection. If someone connects so many times in a row, they get blocked. I do have to admit, some of this stuff I don't understand. Not gonna lie, the networking stuff isn't my strong suite.
                                I use ConfigServer Firewall, which is nice. If I understand the documentation right, it could be setup in such away when a person gets banned, they get redirected to a page saying they're banned. This requires a few iptable modules that aren't installed and there's no way for me to install them though. I've contacted my provider's tech support to see if they could enable them, but the guy I talked too was a bit rude and didn't understand what I was asking, although he thought he did.
                                He felt that I didn't know how to use iptables. I tried explaining that writing iptables rules wasn't the problem, that I just didn't have two iptable modules installed that I'd like to use. He went on how I can google how to use iptables and if I don't know how to run a server, I shouldn't have one. That kind of upsetted me a bit but I was polite. I feel every time I tried explaining the situation, he just blocked it out, because he felt that he understood what the problem was (that I didn't know how to use iptables). He said I could pay around 300$ a month and have them manage my server. All I needed was a few words added to a file or two in the virtuozzo's config files.
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  who is the provider
                                  • JuniperSprouts
                                    Solder Soldier
                                    • Aug 2010
                                    • 119
                                    The provider sounds like someone from whom I would not want service!
                                    • Spork Schivago
                                      • Mar 2012
                                      • 4734
                                      who is the provider
                                      GoDaddy.
                                      • Spork Schivago
                                        • Mar 2012
                                        • 4734
                                        Yeah, usually, when I call, the people are extremely nice and knowledgable and if they don't understand something, they take the time to look it up or ask someone who might know. It's just this one guy. I've talked to him maybe 2 or 3 times. He seems to work when it's night for me. When it's 3AM here, if I call, I always seem to get him. Overall, they're not bad. Just one guy that doesn't seem to like his job and maybe puts in the least amount of effort to do his job.
                                        • omega
                                          Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                                          by omega
                                          Hello all,
                                          as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                                          Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                                          02-09-2024, 03:34 PM
                                          HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
                                          This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
                                          09-06-2024, 11:39 AM
                                        • harp
                                          Comparing FreeNAS, FTP server, SMB server, multimedia server...
                                          by harp
                                          I thinking about some central LAN file server, on where I can put some files from other devices, or access to them, and maybe play some movie without download...
                                          I never study this, but when I see that freenas need few gigabyte of ram to recommended working, some wiered partition, I wonder if I miss somewhat in the midletime...
                                          Also exist "turnkey file server", and other turnkey products that I can not distinguished what is major difference and how it perform - no experiance at all.
                                          What is general difference between this products, and what be most useful...
                                          01-04-2024, 02:44 PM
                                        • Fireballcz
                                          Windows 2016 server L2TP/IPsec VPN - two subnets
                                          by Fireballcz
                                          Hello, please how to properly configure VPN in this environment?
                                          I have two subnets in two different (geographical) workplaces, connected via IPsec (thru gateway routers)
                                          Main subnet: 192.168.11.0/24, gateway (router IP) 192.168.11.1, Windows 2016 server (VPN, DHCP, DC etc.) 192.168.11.3
                                          2nd subnet : 192.168.22.0/24, gateway (router IP) 192.168.22.1 - just client computers.
                                          I need to allow external (home office) users connect via VPN server (192.168.11.3) to the 2nd subnet (192.168.22.0/24) to their computers (via RDP).
                                          I have no problems with VPN connection...
                                          07-29-2022, 03:20 AM
                                        • dfear
                                          HP ELITEBOOK X360 1040 G7 - "power-on authentication" problems.
                                          by dfear
                                          A customer dropped off a HP ELITEBOOK X360 1040 G7 with a "power-on authentication" problem.
                                          Customer says he didn't set this up. Neither password or fingerprint works.
                                          I have tried flashing:
                                          1) JBIOS1UH2
                                          with:
                                          a) RCUnlocker (by RethoricalCheese). Didn't do anything, beacause the chip is 32MB in size.
                                          b) HPUnlocker (by mazzif). Made a small change (changed: "00 00 00 00" to "FF FF FF FF".
                                          result: "power-on...
                                          05-17-2022, 05:31 AM
