Seeing noise finding similar posts (whats this called?)
  • Chaiyz
    • Nov 2009
    • 21
    I see monitors that come in and have what I can only describe as noise comming from the outer corners of the LCD's. Does anyone know what I'm talking about and what's the correct terminology for this and what causes it?
    I fix my fair share of LCD's and after purchasing an ESR meter I've got a very high success rate but when I see one come in and it has this noise, which starts off not so bad but gets worse the longer the monitor is on, like it has a bad cap. When I first saw this problem, it was on a Xerox 17" flatpanel and I thought at first it was a cable issue, I didn't have an ESR meter then so I just replaced all the caps on the PSU and nothing changed. After getting a meter I've ran into one Mag that had the same problem but even worse, several of the filtercaps were bad and I replaced them but it did not cure the problem completely. I guess the Xerox may have had nothing to do with the mag's problem and vise versa but when I see a monitor with lines jumping and you can still see picture but it's got these dancing lines, what does everyone call that and where are they discussed?
    Thanks for hours of entertaining reading!!!
    Chaiyz
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Seeing noise finding similar posts (whats this called?)
    Outer corners -> Arcing on the CCFLs?
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      Oops, never mind. I re-read and thought you meant hearing noise from the LCD corners?
      Now I know you are talking about the display.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Noise usually comes from the SMPS transformer or filter chokes, sometimes from the inverter transformer too. Nothing that a little varnish won't fix.
        A working TV? How boring!
        • PlainBill
          • Feb 2009
          • 7034
          Are you referring to an audio noise, or a problem with the display on the panel? If the latter, I'd suspect a problem on the logic card. Check the voltage regulators.
          PlainBill
          • Chaiyz
            • Nov 2009
            • 21
            Could you please explain? I'm clear that you are referring to varnish to clean something but the answer was a bit vague for me. I think your on the right track thought and I'm really wanting to understand this problem. Also, the noise is not audible. Noise on the screen like when you have a bad monitor cable and it puts noise on the desktop.
            • EGuevarae
              • Nov 2008
              • 1336
              Varnishing the transformers to isolate interference
              There are 10 kind of people in this world: those that understand binary, and those who don't.
              • ASUS ROG Maximus IX Code
              • Intel Core i5-7600K 3.8GHz
              • 16gb GSKILL TridentZ RGB DDR4-3200
              • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
              • Windows 10 Pro x64
              • GeForce GT1050
                2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                Well you should have made yourself clearer. I was talking about audible noise. Dipping the transformers in varnish will quiet them down if they're noisy, but it won't do nothing for your picture.
                Hmm, video interference. I've mostly seen that on LCDs with VGA inputs only, because the signal is converted from digital to analog once in the video card, then back again to digital in the monitor. If the PCB layout is messy and the A/D converter is too close to the power supply transformer, it will inevitably pick up interference. If you have an oscilloscope you can try checking whether the interference is caused by ripple (which can be fixed with new/more caps), or by the board layout (which can't be fixed, but you can try shielding the transformer to see if that makes a difference).
                IMO it makes no sense why they didn't use DVI in the first place - okay, compatibility is one, but making LCDs with only VGA inputs is dumb IMO.
                • lucky13
                  • Aug 2007
                  • 412
                  Really, arcing is a very distinct possibility. Unfortunately, it is very diffcult to troubleshoot as you have to disassemble the panel to confirm if the end of the lamps are arcing. I've seen some where the heat from the arcing caused the plastic panel inside the monitor to melt a bit!
                  I've also found ends grow red but stil light being emitted.
                  • tony359
                    by tony359
                    11-28-2023, 05:18 AM
                  • MegaZAC
                    Onkyo TX-SR805 noise in one channel
                    by MegaZAC
                    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                    There's some logic behind it. As soon as I select an input I get only left...
                    04-23-2025, 10:09 PM
                  • courtcircuit
                    Philips HTS8000 home cinema noise problem
                    by courtcircuit
                    Hello
                    I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                    Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                    Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                    I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                    Removed each of tyhe boards
                    02-08-2025, 08:22 AM
                  • karatzdi
                    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                    by karatzdi
                    I know some might say... just buy another one. Sell it as parts..!
                    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                    Spent some time downloading the Service...
                    06-11-2024, 08:38 AM
                  • Biruslapio
                    LG 50PB690 power supply terrible noise
                    by Biruslapio
                    I bought this TV with really bad oxidation on the power supply and bottom X boards, it was working but during pickup there was a lot of background noise so I don't know if it had this problem before.
                    As soon as I could I opened the tv and started working on it, did not test it before since it had back bars on the screen and obvious signs of humidity. The X boards were replaced and the screen now works 100%, but the power supply...
                    I washed the board and resoldered almost everything on the primary, the oxidation happened because of constant mains AC current flowing,...
                    07-13-2022, 12:46 PM
