Gateway FPD2275W LCD Monitor Bad Caps Reassembly
  • nico95
    • Apr 2010
    • 36
    I have a Gateway FPD2275W Monitor. Samsung LCD model is LTM220M1-L01
    I had a blown cap and one on the way,with I replaced both(same kind) I finally recieved some caps I have been waiting for to replace all the rest on the Power/invertor board but wanted to make sure I can put it back together. I have most of it figured out. Stuff kinda got seperated so I couldn't remember. My main question in on the 4 connectors for the ccfls to the invertor. What would be the proper order? also there are 2 connectors- one for a speaker(not sure why it has one since there is no sound available for the monitor and a second cable on the invertor board. One cable goes to the USB hub and the other goes to the proccesor/componetn board. Im assuming the speaker goes to the component board and the other cable from the inverter board goes to the USB hub board. I will attach pics any help would be great. I really need to get this thing going it been sitting here for to long mostlly waiting on the cap set and would like to get this in. Thought I would test the 2 caps I replaced first. Since the rest tested mostlly ok(nothing that shouldn't make it not turn on)
    THanka again in advance,
    Nick
  • anno
    • Sep 2007
    • 140
    • netherlands
    Re: Gateway FPD2275W LCD Monitor Bad Caps Reassembly
    the order of the ccfls doesn't matter
    • Wrog
      • Oct 2009
      • 472
      The reason there is a speaker is for the touch controls. By default, there is a chime associated when a touch is sensed, presumably so you "know" when one has registered. From the pictures it looks like you have it all correct. Good luck with it!
      • seanc
        • Nov 2008
        • 1319
        When you say 'blown cap' you don't mean the yellow film cap with a burn mark next to it, next to the connectors for the lamps do you?
        Edit: Saw your other thread, you've done that bit!
        • nico95
          • Apr 2010
          • 36
          Thanks for the info on the CFL connectors Anno.
          I was hoping that might be the case
          • nico95
            • Apr 2010
            • 36
            Wrog,
            Thanks for the background on the Speaker. That makes a lot more sense now, and thanks for the reassurance on the correct connections. I didn't want to take a chance, not for how long it has taken to get caps
            Thanks for the help
            • nico95
              • Apr 2010
              • 36
              Thanks Sean, I hope that is all thats wrong with it, Well I'll find out once I do the other caps(since its apart)
              THanks again
              I'll let you guys know How I make out when Im done.
              • itx
                • Jun 2010
                nico - How did you get this thing apart? Working to repair one for a customer and the back plastic panel is on extremely tight despite all the screws out. I googled around - saw one post that suggested the front bezel sliding up 3/8" but I don't see that happening. Trying not to ding it up much but it's not snapping open, even with a breaker.
                • nico95
                  • Apr 2010
                  • 36
                  Hi ITX,
                  Sorry for the slow reply. It is a little tricky I had to do some searching and came across some info about using a credit card(use a old one) or one of those debit cards you have left over from a rebate. Use that to slowly pop it open. If I remember correclly you can push down on the top part of the front bezel as you try to seperate .I believe that is he part with the clip. There are a lot of them. and there is also a small ribbon cable for the touch screen on the right side(mostlly the bottom half) becaefull on that side because of the cable. I would open that part last. I think I either started at the top or bottom and worked my way around very slowly. Work slowly it will pop as mentioend below but if your carefull you should be ok. I did have one problem as the front bezel is thin it cracked on my so something to keep in mind. It glued back together ok but you can see the crack. The old credit card really does the trick believe it or not. If you have more question please let me know. The monitor is back up and now working. I was going to pop it back open but decided I better not since its been used by someone. If need be I can though start to open it if you need help.
                  Here is a little info that I found when I was figureing out how to open this thing
                  "Just to let you know. I've used my expired creditcard edges to physically remove the monitor apart...you will here small cracks once you slide in the card...
                  Also a little more info than you may need below
                  "Here is a step by step guide (I could not find anything on this monitor except what is on this site which is not much)
                  1. Remove the stand by taking out the 2 screws
                  2. Remove the 4 Wall mount screws
                  3. Remove the 3 screws at the bottom back of monitor
                  4. Pry the rear case off by starting in either the left or right corner at the bottom and work your way
                  to the center. (Note you WILL break off a little piece of the retainer clip on the inside but its not a major concern as you will not see it when you put it back together) Once you get it split a bit you need to work your way around the sides very carefully.
