Laptop inverter
  • smason
    • 1652
    Laptop inverter
    Has anyone ever attempted to repair a laptop inverter?
    In my day job I look after IT for a 100 person company. We've seen probably 6 or 7 Dell Latitude inverter failures in the last 6 years.
    The ones out of warranty we replace the inverter with a unit from Ebay, and have had great success.
    Dell won't sell the part, and will replace the entire screen if under warranty.
    Just had a D-810 inverter fail, so thought I might do something crazy, like try to fix it. These things are tiny, could be a major pain in the ass...
    Will report back once I start troubleshooting.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Laptop inverter
    The replacement inverters usually sell for $5 USD with free shipping from ebay from far east sellers.
    The components are way too small for me and even think about soldering.
    --- begin sig file ---
    --- end sig file ---
    • smason
      • 1652
      Re: Laptop inverter
      Yeah, I'm thinking that parts (FETs and transformers) might be made out of unobtanium.
      • primoz1
        • Oct 2010
        • 270
        • Italy-Slovenia
        Re: Laptop inverter
        I got similar problem with toshiba satellite P300D, got DIM screen and inverter is OK.
        So I want somehow start that inverter Sumida 94V-0 independent from motherboard, but not got schematic and not really know which 2 pins must connect to power and start CCFL light.
        any idea ?
        thank you
          Re: Laptop inverter
          The inverter will requires these signals:
          B+ for running the inverter which is connected to the SMD fuse on the inverter board.
          Ground which will be the negative leg of the filter cap after the fuse.
          BL_ON: Backlights on signal from the main board, >1V = ON
          Dim: Dimming control signal from the main board, this one can be variable DC or PWM signal.
          • homore
            • Dec 2013
            Re: Laptop inverter
            are you basing these readings off of a voltmeter or software?
              Re: Laptop inverter
              Those 4 signals/voltage are the basic requirement for the inverter to operate. You can use Ohm meter to trace out the B+ and the Ground. The BL_ON you will need DC meter to monitor the line that will toggle high (ON), LOW (OFF) for the BL_ON. Dim may have to use both DC meter or the scope to look at the signal to find out if it is PWM control or not.
              It is applied to the monitor and TV as well.
              • primoz1
                • Oct 2010
                • 270
                • Italy-Slovenia
                Re: Laptop inverter
                Hi. Thanx for guides, here is link to pics of inverter.
                http://s781.photobucket.com/user/bez...brary/inverter
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4516
                  • Italy - Milan
                  Re: Laptop inverter
                  is your screen completely dim? therefore with no backlight? if you want a schematic try to take the datasheet of the IC, there's maybe an example as usual..
                  • primoz1
                    • Oct 2010
                    • 270
                    • Italy-Slovenia
                    Re: Laptop inverter
                    Hi. Is not complete dark, I got picture if look from side or use flashlight, but CCFL not start, I got spare LCD and inverter and LCD cable all parts tested and work OK.
                    I see one time tutorial how to make that bypass but bookmarks gone
                    • shortchange
                      • Jan 2012
                      • 27
                      Re: Laptop inverter
                      Is the ic OZ965?
                      I believe you should see continuity at pin 16 and fuse F1
                      • primoz1
                        • Oct 2010
                        • 270
                        • Italy-Slovenia
                        Re: Laptop inverter
                        Hi I check that pin and got 18v there, but I got 0Z991
                        must find datasheet for that
                        • primoz1
                          • Oct 2010
                          • 270
                          • Italy-Slovenia
                          Re: Laptop inverter
                          This is only what I found in free web area.
                          can someone confirm if pins are equal like 0Z9910AGN ?
                          thank you
                          • shortchange
                            • Jan 2012
                            • 27
                            Re: Laptop inverter
                            smason
                            Can you get more photos? What are IC's?
                            Continuity for fuse F1 and from F1 to U1 and U2 -at least one pin?
                            primoz1
                            Use your ohm meter as budm said "...use Ohm meter to trace out the B+".
                            Pin 14 to the fuse.
                            The IC is turned off and with a high impedance you will see 18v.
                            Pins 2 and 4 test continuity to only one pin of connector CN1
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4516
                              • Italy - Milan
                              Re: Laptop inverter
                              It's the third time i rewrite this post, it doesn't take it.. SGRUNT!
                              Bypass what? You mean exclude protection? Be more clear, wich test you've done? You connected togheter:
                              1. lcd 1 - inverter 1 - cable 1 = works?
                              2. lcd 1 - inverter 1 - cable 2 = works?
                              3. lcd 1 - inverter 2 - cable 1 = works?
                              4. lcd 2 - inverter 1 - cable 1 = works?
                              or other combinations?
                              • primoz1
                                • Oct 2010
                                • 270
                                • Italy-Slovenia
                                Re: Laptop inverter
                                Hi. sorry. I try to Light Up that CCFL because is DIM now. But crap stop work complete.
                                So reball time again
                                will repost back what happen.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4516
                                  • Italy - Milan
                                  Re: Laptop inverter
                                  i've not understood your last post, a schematic that seems similar to your circuit is in the datasheet of OZ960
                                  • primoz1
                                    • Oct 2010
                                    • 270
                                    • Italy-Slovenia
                                    Re: Laptop inverter
                                    I only find-dig this and may be similar pinout like on my IC, but laptop wont start, now I make reball again and we will see what happen.
                                    • primoz1
                                      • Oct 2010
                                      • 270
                                      • Italy-Slovenia
                                      Re: Laptop inverter
                                      Ok is alive again http://tinypic.com/r/md1nxt/5
                                      This is the thing, inverter start CCFL just for eye blink and go off. I got 3 replacemant screens and cables and inverters and on all is same. I think north bridge is out (bad) but if I success somehow start that CCFL will work like OK. till my new NB chip not arrive from china (end of januar 2014 app)
                                      Because I ask is some option to make some bypass wiring on inverter to start CCFL, but Im not PRO and even SEMI PRO electronic, so that is little tricky and hard for me.
                                      I hope you all understand what I mean.
                                      Thank you.
                                      • primoz1
                                        • Oct 2010
                                        • 270
                                        • Italy-Slovenia
                                        Re: Laptop inverter
                                        Sorry for late RE. Yes I want bypass that exclude protection somehow.
                                        Thank you.
                                          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                          09-06-2024, 09:30 PM
                                          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 08:47 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                          Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:11 AM
