Sitecom WL-341 with bad Teapo SY
  • marcus905
    • Jun 2011
    • 37
    Well
    I had this router for free from a friend (the unit is a rebadged Sercomm IP1006RRv2.)
    He bought another one when this router kept freezing randomly soon after being turned on. The router was fairly new but he didn't have a receipt so he gave it to me and I took it apart to try to see if fixing it was possible.
    In the pics there's what I found:
    4 Teapo capacitors:
    3x SY 470µf 16v (8x15mm 3.5mm terminal spacing) that look fine
    1x SY 330µf 10v (6.3x11mm 2.5mm terminal spacing) that is bulged
    Neither is listed in Teapo's datasheet for the SY series.
    Since a couple of the boards I used had the same problems when their capacitors bulged or vented and I recognize Teapo as a cRapacitor manufacturer, I proceeded to remove all the capacitors.
    Now I'm asking for your help in choosing the right replacements, maybe getting some with better specs as the router should stay on 24/7 reliably.
    The power/voltage regulation circuitry is based on 2x MP9141ES ICs and the external wall wart PSU outputs 12VDC 1A.
    Thanks in advance!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Sitecom WL-341 with bad Teapo SY
    I personally don't think it's those Teapos at fault. Put them back in and run the router on a PC power supply and see if it still locks up. If it does not, pop open the wall wart and see what's in there.
    A working TV? How boring!
    • marcus905
      • Jun 2011
      • 37
      I don't have a PC PSU available at the moment... I measured the wallwart output with a multimeter and with no load it outputs 13.4V.
      In your opinion is the bulged Teapo good and I can put back that too, or I should replace at least that one?
      Anyways I'll try to pop the wall wart open... any suggestion on how to do it as it's sealed and has no screws?
      Ill try to see if I find a regulable output wallwart to try with that instead of the PC PSU now
      EDIT: I tested the bulged cap with an ohmmeter and it never gets to infinity, but settles in 5 or so seconds to 1.7Mohm while the others climb very slowly, like 1.5Kohm/sec.
      EDIT2: I couldn't repeat the ohmmeter phenomenon with the bulged cap so disregard it, it may have been a fluke or a misreading on my part.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Didn't notice the bulged cap, thanks for pointing it out. Of course, replace that one. That cap is likely on the logic rail... hmm, the wall wart may not be bad in that case. Just a second, let me look for a replacement. Edit: This. Some extra capacitance won't hurt, as long as it fits. They likely went with the bare minimum required, so a step up does not hurt.
        For the wall wart, you'll have to be creative. There was a thread on that over here IIRC. But replace the bulged cap first. I'll have to be more careful when reading stuff next time... guess i have too many things on my mind ATM.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          replace them all now or one at a time later.
          check the wallwart too if its a lightweight switcher type.
          looks like a netgear i did a while back.panasonic fm is a good choice.
          • marcus905
            • Jun 2011
            • 37
            It's bigger than the one that was there (it's 8x12 - pitch 3.5, while the one that was there is 6.3x11 - pitch 2.5,) I don't know if it fits. I found some Rubycon ZLH 10v 330uF locally, would those be good?
            Since I've desoldered all of them already, what could be some alternatives to the other 3 Teapos? And some alternatives for the bulged one other than the Rubycon ZLH I found?
            I found an alternative PSU: a Seagate expansion I have uses a compatible PSU.
            In case, if after replacing the capacitor it still freezes, I'll try with this one.
            • jsog
              • Feb 2011
              • 220
              Since you have them out anyway, might as well replace them with something better. Especially that bloated one, which is hard to see in the photos. All I can find of the Teapo SY series is "long life, low impedance". I would lean towards Panasonic FR for the life/temperature rating, or FM.
              Some switcher wall warts are repairable, most are not worth it. Try another.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Yes.
                • marcus905
                  • Jun 2011
                  • 37
                  Well, the ZLH weren't available anymore when I tried to get them at a local shop; I think I'll have to order them online (but when you buy only a few units the shipping is too much :/)
                  [OT]
                  BTW, I tried to get a friend to buy those for me at another store instructing him to avoid buying crap, and this is what he brought me... I think it's the first time I see those capacitors, and judging from the datecode NOS is an euphemism in this case! Moreover it's probably the first time I saw a Philips capacitor!
