Viewsonic Optiquest Q19wb
  • lucky13
    • Aug 2007
    • 412
    Re: Viewsonic Optiquest Q19wb
    Originally posted by MBAJACE
    BTW I found 2 resistors that were shorted. Make any sense?
    What's the location? I can get you the resistance value.
    • MBAJACE
      • Jun 2010
      • 25
      R805 resistor red yellow silver gold I think 24.7ohm??? I'm learning.
      Ranges from 0.5 to 0.2ohm
      F802 Mustard yellow resister? Fuse possibly, reads T 4A so I think its a 4Amp fuse..
      Reads 0.5 to 0.1ohm
      Everything else checks out I think.
      • MBAJACE
        • Jun 2010
        • 25
        OK I think R805 is actually fine. My meter says its shorted, a solid connection. hmmm.
        • lucky13
          • Aug 2007
          • 412
          Reads 0.5 to 0.1ohm
          That is:
          red = 2
          yellow = 4
          silver = multipy by 0.01
          goldd = 5% tolerance
          So it is 24 x 0.01 = 0.24ohms!
          I can't find F802. Where is it?
          • MBAJACE
            • Jun 2010
            • 25
            It is yellowish on the edge, left I think. So I think the fuse may be the problem. with 0.1 resistance I believe there is a 2V loss and 8V may not be enough to sustain the cfls. I went over the transformer solider and bridged the fuse. Its a slow burning 4AMP and I think it is half way. The green light is blinking so there must be some flux on the board. I'm going to bridge the fuse and see what happens. I'm going to replace caps by Saturday. Whenever they get here.
            If I can power cycle on/off/on and keep the backlights on it will be a success.
            • PlainBill
              • Feb 2009
              • 7034
              Anyone who cannot cope with mathematics is not fully human. At best he is a tolerable sub-human who has learned to wear shoes, bathe, and not make messes in the house.
              Robert A Heinlein
              The inverter draws perhaps 1 amp, 2 maximum. If the resistance of the fuse is .1 ohm (did you correct for the resistance of the leads?), the voltage drop across the fuse is .2 volts.
              If you still have the Rat Shaft caps in there you are wasting your time and ours. Replace them with good Panasonic FM or FC series caps.
              PlainBill
              • MBAJACE
                • Jun 2010
                • 25
                #27
                No, I took that radio shack cap out. The 4A fuse is good then and all of the circuitry tested good. The kit I bought off of ebay this morning has all of the caps. The monitor works it just gives me 1 opportunity every 4-6 hrs and it has to stay on. I guess I will start with the caps and go from there. I really want to know how to bypass or trick the circuit with a resister on I think the 7 pin. Any experience?
                • PlainBill
                  • Feb 2009
                  • 7034
                  I have seen that process, and don't recommend it under any circumstances. If it is the one I am thinking of, it is for a dying mcu. It usually has the effect of quickly killing the mcu. The problem you describe is an ALMOST classic 'two seconds to black'. The winkle in your case is it won't restart for a period of time.
                  PlainBill
                  • MBAJACE
                    • Jun 2010
                    • 25
                    #29
                    How much factor is the shielding tape on the back of the lcd panel? I did not measure what comes off but I'm super curious.
                    • lucky13
                      • Aug 2007
                      • 412
                      #30
                      I am sorry but I look at my board again and don't find this F802. Can you post a pix of it?
                      • lucky13
                        • Aug 2007
                        • 412
                        #31
                        You mean those silver tape? They are for RFI/EMI and these tape won't stick once you pull them off. Just leave them out.
                        • MBAJACE
                          • Jun 2010
                          • 25
                          #32
                          OK, thanks on the silver tape info. The fuse was not the problem. I will be putting a new set of caps in on Saturday. Hopefully that fixes it.
                          Where on the board would its memory be stored?
                          As a last resort I think I could make some kind of reset switch that drains the power from it faster than 5 hrs.
                          I will post the picture up soon.
                          • elbtax
                            • Apr 2008
                            • 59
                            #33
                            I have the same psu rev: c. I see no F802 on my board.
                            • MBAJACE
                              • Jun 2010
                              • 25
                              #34
                              If you're looking at the green side w plug down it is on top left corner.
                              • eradz
                                • May 2010
                                • 20
                                #35
                                any update on this issue? im getting the same exact thing as above, same parts and the tests are the sme.
                                On the pink resistors tho, there are 3 different sizes but if you look at the 2 big pink ones, one had a red band and the other a blue. ones tests out at .05(set my meter to 20m) and the other just 0.
                                Transformers measure .628 and .635 for 01 - 02 and 03 - 04
                                • lucky13
                                  • Aug 2007
                                  • 412
                                  #36
                                  Lamps.....lamps.....lamps.....
                                  Get yourself a known good lamps and swap in one set at a time.
                                  • MBAJACE
                                    • Jun 2010
                                    • 25
                                    #37
                                    I soldered the fuse with a copper bar a few weeks ago and no problems.
                                    I would like to know where to get replacement lamps because thats the only option I didn't try.
                                    • Rtech
                                      • Jul 2010
                                      • 1095
                                      #38
                                      You mean shorted together...because resistors NEVER go short Circuit on their own ??
                                      • MBAJACE
                                        • Jun 2010
                                        • 25
                                        #39
                                        The fuse was part of the problem. I don't think its totally fixed but as of now I want to find some replacement lamps
                                        • eradz
                                          • May 2010
                                          • 20
                                          #40
                                          so it seems to be bad lamps? i took apart the screen and it seems like the lamps arent any like i normally see. Like the ones u can just side out. These seem built into the whole back clear screen once u removed the top darker peice.
