xfinity xb3 router port forwarding
  • freakaftr8
    • Oct 2012
    • 3743
    Hey guys so I switched up to this new Xfinity xb3 router although it seems nice and it's replacing my failing Asus 5g all my internet ports or at least my addresses are all 10.0.0. Something. All of this didn't bother me too much I can't figure out how to get into the router to address port forwarding so I can make my Synology DiskStation read in the house for plex Media Server. My Smart TVs are saying that they cannot connect to it anymore. Now does this have something to do with me and static or dynamic? And how the heck do I get into the router to address port forwarding rules? I can't seem to find any information on the IP address to get into the router. And people that say they have have had nothing but problems with port forwarding but I can't seem to find information on how to get in to start.
    • 31040
    Re: xfinity xb3 router port forwarding
    10.0.0.1
    10.0.0.254
    192.168.0.1
    192.168.0.254
    192.168.1.1
    192.168.1.254
    192.168.1.20
    ping those common numbers.
      • 31040
      http://forums.xfinity.com/t5/Home-Ne...n/td-p/2145712
      btw, if it's a cloud-login i would sell it and fix the asus.
      • freakaftr8
        • Oct 2012
        • 3743
        Cool I'll try these! Thanks!
        • Compgeke
          • Feb 2014
          • 524
          I've the XB3 (DPC3939) and it's complete crap. Beware that for port forwarding you WILL need to restart in order to view what you've just done or to fix\disable anything. For whatever reason it likes to quit displaying anything there after a day or so. I ended up shoving the thing into bridgemode and it hasn't given any trouble since.
          The address for mine was 192.168.2.1 from the factory. One way to find what yours is running on is to run an ipconfig (or ifconfig) and see what the gateway is set at.
          Example:
          Wireless LAN adapter Wireless Network Connection 2:
          Connection-specific DNS Suffix . : hsd1.ca.comcast.net.
          Link-local IPv6 Address . . . . . : fe80::34b8:610f:361:b95b%16
          IPv4 Address. . . . . . . . . . . : 192.168.2.101
          Subnet Mask . . . . . . . . . . . : 255.255.255.0
          Default Gateway . . . . . . . . . : 192.168.2.1 <-- This would be the address for the modem
          • freakaftr8
            • Oct 2012
            • 3743
            Thanks for the info. Mine seems to be on 10.0.0
            1. Login as admin but I have no idea that.the password is. Tries everything.
            You right about it being crap. This things harder to figure out than my wife. Lol
            • Compgeke
              • Feb 2014
              • 524
              Unfortunately I can't check at the moment but I believe there's a sticker on the bottom that'll have a user\password. If not there on the back.
              • freakaftr8
                • Oct 2012
                • 3743
                Thanks again for the help..the sticker that has the login password for the wifi won't do. I'm thinking of calling comcast. This things lame
                • TurcoLoco
                  Questions About The Numark MixDeck Onboard DC Port
                  by TurcoLoco
                  Hello all,
                  I have a Numark MixDeck from 2011. The power supply seems OK but the DC port within the deck itself seems broken or loose.
                  The device will not power on until the DC connector is inserted and then turned a little counterclockwise then it works but if you touch the cord, poof!
                  I am guessing the cube shaped DC port on the board is bad and needs to be replace?
                  Does anyone know what this part is called so I can check on DigiKey or somewhere?
                  TIA...
                  08-05-2025, 04:00 PM
                • fredyjbi
                  please help, friend, thinkpad L480 NM-B461 rev 1.0 JDOCK1 type C port 5volt only, thank you
                  by fredyjbi
                  I have a thinkpad L480 NM-B461 rev 1.0 laptop functioning normally with Type 1 port (JUSBC1)
                  if you use port type C 2 (JDOCK1) with a usb type meter it only displays 5v, thank you
                  I tried to look at the schematic diagram USBC_VBUS20, which is the port path from JusBC 1 to U4701 then goes to the system2 charging IC, why is there no system2 path leading to the charging IC on the TYPEC_VBUS20 port which is JDOCK1, thank you for your help.
                  if you look at the power sequence there must be 2 types of port type C a (JUSBC1) via U4701 and port type C b (JDOCK1)
                  On the type...
                  07-09-2024, 11:28 PM
                • double_DD
                  Why does my ISP router hate my "homemade" power supply??
                  by double_DD
                  It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                  So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                  For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                  07-12-2025, 03:09 AM
                • CapLeaker
                  Poly VVX-250 VOIP POE problem not booting fix
                  by CapLeaker
                  I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
                  Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
                  11-25-2023, 10:46 AM
                • Scarfycake
                  ASUS proart Studiobook h7600ZW; Had DC in port replaced and all the sudden it isn't charging but is the charging sign is on!
                  by Scarfycake
                  I sent my ProArt Studiobook 16 OLED (H7600, 12th Gen Intel) to the local repair guys to have a very simple DC in port replaced. I sourced the part myself on accessoires-asus (french company) after struggling to find the right part in the UK. It looked completely the same to the installed part from what I can tell. Originally the only issue with the laptop was a bad / loose DC connection, and so the computer and battery acted completely normal aside from a very poor connection that would fail at certain angles. After the repair was completed I brought it home and used it for...
                  05-21-2024, 08:16 AM
