P2317H not turning on
+ More Options
Posts
  • questore
    • Dec 2015
    • 485
    • csongrád
    Hi Everyone,
    I have a problem with my dell P2317Hb
    No reaction to power button press.
    Boardnumber:
    L3101-1M
    48.7AA02.01M
    No schematic or boardview found yet.
    Power supply board itself looks good, 5v Is present on the wires that goes to secondary Logic Board. As soon as i connect the to boards then this drops to 1.4v.
    1.4v also present on the power button sideboard, and when I press the button, voltage drops to 0 then comes back but nothing happpens. Checked all wires no broken found.
    Can anyone help me trace what could be the problem?
    Thanks.
  • questore
    • Dec 2015
    • 485
    • csongrád
    Re: P2317H not turning on
    Its only 1.12 volts now
    • questore
      • Dec 2015
      • 485
      • csongrád
      Find a "1MHz 1A Synchronous Step-Down Regulator"
      According to Datasheet the equasion is good and the output should be 1.2v indeed,
      Because Vout=0.6V*(1+(163K/163K))=0,6v*(1+1)=1.2V So this seems fine.
      So my thinking is like this: If the powerbutton pressing drops voltages to 0 for a second then something else must be not switch on.
      • questore
        • Dec 2015
        • 485
        • csongrád
        1. Strange thing is that acoring to datasheet the VIN should be voltage higher than 4 Volts, and its is 1.2V also, so how is the regulator even working?
        Is it possible that it is not and the 1,2volt is coming from somewhere else and it only would go up if button is pressed and something gives more power to VIN?
        Also VIN and LX is not sorted.
        Readings to ground are:
        - Pin 1: 1.5K
        - Pin 2: GND
        - Pin 3: 1.5K
        - Pin 4: 1.5K
        - Pin 5: 8,2K
        • questore
          • Dec 2015
          • 485
          • csongrád
          After letting is rest 24 hours unplugged. The following changed:
          The LX has only 0.28v
          Also cheched power button line and seems to have no broken resistor and when button pressed, the voltage drop reaches the main IC.
          Any idea why 5v not raising after button press?
          • R_J
            • 9535
            Your problem is likely with the power supply not the main board, the power supply can't supply any current on the 5v standby line.
            I would suspect the small electrolytic (PT504?) in the primary for the vcc line of the controller ic.
            • questore
              • Dec 2015
              • 485
              • csongrád
              I think I can borrow another same type power supply to test that theory.
              Thanks, I will get back to you with the result.
              • questore
                • Dec 2015
                • 485
                • csongrád
                In the meantime i have checked.power board and the 5.12v is present in the other side of the 360kohm resistor, so I wonder...isn't it means that the power board is ok?
                • questore
                  • Dec 2015
                  • 485
                  • csongrád
                  I had time while waiting for the power supply.
                  So i have checked every component on the logic board and found a bad diode that reads 0.5v and 0.3v in both ways on diode mode.
                  I assume its fault can be the cause of the low power since its directly connected on the input rail of the board.
                  According to the internet it is a "UDZ5V6B" SOD-323 diode.
                  Attached an image (its the one with the mark of BC), please correct me if I'm wrong.
                  • questore
                    • Dec 2015
                    • 485
                    • csongrád
                    I cannot find component, since these are only comes with a package of 3000pcs and this is more costly then buying a new board.
                    Any replacement suggestions?
                    • R_J
                      • 9535
                      That diode is a 5.6 volt 200mw zener diode, they can be found everywhere, Check the voltage across it. If it is across the 5 volt input, it is good, and this is not your problem.
                        • Jul 2011
                        • 6033
                        Here try this place for them this is the actual part number “ UDZ5V6B-7 ”
                        https://www.questcomp.com/part/4/udz...ign=partsearch
                        Here is the data sheet
                        https://cdn.badcaps-static.com/pdfs/...5bde1316c9.pdf
                        I have personally ordered from them in the past several times when I am finding hard to find parts yes they do have a minimum amount for an order
                        • questore
                          • Dec 2015
                          • 485
                          • csongrád
                          This is not my problem? I don't understand! Are you meaning changing the bad diode won't fix my standby 5V being 1.2V?
                          • R_J
                            • 9535
                            Sorry I misunderstood, I thought the 5 volts was present and only dropped when the power button was pressed. Replacing the diode should resolve the problem.
                            If the diode is across the 5 volt input to the main board the diode is likely only for protection If the main board is removed and the 5 volts is not high, you can remove it to test the operation of the monitor, after testing install a new 5.6v zener diode.
                            • questore
                              • Dec 2015
                              • 485
                              • csongrád
                              Removed the bad diode, no change
                              Any idea?
                              • R_J
                                • 9535
                                So it is not the diode causing the voltage to drop, It is one of two things, either the power supply can not supply enough current for the main board or something else on the main board is loading down the 5v. The easiest way would be to try that other power supply board.
                                • questore
                                  • Dec 2015
                                  • 485
                                  • csongrád
                                  Or i can hook up a lab power supply to see if it is drawing power of 5v fine.
                                  • R_J
                                    • 9535
                                    Yes, you can do that or you could load the 5v line on the power supply with something like a 10Ω for about 500ma draw or a 4.7Ω 5watt to draw 1 amp.
                                    • questore
                                      • Dec 2015
                                      • 485
                                      • csongrád
                                      Disconnected the two board and hooked a lab power supply on the.5v. input.
                                      Pushed 5.1v and it started drawing 0.020A and the power led started flashing. Maybe its flashing because the rest of the connection pins missing but since 0.020 is small amount, i would suspect the problem is the power supply board. Feel free for dicussion..
                                      • R_J
                                        • 9535
                                        It could be flashing for many reasons, no input signal, no backlights etc.
                                        >Goto #6
                                        • Woodsworth
                                          PS3 CECHC03 60GB YLOD Troubleshooting
                                          by Woodsworth
                                          I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
                                          START
                                          Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
                                          03-19-2024, 07:58 AM
                                        • Victor Petrovich
                                          Lenovo IdeaPad 3 15ITL6 doesn't start
                                          by Victor Petrovich
                                          I have laptop Lenovo IdeaPad 3 15ITL6 with Intel Core i3-1115G4. When I press the start button, LED light on the start button starts blinking 12 times, then stops and after some time starts blinking 12 times again. When it stops, all voltages are down.
                                          The motherboard is HS460 HS560 HS760 NM-D471 Rev: 2.0
                                          S/N: PF3Q0WTF
                                          The motherboard is not mine, also there were corrosion on the board which I cleaned.
                                          Methods of fixing like fully turning off the motherboard or starting only with adapter doesn't work. All testing were did only with adapter on.
                                          06-07-2025, 02:40 AM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
                                        • Mustang67ford
                                          Sharp LC-50LB370U PS or backlights?
                                          by Mustang67ford
                                          Hello all. Working on a sharp LC-50LB370U. A few days ago, I turned the tv on and immediately left the room, came back in and tv was black. Turned it off then on and all good (didnt think much of it at the time) for about a week. Did the same thing again but stayed black this time. When turning on, the word "sharp" is dimmer than normal I think then tv goes black. I do have sound and do have a display with the flashlight test. I trided unplugging and also holding in the power button for 30 sec, no change. I opened the back up and the backlights do turn on to some extent for a moment...
                                          11-12-2022, 08:32 AM
