Forwarding in Router Arris TG862
+ More Options
Posts
  • ivtec
    • Dec 2008
    • 1967
    Hi guys;Has anybody had luck with Port Forwarding in Router Arris TG862
    from Comcast, i have an HD sling box at my sons and want to open a forward port to use the sling box to watch tv remotely,i use to have it at my house but have a vastel router and it was easy to port forward on a Vastel from verizon,now with this new Comcast router it's not easy ,any tips would be appreciated.
    Re: Forwarding in Router Arris TG862
    http://setuprouter.com/router/arris/...forwarding.htm
    http://forums.comcast.com/t5/Home-Ne...CT/td-p/954929
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      those f*cking things suck. your best option is buying a good modem like a motorola and returning the cumcrap one.
      • ivtec
        • Dec 2008
        • 1967
        Thanks guys,I have a Belkin F6D4230-4 v1 should i connect it to the Arris T862
        and open port forward on the Belkin or it doesnยด't work that way?
        thanks
        • Jonny Accelerant
          Banned
          • Aug 2014
          • 205
          For some reason I want to say that Arris is Motorola rebranded.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            it is.
            it has decent router functionality in it.
            but if you want your own router turn off the nat in the arris.
            some carriers lock down the wireless and charge you for it.
            then you want your own router/ap.
            • shadow666
              Router Xiaomi M4A Gigabit
              by shadow666
              hello
              i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
              Mi Router 4A Gigabit Edition
              ROM CHIP is 16 MB
              i attached picture of motherboardโ€‹...
              11-30-2024, 03:49 PM
            • EasyGoing1
              UPNP, "Standards" and hardware that implements it
              by EasyGoing1
              I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
              One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
              So I decided to implement UPNP...
              07-16-2022, 07:12 PM
            • hinisa
              Xiaomi router freezes at boot after re-capping
              by hinisa
              I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
              When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
              After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
              Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
              07-08-2023, 05:58 AM
            • spleenharvester
              Synology MR2200ac mesh router, UART connection - login details?
              by spleenharvester
              This particular unit powers up, LEDs behave normally, but broadcasts no SSID, will not mesh with any other routers. Plugging in an ethernet cable from a Windows laptop results in "unidentified network" with an autoconfigured IP address and no response to pinging 192.168.1.1.
              I was able to log into serial/UART by connecting the 6-pin header to the GPIO on a Raspberry Pi Zero W (GND to GND, TxD to RxD, RxD to TxD, no connection between +3.3V as it is supplied on both sides) using Minicom, command:
              Code:
              sudo minicom --baudrate 115200 --device /dev/ttyS0
              09-02-2024, 01:19 PM
            • filippia1981
              Starlink WiFi router firmware of the HR1211 IC
              by filippia1981
              Hi, I would like to ask if someone has the firmware of the HR1211 IC of the Starlink WiFi router in order to program a new IC
              The diagnosis showed that this IC is shorted and need to be replaced with the right firmware. I cannot find the firmware
              kind regards
              Ioannis Balouktsis
              06-17-2024, 11:38 AM
