Netgear GSM7224 Switch might need Reflow / Reballing
  • Majestyk
    • Nov 2013
    • 96
    Hi there,
    I have been using this nice 24 port layer 2 switch for a couple of years now. Last week it started to cause serious troubles by rebooting without any reason and by hanging at startup with all the status LEDs permanently lit.
    When I press the packet-processor down gently, the booting continues and the LEDs turn off but the unit will not run stable. When pressing down the processor while it is running might cause the unit to reboot.
    This looks to me like a case of faulty solderings of the BGA chip, a Marvell 98DX240-BCW. The packet-processor doesn´t have any heatsink atttached to it and gets considerably warm during operation.
    The pictures show the packet-processor and it´s surroundings and the bottom side with several capacitors.
    I wonder if there´s a reliable way to resolder / reflow or even reball this chip to make sure it will operate stable for another couple of years.
    • 31199
    Re: Netgear GSM7224 Switch might need Reflow / Reballing
    recap it first.
    • Majestyk
      • Nov 2013
      • 96
      Did that already. The caps on the mainboard are all new. I also checked the ones in the psu, everything´s fine there.
      This must be a mechanical / contact issue since the CPU is tender to the touch.
        • 31199
        normally it would take more heat than that to mess it up.
        if you burned your finger on it then i'd suspect soldering or a bad chip.
        • Majestyk
          • Nov 2013
          • 96
          I don´t think it is getting THAT hot during normal operation. I don´t know what´s happening on hot summer days under heavy data traffic though.
          I´m afraid the soldering was not made perfectly in the factory. Maybe the soldering heat wasn´t appropriate or a solder ball was faulty, maybe the flux had not been dispensed properly.
          I have seen similar embedded units before that showed problems with the BGA soldering without ever running too hot. It´s just lousy manufacturing I assume.
          For a professional reworking specialist it´s probably no big deal removing the chip, reball it and solder it right back to the board. But you got to have a good reworking station, the right materials plus lots of experienc which I lack unfortunately.
            • 31199
            well to reflow a chip that large you need a pre-heater under the board, and a hot-air / IR heater on top.
            other than that, just flux it.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5037
              • New Zealand
              It could also point to one of the ceramic capacitors being cracked or something, and pushing down on the CPU affects it since they are right under it on the other side.
              -David VanHorn
              • Majestyk
                • Nov 2013
                • 96
                There are several capacitors and two inductors on the downside in the processor-area. I resoldered all of them carefully, but the problem persists.
                I also took a look at the layout of the bga pads of the processor. Most of them are located near the edges of the chip, only a few in the center. And the right half of the rear edge is whrere the thing responds to light pressure.
                It´s amazing when you search Youtube for bga reballing. There are guys in China, Pakistan and elsewhere who do this job in a small workshop very professionally and carefully, replacing notebook graphics chips and chipsets on PC-Mainboards.
                I think I will ask some companies here how much reballing this chip would be just for laughs...
                  • 31199
                  the ps3 / xbox360 guys would charge you about 50-75€
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5037
                    • New Zealand
                    The capacitors themselves might be physically damaged, resoldering won't fix that. (Unlikely though, more likely it's the BGA)
                    Any professional company will charge big $$$ (buy a new switch)
                    You'd need to find someone who will do a reflow for cheap, but actually knows what they're doing. Anyone can buy a BGA rework machine on eBay, watch a few YouTube videos, and become a self-proclaimed BGA rework specialist.
                    -David VanHorn
                    • xboxhaxorz
                      • Jan 2011
                      • 196
                      ^ is totally right
                      i had a modem with a similar issue so i took it apart and lifted the chip and wow it was totally delaminated and it kind of made sense because it was kept in the basement so moisture had entered and over time totally destroyed the pcb
                      while you can repair delamination, its not worth it due to a modem being around $80
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5037
                        • New Zealand
                        Moisture by itself shouldn't cause delamination... but running a board that has been exposed to moisture for a long time through a reflow profile without baking the board for several hours at a low temperature first will.
                        -David VanHorn
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5042
                          • US
                          unplug it, push down on the chip fairly hard (and continue to do so) and plug it in, see if the problem persists.
                          • chris1h1
                            • May 2016
                            Sorry to revive a one year old thread, but did you get the GSM7224 working in the end? I've spotted one on eBay with the same symptoms and am wondering whether to risk it; I can replace the capacitors, but reflowing a BGA is not within my skill set.
                              Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                              This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-06-2024, 05:30 AM
                            • shovenose
                              Netgear JGS516PE Switch Fan Replacement
                              by shovenose
                              I got a free Netgear JGS516PE PoE switch and it works fine but the fan makes a grinding sound.
                              It uses a 12V 3 pin fan with a non standard pin out. So I took a Noctua fan and moved the wires around in the connector to make it work.
                              Unfortunately, the fan spins for just a couple seconds before it turns off and the Fan Fault LED comes on.
                              I think it's stupid they designed it to stop powering the fan when it detects a fault but I guess that's what they chose to do.
                              Instead of spending $30 on the correct replacement fan, does anyone have a clean...
                              12-12-2024, 03:24 PM
                            • Natob82
                              Micro Momentary Push Switch?
                              by Natob82
                              Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                              12-21-2022, 05:22 AM
                            • grimacelord
                              NEC TurboExpress On/Off Power Switch Replacement Help
                              by grimacelord
                              I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                              I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                              I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                              11-09-2023, 09:49 AM
                            • SluggerB
                              Help making a switch work the opposite way with a relay
                              by SluggerB
                              I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                              I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                              It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                              02-07-2025, 07:57 PM
