Internet is lossy
    Internet is lossy
    I'm currently having a problem with my DSL internet connection. Basically it worked fine for about 2 weeks (since I just moved in) and in the last couple of days it's been acting up like a 5 year old.
    Basically I'd be using the internet and then slowly my pages would start to have missing objects or would only load halfway and so forth... and then internet would cut out completely but my modem (D-Link DSL-G604T) still had the "internet" light lit up.
    After restarting the modem, the internet would work properly again... sometimes for 10 minutes, sometimes for an hour. Pissed off, I decided to fork out some money and buy a new modem/router (D-Link DSL-2642B)... low and behold, I'm still having the same problem.
    My ISP likes to pretend that I don't exist and puts the blame on my equipment no matter how much I tell them "Hey, I bought a NEW modem, got a NEW phone cable and ALL my phones have filters!"
    Anyway, do you guys think it's my ISP or my modem(s)?
    Re: Internet is lossy
    Should also add that if I leave the internet idle for a while, I lose my connection
      Maybe your network card has some issues ... like missconfigured full duplex / half duplex,
      maybe your network cable has problems (sometimes due to heat/bending/cable pulling the metal contacts in the connector pop out no longer making proper contact with the wires)
      maybe you installed some faulty antivirus/internet security suite which crashes transparently to you and kills connections therefore preventing pages and content (images for example) from loading completely.
      Get WinMTR and keep some traceroutes open for the websites you're sure they're working and see where the data packets get dropped - if it's not at your computer, you can forward the results to tech support to sort the issue.
        I would say its 90% DSL related, have a similar issue at my work place, had repairmen there quite a few times but always show up on a sunny day when the issue isnt there. When a rainy day comes its back to shit again.
        Anyways on to your problem, one thing you can try is disconnect as many phones as possible, this will boost the gain slightly of the signal to your modem, or rather wont lower it. Might also be a faulty phone that cause this.
        I common cause is the "DSL filter", but since you swapped the modem i assume you also swapped the filter?
        If all this checks out i would see if your modem has a console or something where you can log in and monitor line attenuation and gain values and stuff.
        The stuttering in connection is probably the modem talking to the dslam and lowering the speed each time the noise is too bad. Each time you powercycle the modem it will go back up and given time slowly decrease speed again if the line is noisy.
        Hope any of this helps, let us know how it goes.
          Who's your ISP?
          My AT&T connection does this all the time. A brand new modem is being used, so it's not that.
            You say it goes to shit, when it's rainy, that's bad wiring either on the telco end or your end.
              At one time, it was our ADSL filters - a good reason to stay away from the bargain counters...
                also check an make sure main line for phone is grounded properly! have seen that be the cause of some of the symptoms you speak of!
                  I would replace the wiring from the box to the jack. (The wiring that goes into your house.)
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                    Thanks for the help guys. I dunno what was going through my head at the time... but I decided to buy ANOTHER modem/router combo. This time I spent nearly $100 on a D-Link DSL-2740 Wireless N router combo. It's been up and running for about 24 hours now and I'm glad to say that I have absolutely NO dropouts or problems at all with my internet now.
                    Does this mean that the D-Link I bought 2 days ago is.... faulty as well? ... buying a faulty product to replace another faulty product? :S
                      wouldnt be the first time to get a dud out of the box.
                      reminds me of the wrt54g v2"s i bought off a guy on cl.
                      he had 6 of them.
                      said none were stable.
                      found the factory used a 2.2 uf 450v cap on the input.
                      wonder how many made it off the line with that goof?
                      a recap and dd-wrt or tomato fixed them right up.
                        I was gonna say it sounds like the modem router is overheating. I've had this issue with a few brand new netgear routers before, where wither the wifi or Internet drops out randomly once the modem has been running for a bit. I would have tried taking the case off the old router and putting a fan next to it. Some modem/routers just aren't made for Aussie weather.
                          For the best help with this you should provide the following:
                          Speeds you are paying for, Kbps UP / Kbps Down
                          What you are paying monthly
                          Your ISP provider
                          BIG HINT INCOMING! Never buy equipment to fix a issue with a provider!
                          They provide equipment (most of the time for free) Use their shit and once its working use you own equipment. When it stops working remove your equipment and put theirs back and make them fix it.
                            Your ISP provider
                            Well, this is what I supposedly get for my $30 a month for internet...
                            Download speed: Up to 20Mbps (yes, up to... i'm lucky if I get about 6!)
                            Upload speed: 1Mbps (I think?)
                            ISP: TPG Australia
                            Equipment wise... I get nothing. ziltch, zero... nothing. I have to provide my own ADSL equipment. Alternatively I could buy their Chinese made No-name routers for $150 which is a big rip off IMO.
                              I know it is, and its on the telco side, they just have to not ignore it and call the problem solved all the time when it isnt.
