Advent Powerline Ethernet Adapters
    Avoid these like the plague
    I was given two of them, new in the box, for my own uses. I use them to connect my upstairs computer to our downstairs network; it removes the hassle of having to run a wire upstairs or use wifi, which never worked well. There are a pair of adapters, they connect to each other. I'm told you can also expand the network and add as many adapters as you like but I haven't tried it.
    They worked well themselves... until 3 months after owning one, it just stopped. Died. Nothing. No power indicator, not recognised as an ethernet adapter, etc.
    Open it up and lo and behold a bad cap. Order replacement cap, replaced it. Works great.
    Then 2 months later (so 5 months total), the other one died... with the same symptoms and the same cap. Replaced that one too, but I used some 1500u 6.3V motherboard caps, instead of the 1000u 10V cap I replace the 1000u 6.3V original with, because I was in a rush. But it didn't fit, so I mounted it horizontally . The original cap is a cheap Jackcon capacitor in both units.
    Both are in good working order now.
    But what pisses me off is that these adapters died so quickly. Obviously I knew how to fix them but it is just plain poor design. And not everyone knows how to fix things. A few more items saved from landfill, but it's a losing battle.
  • Rulycat
    • Apr 2010
    • 724
    • United Kingdom
    Re: Advent Powerline Ethernet Adapters
    Yep, that's why we need longer warranties damn it!
    • seanc
      • Nov 2008
      • 1319
      The layout is not too dissimilar from my 'Peak' (purchased from Dabs) powerline adapters.
      They lasted a year and a half, then I moved house and plugged one in - it was squealing.
      I replaced all the Teapos in that one and did the other for good measure. Still working fine.
      • japlytic
        • Oct 2005
        • 2086
        I recommend replacing the capacitor next to the bulged unit as well.
          It's part of a pi filter but it's not subject to anywhere near the same amount of ripple so I left it in for now.
          • Longbow
            • Jun 2011
            • 623
            These things blow their power supply capacitors and you can probably get the power supply fixed by replacing them. They fail by the hundreds, sometimes after a month or two. The overall quality of these things is terrible, they get hot and I hesitate to use them because of the possibility of melting the plastic container and worse. Wireless is the best way.
            Is it plugged in?
              Agree 100%. They run at 75°C on the case - insanely hot. No wonder the 85°C caps popped. At such a temperature they cannot be energy efficient. However, the wifi in my room is really poor so I had no other choice, really...
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                recap now with quality parts or do it again very soon.
                a neighbor has a set of these.every lytic in them was baked dry or popped.their cat rests its head on the things for the heat.edit.forgot to note these things are turning a brownish yellow.they were a bright white when i first saw them.were brought home from somewhere in uk.sold in the px.
                • seanc
                  • Nov 2008
                  • 1319
                  Yeah I'm not surprised my Peak adapters failed, I bought the cheapest ones I could find.
                  I also have a pair of Zyxel homeplugs which are older than the peak adapters, but fine.
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    another brand name sold to the junk makers.used on crappy tv's here too.
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      Reminds me of my former family's PC. (IBM Aptiva P133) Unfortunately, my mom and father smoked.
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4979
                        • New Zealand
                        3 months? That's pathetic...
                        Good to see you fixed it though. And I agree with the others, you should probably replace the lot not just that one. Even if they're not critical I would just to feel better.
                        -David VanHorn
                        • MikeCartwright.net
                          • Nov 2010
                          Sorry to resurrect an old thread, but someone may find it useful.
                          I've used the Advent Powerline adaptors for years having bought a batch of faulty units sometime ago from Ebay.
                          I simply upgraded the two 1000uf 6.3v and the two 4.7uf 400v with superior Panasonic equivalents (but 105C rated). Worked a treat since!
                          Only other component to fail in these units is the IC TNY276PN which can be replaced, though a tad trickier to solder due to the 8 pins being close together.
                          Hope this helps!
                          • Doesronnieevenlift
                            Help a noob! Wson8 Pogo/Needle Adapters to read/Write
                            by Doesronnieevenlift
                            I had recently tried to reflash the bios on a dell latittude that has a Wson8 Chip however to no avail.
                            My question is, Has anyone had much success using the Pogo/Needle adapters to read and write bios without removing the chip from the main board?
                            I seem to struggling with the solder process wofh my reflow station and currently have 4 machines waiting for a bios mod/reflash.
                            For context I have just ordered a EZP2019 SPI flash so this is what I would be using alongside the Pogo Adapter.
                            Apologies if this is the wrong subcategory....
                            06-22-2025, 04:51 AM
                            Biostar IG41S-M7S - Advent Zuni 71R-B11E14-T820 Motherboard Schematic
                            E326167...
                            11-06-2024, 05:48 AM
                            Advent 7085 7100 7101 7103 Laptop Schematic
                            (ECS 558 Motherboard)...
                            10-31-2024, 04:26 AM
                          • Alphacentauri
                            Advent k200 motherboard schematic 37gl50200-10-rev.01
                            by Alphacentauri
                            Has anyone got a schematic for an Advent K200 laptop. Motherboard is 37gl50200-10-rev.01.
                            I need to locate the BIOS chip on this board.
                            The laptop seems to work, apart from it has a BIOS corruption (CRC error on POST). The Phoenix BIOS then asks for a password (which should not be set, probably due to the eruption?) and the "hash code" password generator doesn't work. I have removed the CMOS battery, but I can not get it to reset, so I think I need to dump the bios and have a look at it or re-flash it, but I cannot locate the bios...
                            03-08-2023, 04:01 PM
                          • eccerr0r
                            common SATA adapters that support SAS?
                            by eccerr0r
                            Anyone know of common SATA controllers that support SAS? Perhaps all I'd need is one of those SATA-SAS adapters and one of these controllers?
                            Else will I have to get a SAS backplane and dedicated SAS card and all to access a SAS disk?
                            Wondering about how I can use this one 146GB 15K RPM SAS disk I have. Disk was free, if infrastructure will cost $ARM$LEG then I may well just put the disk in the trash (or wait until someday I get a machine with a SAS backplane...)
                            09-20-2022, 08:50 PM
