Choosing appropriate PoE extender
  • Adenitz
    • Jan 2021
    • 122
    • Congo
    I have an application that uses 4 cameras PoE. I have one PoE switch in a cabinet in a server room while Cameras are outdoor at different locations. The closest camera is at distance about 80m (that is the cable length), while the furthest camera is about 160 meters. For sure, three cameras are more than 100 m from the switch in cable length. Voltage level is about 48VDC (that PoE switch is supplying.
    Since PoE is working reliably up to 100 meters, obviously I neeed to use some kind of PoE extenders. In order have two options:
    1. To buy 4 outdoor PoE extenders, like this one ( DIGITUS Outdoor PoE Extender - 10/100 Mbps - 100 m Range - Protection Class IP67)
    2. To buy 2 Outdoor PoE 2-ports extenders, like this one( FASTCABLING Industrial Outdoor PoE Extender 2 Port, Repeat 328ft PoE for Mesh, PTZ Cameras). This would save some cables
    The thing that is strange to me is that these extenders doesn't require any external power supply, so I'm not sure how they're boosting signals. How these extenders really works and the my question is whether I need a different type of extender, one with auxiliary power supply.
    Thank you for your advices.
    • 31087
    POE is something like 42v - it survives long cable runs.
    so the boosters pass the POE power through while buffering the ethernet data.
    • Adenitz
      • Jan 2021
      • 122
      • Congo
      Hi stj,
      I have decided to go with FASTCABLING option, I'll install a small cabinet with two 2-Port PoEs.
      • paparazzo79
        sparklling and buzzing around the switch on the extender cable
        by paparazzo79
        My dear electronics repair guys:
        I switched off this thing (on picture) via switch and switched back ON but immediately I could hear buzz and like a little electric shock around red switch and these 2 lights started to blink but should be ON all the time.
        I then switched it OFF,got afraid that I burnt the PCs via electric shock.
        I saw a little current flash around this red switch and I could hear buzzing.
        All the devices were connected to the extender when I did that but none of them were working at that time (they were in standby mode)-
        This is second time it...
        06-06-2021, 10:37 AM
      • labello
        Tplink RE600x wifi extender
        by labello
        Hi guys, I have this wifi extender from 2 years ago. Itstarted to hhavesome problem like ddisconnectingalone and reconnect alone some time I must turning off wait a couple of minutes and open it to working again, anyway I opened and found some capacitor not very good then I replaced, and this kind of resistance.. It's possible I can't buy it? I mean I read the mark on the pcb but I didn't find it... It's very strange that or the problem is myself getting badly research... thank you all for your reply , your time and your help 🙏...
        07-08-2024, 10:08 AM
        NETGEAR extender power supply problems recap working good now
        This extender unit was having drop out issues and not very reliable and I stopped using it and it sat around for a couple years not being used
        Then I had to replace my router because of a lot of dropouts and becoming anointing my wife has to work from home because of the Coronavirus and she had just about enough of this
        So we got another router but the range of this router is not quite as good my door bell camera would not work correctly anymore so I found the extender again and replaced two 1000uf@16 volt capacitors ( ESR values of 02 and 04 ) with a very low profile...
        05-02-2020, 05:41 AM
        LED Solar Flood Light Dusk to Dawn Security Wall Street Yard Outdoor Lamp modifications are in order
        I bought one about a month ago from an eBay seller who now is out of stock however I found another eBay seller that has the same version of this device so I think about buying a few more of over a period of time
        Awhile back I bought some A123 brand 18650 battery cells that are 3.2 volt battery cells that I am going to use in this device for more running time in a florescent bulb fixture that I gutting out the tube sockets and turn it into a solar powered LED lighting fixture instead
        Pictures will come later when I have the lighting fixture gutted and have the battery...
        08-11-2024, 11:10 AM
      • Gjackson
        Understanding air conditioner PSU logic
        by Gjackson
        I have an air conditioner outdoor control board that I'm trying to understand how it functions. In short, the board takes in 240VAC and splits it into 4 other wires, 2 of these go to power the indoor unit and another 2 go to power the outdoor unit module board. the 310VDC capacitor bank on the outdoor control board get charged up from a rectifier on the outdoor module board. Now what I can't wrap my mind around is the fact that there is a relay in between the 2 mains wires that go from the outdoor control board to the outdoor module board which is normally open, what this...
        11-25-2022, 10:45 AM