                  [/OT]
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    Those are good caps if you're dropping them in a piece of analog gear, not a SMPS or a CPU bypass. Don't let the age fool you - they are high quality parts, and even after all those years they likely drifted less in value than crapcaps do in an year... They're just not suited for your application.
                    • marcus905
                      • Jun 2011
                      • 37
                      Yeah, I know... I saw ELNAs in high quality amps so I knew them, but I was surprised to find 24 year old ones still in shops they probably just need to be slightly reformed
                      I don't seem to find the Philips 035 datasheet anywhere also.
                      I'll see where I can get the ones I need.
                      Thanks again
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        When a data sheet doesn't have an exact cap use the closest one with the same physical can size.
                        3x SY 470µf 16v (8x15mm) 840 mA, 0.087 ohms.
                        1x SY 330µf 10v (6.3x11mm) 340 mA, 0.220 ohms.
                        Cross references to Chemicon KY and Nichicon HE.
                        [So those or better would do fine.]
                        Mann-Made Global Warming.
                        - Dr Seuss
                        • marcus905
                          • Jun 2011
                          • 37
                          After a long local search, a soldering mistake, a burnt finger from the soldering iron and lots of swears because I'm not used to clipping the leads at the right size (and I mean lots) I finally managed to repair the unit using Rubycons. I used a ZLJ for the smaller 10v330u and MCZs for the 16v470u. Now the unit seems to be working fine but I'll leave it on overnight to see if it keeps going.
                          To be honest, the first poweron scared me a lot as the unit needed about 30 seconds to 'warm up' before starting at all but now it seems to be going fine. I'll post a picture of the completed work later so that you can judge the quality of my work (a double first: first time recapping and first time using a soldering iron.)
                          I'm going to start another thread soon as an el-cheapo chinese external tray PSU fried and needs a recap + a new fuse too.
                          Thanks again for all the help
                          • marcus905
                            • Jun 2011
                            • 37
                            Pictures
                            Judge my double first
                            I forgot to mention I mounted a pinheader too and that's the reason for those solder balls. I figured out that more solder there = more mechanical resilience.
                            There you go!
                            PS: those yellow/brown burned material splotches are from the excess solder resist/flux/coating that is still on the board.
                            Another thing: is it normal for the caps to be a little bit hot to the touch, maybe 45°C, with the router operating?
                            Thanks again!
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Looks like a good job!
                              45°C sounds about right if there's a lot of Ripple getting filtered out.
                              Might wanna make sure the thing has good ventilation.
                              Maybe mount it on edge or at a steep angle so heat can flow in from a low vent and exit through a high vent by natural circulation.
                              [Or you could go nuts and add a small low amps fan. That -could- cause EMI issues though.]
                              - Dr Seuss
                              • marcus905
                                • Jun 2011
                                • 37
                                Thanks!
                                Actually I took the time to measure the temps on those caps: after 6 hours of light use the MCZ were around 52°C on average (55, 53, 46) and the ZLJ was at around 38°C
                                Should I crack the wallwart open too to see if there's something wrong with that?
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  • Romania
                                  Temps look alright to me. I've seen motherboards that ran the caps hotter than that, so you should be fine.
                                  • double_DD
                                    Why does my ISP router hate my "homemade" power supply??
                                    by double_DD
                                    It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                                    So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                                    For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                                    07-12-2025, 03:09 AM
                                    by momaka
                                    03-15-2023, 10:17 PM
                                  • iMic
                                    IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
                                    by iMic
                                    Hi folks,
                                    I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
                                    The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
                                    11-29-2023, 06:44 AM
                                  • shadow666
                                    Router Xiaomi M4A Gigabit
                                    by shadow666
                                    hello
                                    i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
                                    Mi Router 4A Gigabit Edition
                                    ROM CHIP is 16 MB
                                    i attached picture of motherboard​...
                                    11-30-2024, 03:49 PM
                                  • EasyGoing1
                                    UPNP, "Standards" and hardware that implements it
                                    by EasyGoing1
                                    I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                                    One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                                    So I decided to implement UPNP...
                                    07-16-2022, 07:12 PM
