My ATA PAP2T-NA Adapter Bricked, I want to fix
Re: My ATA PAP2T-NA Adapter Bricked, I want to fix
on PAP2T Power Transformer written
INPUT : 100-240V , 50-60Hz
OUTPUT : +5V - 2A MAX
And when i Touch Black Probe to Negative of Big Cap close to U11, and Red probe to other end of that cap then i got this reading
Big Cap : 2.92VComment
Check the voltage coming out of the power adapter. Sounds like it may be bad.Muh-soggy-kneeComment
The Power Adapter when i connect to another good PAP2T that working fine from last 2 months. Power Adapter is fine.
And i change another Power Adapter and connect to this PAP2T, still same problem.
But still you want then i will check, please let me know, how to check Power Adpter.Last edited by tester2; 12-10-2013, 01:01 PM.Comment
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by Asraf AtbHi everyone,
I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....1 Photo -
by notallbadOriginally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
0% p_dim at 1.65v and a_dim at 1v
50% p_dim at 3.3v and a_dim at 1.65v
100% p_dim at 3.3v and a_dim at 2.88v
Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
Leds are 2 rows of 15 6v leds.
On inspection of the power board found diode MBR3200 shorted so replaced with...6 Photos -
Assuming...7 Photos -
by yaya3gmaxDell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
Symptoms:- Laptop works normally on a pre-charged battery.
- Battery does not charge when adapter is connected.
- Without battery:
- Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
- Speakers “pop” when power cut occurs indicating harsh sutdown.
- If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
- Loading...
