Voltage Regulator Question
  • Solder Boy
    • Nov 2006
    • 178
    Hi there not sure if this is the right spot for this question, tried googling the numbers on this regulator came up empty.
    The numbers on it are T423 MBFR2010OCT.. It's out of a Dell E173FPS monitor. Diagnosed the board.. it had a dried out filter cap, 2 bad diodes, one small cap 50v10uf that was bad and I checked this regulator while it was in the board and it was shorted.
    Took it out of the board and still read shorted. Sort of dead in the water unless I can find this thing or wait til I get another donor board.
    TIA
    www.bcrelectronics.ca
  • PlainBill
    • Feb 2009
    • 7034
    Re: Voltage Regulator Question
    TIA
    A picture of the part might help identify it.
    PlainBill
    • Solder Boy
      • Nov 2006
      • 178
      Okie dokie:
      • lucky13
        • Aug 2007
        • 412
        Solder Boy,
        This is not a regulator. It has a pair of diode inside configured as printed on the picture outside. I think you should be able to get this (or equiv) from Digikey.
        This part is commonly seen in Switching P/S. Do you have any duds kicking around?
        EDIT: Here you are:
        http://search.digikey.com/scripts/Dk...F20100CTGOS-ND
        • jetadm123
          • 2169
          TIA
          Good thing PlainBill asked for a photo. For one, you transversed the letters "R" and "F". And there is no letter "O". Actual part number is: MBRF20100CT. It's available at digikey.com for $1.20
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            Or free from an old ATX power supply.
            A working TV? How boring!
            • Solder Boy
              • Nov 2006
              • 178
              Thanks for the help guys! Greatly appreciated! I have about a hundred power supplies kicking around in my shop. I'll probably order a bunch of these for future repairs.
              I was speaking to a buddy of mine about it the other day and he agreed the fact the large filter capacitor didn't read anything at all on the ESR meter probably was the culprit that blew everything else up.
              I could just swap the board out for another one but I'm determined to fix this one somehow
              • Krankshaft
                • Jan 2007
                • 2328
                No reading on the ESR meter if you are referring to the Bob Parker one mean's either the ESR is over 100 ohms or the cap is shorted.
                • Solder Boy
                  • Nov 2006
                  • 178
                  Yeah I knew that.. I don't have the Bob Parker model.. got mine from Global in Missisauga.. works like a champ for me
                  • Toasty
                    • Jul 2007
                    • 4171
                    Do you mean open instead of shorted?
                    veritas odium parit
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • artvandalai
                      Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
                      by artvandalai
                      This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
                      The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
                      11-05-2024, 07:38 AM
                    • playit
                      diy - voltage injection possiblity with voltage and ampere regulator - possiblity ?
                      by playit
                      hello ,for diy voltage injector for short killer/finder -- is it possible to use something like this - LM317 DC Linear Regulator, DC-DC 4.5~40V Turn 1.2~37V, Step Down Power Module, Adjustable
                      and ampere controller along (to make it zero amps ) with some addons(transistors diodes etc.) for it -- and use some 5v adaptor or 3.3v volt rail of my smps power supply as input and finally get 1v and zero amps for injecting voltage to find out short circuit component ? ..
                      for source input -- can we use 3.3 -4 volt 18550 battery ?( i have some of those ) and then adding ampere regulator...
                      02-26-2025, 05:39 AM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