                  5. Once you get it split do not pull off the front bezel too fast as the tape wire for the front controls will be attached, all you need to do is pull up in the direction the cable is running and it will pull out very easy, be careful not to damage this tape wire.
                  6. Once you get the front bezel off there are 4 screws retaining the LCD cage to the rear case, remove these 4 screws.
                  7.Set the front and rear case cover aside and lay a soft towel down and flip the LCD on its face, next there are 4 screws securing the LCD into the LCD cage (Please note I'm not a professional and don't know the exact names for all the parts but I think once you get the case open you will understand what I'm calling what)
                  8. Remove the 4 wires on the left of the unit and the cable grouping on the right. you will also need to remove all the taped wires that are secured to the LCD cage.
                  9. There are 2 parts to the cage, you will need to only remove the top 4 screws and the 2 screws where the monitor speaker is. This is needed only because in order to get the power supply out you need a little space to remove it.
                  10. Remove the 2 screws where the power cord plugs into
                  11. Flip the unit over so that you can see the power supply and the video board and remove the * screws holding the power supply into the cage.
                  12. Remove the wires from the Video board going to the power supply board, you will also need to remove the wire going to the USB hub, this can be done by removing the 2 screws holing the metal protection plate and then pull the wires from the hub.
                  13. Now remove the power supply and look at the capacitors on the board, you will see the top of the capacitor has a bulge on the top, that is the one that needs to be replaced."
                  • nico95
                    • Apr 2010
                    • 36
                    THanks to everyone for there help. THe Monitor is back up and running!
                    I have one minor problem. THe person I gave this too(planned this in advance) I didn't think to measure the location height where it was going. Its a tad tight so that is a little bit of a problem at the moment. THey may need to change the desk out to get it to work properlly but they did want to do that at some point anyways so...
                    Woops, guess I should have thought of that.
                    Thanks again guys!
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      I used those spam/junk mail credit cards to open the first couple of monitors, but now I switched to 2 regular screw drivers and can do a decent job of not destroying the plastic. I have now opened 12 and gotten the hang of them.
                      Hi ITX,
                      --- begin sig file ---
                      --- end sig file ---
                      • nico95
                        • Apr 2010
                        • 36
                        I have tried the screw driver method now and that does work well, take a little to get the hang of it,I know that Gateway was a lot trickyier than the others's I have opened since(still working on the others(parts needed)
                        Thanks again for the pointers, I still owe you a update on the Acer Monitor you where helping me with back in August, I needed parts and finally have gotten them ordered. THe one Transistor was on backorder so I kinda put everything on hold and had no time after that. Just ordered the parts today so I will let you now in that post How I made out and hopefully all set. I have to post on another monitor(1 for now) and may have a few more qutions.Thanks again for your help and everyone elses as well.
                          by momaka
                          03-15-2023, 10:17 PM
                        • ant3202
                          HP 27es - LED monitor - Monitor Flashing On - Off
                          by ant3202
                          Hi Everyone
                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                          https://www.badcaps.net/forum/troubl...lashing-on-off
                          The monitor is HP 27es LED Monitor
                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                          The monitor will randomly blackout and display no signal and will recover again.
                          Sometimes need to power and off again to restore the display but...
                          03-20-2025, 07:30 PM
                        • Rick_1234
                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                          by Rick_1234
                          Good evening, gentlemen.
                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                          Things I tried
                          - Bought a new AC adapter thinking that was the problem but the problem...
                          06-22-2024, 04:44 PM
                          Wise Wing F199 19'' LCD monitor - recapped
                          by momaka
                          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                          When I saw the Craigslist post, I wasn't...
                          08-24-2020, 10:58 AM
                        • sew333
                          Pc shutdown, monitor flickered with no signal after 10 seconds
                          by sew333
                          My pc:
                          10850K stock 4800mhz stock Kraken X73 good temps
                          2x16 GB DDR4 GSKILL 3000mhz XMP
                          Seasonic Tx-850 Ultra Titanium
                          Gigabyte Rtx 3090 Gaming OC
                          Aorus Z490 Pro Gaming
                          1 TB SSD
                          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                          Power...
                          02-22-2022, 10:27 AM
