D-Link DI-604 router
+ More Options
Posts
  • andlcs
    • Feb 2007
    • 22
    My D-Link DI-604 router HW B1 had a capacitor bulging and leaking a little bit (I saw it after 2 years 24/7 usage). Unfortunately I don't remember the capacitor manufacturer. All I remember is that it was rated for 85oC. The router was still working even with the leaking cap.
    You can see it on the top left corner. The big electrolyte capacitor.
  • shadow
    • Feb 2007
    • 732
    Re: D-Link DI-604 router
    Soooo....do you have this router?
    If you do have it then couldn't you just pop it open again and see what capacitor is there. The thing that you really need to know is the rating in micro Farads. That way you can easily just pick up a top quality Japanese capacitor and solder it in.
    • andlcs
      • Feb 2007
      • 22
      Yes, I still have it. But I've already changed the capacitor and added few heatsinks too:
      • PedroDaGr8
        • Oct 2006
        • 130
        is that SC the new cap? That is a known bad cap company.
        • andlcs
          • Feb 2007
          • 22
          Humm thanks. I'll replace that one too...
          • etnietering
            • Apr 2009
            • 379
            Re: D-Link DI-604 router and DI-524
            Well for a couple years I had been using a D-Link DI-524 wireless broadband router, first at home and then at school. Last fall up at school, it would start dropping wireless connections randomly, which was annoying. I opened it up, and (not knowing capacitors could go bad at the time) didn't see anything wrong. So I spent 80 bucks and bought a new router (this new one's gigabit though ). Recently I found the old one, and took it apart again. What should I find, but bulging and vented capacitors!
            11 Electrolytic caps, all from the "Forever" brand. Looks like they didn't last forever...
            The two closest big ones to the camera have bulged, the one on the right vented through the stamp at the top
            Nice shot of the Forever logo...and check out that depth of field! hehe
            And here it is after replacing all of the electrolytics:
            4x Forever 1000uF 10v -> Panasonic FM 1000uF 10v (and my size measurements were wrong...oh well)
            7x Forever 100uF 25v -> Panasonic EB 100uF 25v
            And to my utter amazement, it works! The transplant surgery took my and my friend about 3 hours, from 1am to 4am....just a tip - don't ever try to recap something in the middle of the night, it will just lead to a lot of swearing and soldering iron burns.
            • Krankshaft
              • Jan 2007
              • 2328
              Hehe that board is a double sided PCB with through hole vias. It takes a bit of practice to remove the caps and install new ones on these boards quickly.
              Nice job!
              Apparently those caps didn't last "Forever" .
              • yanz
                • Nov 2004
                • 910
                but it will be remembered for forever that it is crap.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  these caps will be crap... forever
                  i once had a siemens speedstream wireless-b router that never had issues. i was bored amd opend it, found one bulged tocon, 6 tiny tocons with the bungs shoved completely down and outside of the cap- at first it looked like the caps were mounted on rubber bases until it dawned on me that the thing had no good caps inside. at least i got a pc card out of it
                  sigpic
                  (Insert witty quote here)
                  • Prolog
                    by Prolog
                    12-01-2024, 08:27 PM
                  • chth96
                    by chth96
                    12-22-2023, 04:34 AM
                  • chth96
                    by chth96
                    06-02-2024, 07:31 PM
                  • chth96
                    Is it no harm to replace with capacitor without ripple current rating?
                    by chth96
                    When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                    Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                    But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                    Rubycon YK DataSheet (b...
                    04-19-2024, 05:19 AM
                  • chth96
                    Should I replace polymer capacitor?
                    by chth96
                    a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                    I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                    Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                    Is this ESR value of polymer capacitor correct?...
                    11-18-2022, 04:22 AM
