sharing broadband tv signal?
  • ivtec
    • Dec 2008
    • 1967
    Hi guys;i have a subscription of a tv sports chan, now i give my password to my son and my brother in law,in different locations, will that have inpact on my own signal?
  • AFajitas
    • Dec 2014
    • 183
    Re: sharing broadband tv signal?
    I'm guessing you're saying that you have an internet streaming option with your sports channel and you've shared it with others? It all depends on how many simultaneous logins they will let you have at once. Most streaming services gives you at least 3 in order to accommodate multiple devices. You will probably be alright, just don't give it to anyone else.
      • 30917
      you may find the password will only work with one i.p. address at a time.
      • AFajitas
        • Dec 2014
        • 183
        Alot of times they choose not to restrict by one IP because people watch from their mobile devices over LTE etc with a different IP. Worst case scenario if it doesn't work, just change your password and apologize to your family members.
        • AstutePauciloquent
          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
          by AstutePauciloquent
          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
          11-23-2023, 11:02 PM
        • howardc64
          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
          by howardc64
          Failure Symptom
          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
          Where is the short?
          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
          05-27-2025, 02:56 PM
        • JayPoorJay
          Converting +/- 5v to a Usable Hz Signal
          by JayPoorJay
          Good morning.
          I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
          This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
          The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
          08-07-2022, 08:35 AM
        • Scruit
          What is a normal composite signal range for a C64?
          by Scruit
          Hello all,
          Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
          More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
          https://imgur.com/gallery/PpqcqPY
          My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
          More detail:
          Symptoms are that that I get...
          04-28-2022, 05:33 AM
        • supravit2000
          PS4 fat has inconsistent signal after HDMI replacement
          by supravit2000
          Hi, guys!
          I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
          My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so...
          12-19-2022, 08:08 PM
