I use PANASONIC FM/FC 1000/25V cap myself in place of 680.
Thanks for the updates guys, I appreciate it. I guess I should have just replaced them while it was open. It seems the cable that connects to the actual display is incredibly brittle and chunks are breaking off every time it is taken apart.
Re: Hanns G HG281D 2 second black screen and parts help
I have repaired many of these
The problem you describe will always be 3 caps on the logic board
Please note: the caps will NOT show any sign of bulging
Hi Everyone,
I've been trolling this forum as well for useful information.
I have 3 28 inch monitors, 2 HG281D's and an I-INC IF281D.
I purchased used through craigslist, I knew they had issues to begin with.
The last one I was using finally decided to do the 2 seconds to black routine
so I decided to finally use the kit I bought off eBay for both boards, and yes they were quality caps recommended by this site.
I first did the power supply board, all new caps but this didn't fix the problem, so I did the next step which was to replace the 3 100ufd caps listed above on the control board.
This solved the 2 seconds to black problem and it also cured one other issue which was the wavy vertical lines on any image, which usually started out very noticeable but after a while was visibly reduced but still noticeable. At some point I will finish recapping the control board, removing the caps from that one is a royal pain in the butt being a multi-layered board.
I'd love to say it was but at the moment only one pin(if you would call it that) is slightly "unsupported." I suppose my statement was more geared towards taking it apart and putting it back together will lead to a new cable.
I was wondering if this can be traced directly back to the logic boards, or should I start replacing parts on the two side circuit boards.
Glad I found this thread.
I had been searching around the internet for a solution for a 42 inch Vizio TV, which I found, and decided 'hey that was easy, I'll look around to see if anyone has figured out the problem with my HG281D that's been sitting in my garage for 2 years'.
I received the Panasonic 100uf 25v caps yesterday and replaced the old ones on the logic board. The monitor seems to be back to at least 99% functionality. No more flickering pixels, wavy lines, or quick blackouts. Though it did black out once after a few hours, while the power light remained blue. I power cycled it, and it hasn't done it since then. I'm guessing maybe one of my solders is not quite good enough. But at least now, I know the issue.
Great site! This may rekindle my love of fixing electronics.
Hello, i've replaced the 2 faulty caps (100uF 16v) on the logic board (funny the third same cap on right side of the board seems in good condition). I've replaced with Panasonic 100uF 16v. There is still one issue on my monitor, i have some vertical lines on the right sides, see this picture:
Ok, after an hour of working the lines are gone. So i guess it is an electronic problem and not a problem with the bad connection of the LCD drivers PCB.
Do you think it's a capacitor issue on the logic board or maybe on the T-CON board? I've checked the T-CON and it seems clean and in good condition.
Failed screen not fixable sorry. Caps will not cause that, do not spend any more on it ?
