Acer AL1916W Ab Monitor, DAC-19M008 - No Backlight, Recapped, Can see with Flashlight
  • carloroma63
    • Feb 2022
    • Italy
    #61
    Re: Acer AL1916W Ab Monitor, DAC-19M008 - No Backlight, Recapped, Can see with Flashl
    I'm too trying to fix a black screen on my monitor, which use DAC-19M008 power supply
    I've read all previous post and none helped me to fix the problem.
    My situation is the following:
    - Power source on C200 cap is about 20V
    - Voltage on pin 15 and 16 follow as described on https://www.badcaps.net/forum/showpo...89&postcount=4
    - Voltage on pin 8 follow the Enable signal.
    - Voltage on pin 5 and 12 is 5 V for some seconds at startup, then goes to zero
    - voltage on pin 15 and 16 (output vs high mosfet) is fixed to 20V. At startup, after few seconds, oscillosope show a waveform with a short (less then 10 mS ) brust, from 20 to 16V, then stop and again goes to +20V
    - voltage on pin 1 and 3 (output vs low mosfet) are fixed to 0.
    - no fuse broken
    - some capacitors appears to be swollen, but voltages are Ok.
    - mosfet look to be NOT in short
    - continuity of output trasformer seems ok (about 750 Ohm on both Secondary, near to zero on Primary)
    Before try to replace the OZ9910, it isn't easy to find it in short time, someone can tell me if the waveform on pin 15 and 16 are normal during startup?
    Carlo
    • carloroma63
      • Feb 2022
      • Italy
      #62
      Addendum: With oscilloscope, I checked pin5 oscillator. At power on or after Screen Wakeup, it starts from 0V, then start to oscillate at about 3 Khz for few milliseconds ( about 20) then goes fixed to 5V.
      Tomorrow I'go to buy a OZ9910....
      • carloroma63
        • Feb 2022
        • Italy
        #63
        Update!
        I've replace the OZ9910GN and something news appens. Now, while powering on, it flash for a brief moment, then goes black.
        If I leave it powered on for some minute and try switch it off-on, sometimes it starts and works fine.
        What can I check now?
        Carlo
          Wise Wing F199 19'' LCD monitor - recapped
          by momaka
          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
          When I saw the Craigslist post, I wasn't...
          08-24-2020, 10:58 AM
        • keepread
          Dell monitor PSU vs Dell laptop PSU
          by keepread
          Hi there!
          Someone gave me their old monitor, it's Dell S2715ht.
          The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
          Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
          10-30-2025, 04:45 PM
        • wattage
          by wattage
          Hello Badcaps Community,
          07-13-2025, 04:41 PM
        • ant3202
          HP 27es - LED monitor - Monitor Flashing On - Off
          by ant3202
          Hi Everyone
          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
          https://www.badcaps.net/forum/troubl...lashing-on-off
          The monitor is HP 27es LED Monitor
          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
          The monitor will randomly blackout and display no signal and will recover again.
          Sometimes need to power and off again to restore the display but...
          03-20-2025, 07:30 PM
        • sew333
          Pc shutdown, monitor flickered with no signal after 10 seconds
          by sew333
          My pc:
          10850K stock 4800mhz stock Kraken X73 good temps
          2x16 GB DDR4 GSKILL 3000mhz XMP
          Seasonic Tx-850 Ultra Titanium
          Gigabyte Rtx 3090 Gaming OC
          Aorus Z490 Pro Gaming
          1 TB SSD
          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
          Power...
          02-22-2022, 10:27 AM
