My ATA PAP2T-NA Adapter Bricked, I want to fix
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: My ATA PAP2T-NA Adapter Bricked, I want to fix
    Originally posted by tester2
    When i touch Black Probe on Electrolyte Capacitor of Negative Pin then Red probe on IC Pins
    U11 -- Pin2 : 1.71, Pin3 : 2.60,
    U12 -- Pin2 : 0.95, Pin3 : 1.84,
    What is the voltage on that big capacitor near U11?
    Also, what voltage is the wall-wart (power brick, charger, transformer, etc... whatever you call it) supposed to put out?
    Muh-soggy-knee
    • tester2
      • Sep 2012
      • 28
      • ca
      on PAP2T Power Transformer written
      INPUT : 100-240V , 50-60Hz
      OUTPUT : +5V - 2A MAX
      And when i Touch Black Probe to Negative of Big Cap close to U11, and Red probe to other end of that cap then i got this reading
      Big Cap : 2.92V
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Big Cap : 2.92V
        Check the voltage coming out of the power adapter. Sounds like it may be bad.
        Muh-soggy-knee
        • tester2
          • Sep 2012
          • 28
          • ca
          The Power Adapter when i connect to another good PAP2T that working fine from last 2 months. Power Adapter is fine.
          And i change another Power Adapter and connect to this PAP2T, still same problem.
          But still you want then i will check, please let me know, how to check Power Adpter.
          • Soulzink
            Samsug washing machine. Power supply DC41-00189a board issue
            by Soulzink
            I am trying to fix a samsung washinmachine power supply main board.
            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
            The power supply board reference is the following: DC41-00189a
            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
            04-19-2025, 06:26 AM
          • Asraf Atb
            by Asraf Atb
            01-27-2025, 05:02 PM
          • notallbad
            TCL 55RP620K power board issue
            by notallbad
            Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
            0% p_dim at 1.65v and a_dim at 1v
            50% p_dim at 3.3v and a_dim at 1.65v
            100% p_dim at 3.3v and a_dim at 2.88v
            Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
            Leds are 2 rows of 15 6v leds.
            On inspection of the power board found diode MBR3200 shorted so replaced with...
            07-12-2025, 05:45 AM
          • yaya3gmax
            Laptop Power Issue – Works on Battery, Fails on Adapter Load
            by yaya3gmax
            Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
            Symptoms:
            • Laptop works normally on a pre-charged battery.
            • Battery does not charge when adapter is connected.
            • Without battery:
              • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
              • Speakers “pop” when power cut occurs indicating harsh sutdown.
              • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
            08-21-2025, 07:16 AM
