My Phoneline Problems
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Everytime it rains hard my phone/DSL line goes down. Yesterday I had a "Tech" in India tell me that my phoneline was working just fine when in fact my phoneline was full of static and had no dial tone. The DSL was also down. I tested the phoneline at the test port in the box with no change. After and hour on the cell phone with them yesterday they said that they would send out a "Repairman" today. I couldn't sleep so just on a lark I checked my phone and the line is clear as a bell. My DSL is also back up and working great. Something in my line gets wet with a hard rain but yet always dries back out before the phone company subcontracted repair man ever gets here to find the problem...LOL Here is a short list of problems that they have found in the past. 1. About few feet of wire up on the pole was melted. Lightning Strike maybe? 2. Rain cove on the junction in the line right by my house was open. 3. Squirrels chewed up another junction in the line behind my house in the alley. 4. The main junction box just up the street has also caused problems because it leaks. Its a wonderful world where the system that you pay money to use is such a mess.
    Mark Twain
    John Paul Jones
    Rod Serling
  • mockingbird
    • Dec 2008
    • 5488
    Re: My Phoneline Problems
    Somewhere in your neighborhood, there's a junction box where some lines meet. It's about 3 ft long by 2 feet wide with the depth of a shoebox. In my neighborhood it's grey colored.
    You can easily lift the cover it's only attached with a rudimentary hinge. Inside are lots of inch wide screw-in fuses. Have the technician trace your line to the fuse in the box, unscrew the old fuse, clean out the oxide, and give you a new fuse.
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      Mb I guess that is the big junction box that is just up the street from me. It leaks and the repair men are always messing around in it. I never knew just what was in there myself. Thanks to you I now have an idea. If a repair man does show up today I'll ask him to clean out that fuse as you said. They just may have done something to it like that last night. My wife did put the hammer on them when she spoke to them. She told them that I have uncontrolled seizures that always require Medical Introvention and what "The Fuck" was she going to do when not having a working phone if I go down again! Come to think of it she was telling them the truth sort of. She didn't tell them that there are also two working cell phones here. Good for her for thinkng fast on her feet.
      Mark Twain
      John Paul Jones
      Rod Serling
      • SluggerB
        Help with trying to fix phone that is not charging (Pics inside)
        by SluggerB
        I have two TCL A30 phones.
        Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
        New Phone: Works fine, bought as a donor board to try and repair Old Phone
        My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
        08-12-2024, 08:11 AM
      • cubytus
        Samsung UN50TU8000FXZC shows thin horizontal green line when warm
        by cubytus
        Hi to all,
        I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
        I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
        Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
        01-10-2024, 01:26 AM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • otaku_nut
        Vizio E701i-A3 fixed but now has red vertical line
        by otaku_nut
        Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
        08-19-2025, 06:11 PM
      • TrueSword88
        Kogan - KALED65XU9220STB - Blue Vertical Line
        by TrueSword88
        Hi all.
        I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
        The line just happens to coincide with the end of COF and start of the next COF (attached).
        The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
        Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
        Hoping to fix...
        05-05-2023, 04:28 PM
