Samsung Syncmaster 943B problem
  • falcontech
    • Oct 2013
    • 477
    • italy
    Hello
    I have a problem with a samsung 943B, initially thinking it was a power problem i replaced the power board which is a bn44-00082e, i had a flashing of the ccfl lamps and the monitor would not start, i replaced the power board and the problem is remained, thinking they were the lamps I tested them with a ccfl lamp tester and they are all working, at this point I think it is the main board which is a BN41-01172B, my question is, before making a further purchase there is a way to turn on the lamps without the main board to exclude that the new power board is also broken? Of course without the main board the lamps show no signs of life, so maybe I should short out two of the 12 output pins to turn on the lamps, like the guy on youtube did Grazie
    https://www.youtube.com/watch?v=fia_pXizejY&t=46s
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Samsung Syncmaster 943B problem
    Yes, you can test the inverter with the main board disconnected.
    My guess would be that pin 8 (O/F) on the power supply board is for the inverter On/Off control pin. Pulling this pin up to 5V (so connect pins 5 or 6 to pin 8) should turn on the inverter (and backlights.) Probably best to use a 100-Ohm series resistor between these two rather than a direct connection, though... just in case.
    Pin 1 (ADJ) should just be for adjusting the backlight brightness, but usually that can be left unconnected for testing.
    I'm not sure what pin 7 (DCR) is for, but you can probably leave that one alone as well.
    So connect pins 8 to 5/6, and see if your backlights turn ON and stay ON. They should stay ON as long as pin 8 is connected to pin 5/6.
    Also, I'm linking your thread here with the power supply, so that people can see the inverter you're dealing with.
    https://www.badcaps.net/forum/showthread.php?t=99034
    • falcontech
      • Oct 2013
      • 477
      • italy
      No, this doesn't work, I realized that with the main board connected the last two pins k1 and k2 receive respectively 14, xx volts and 5.1 volts I don't know if it can be useful
      • R_J
        • 9594
        K1 & K2 are from the button board, Key1 Key2 should only have about 3.5 volts not 14v. k1&k2 connect to CN5 where the buttons connect
        • falcontech
          • Oct 2013
          • 477
          • italy
          I check again with the connector of the connected commands and I tell you
          • falcontech
            • Oct 2013
            • 477
            • italy
            ok I rectify, on k1 and k2 I have 1.80 volts, on pin 8 I have only 3.10 volts, if they must be 5.1 I think they are insufficient
            • R_J
              • 9594
              The control voltages from the main board are 0~3.3v
              • falcontech
                • Oct 2013
                • 477
                • italy
                what do you advise me to do to make this inverter turn on?
                • R_J
                  • 9594
                  Disconnect the main board from the power supply so you don't damage the main board, Then use about a 1kΩ resistor between the +5.1 volts and O/F that should turn on the backlights, if it does not, then connect another 1kΩ resistor between +5.1V and ADJ
                  I think the DCR pin is used on this power supply
                  • falcontech
                    • Oct 2013
                    • 477
                    • italy
                    all clear, except that I did not understand what to do with the dcr pin
                    • R_J
                      • 9594
                      for the DCR pin, Look at the back of the board where the plug is located, I do not think that the DCR pin is connected to any circuit.
                      • lotas
                        • Jan 2016
                        • 4763
                        • Russia
                        Wiring Diagram - Main Board
                        • falcontech
                          • Oct 2013
                          • 477
                          • italy
                          Yessss ... they turned on, so the power supply is ok ... now I should figure out what's wrong with the motherboard, assuming it's repairable ...
                          • falcontech
                            • Oct 2013
                            • 477
                            • italy
                            any idea to understand what could be in the main?
                            • R_J
                              • 9594
                              You could disconnect the flat cable between the main board and the panel to see if the power supply and backlights turn on, as there may be a fault with the panel.
                              • falcontech
                                • Oct 2013
                                • 477
                                • italy
                                all the tests done so far have been done just as you advised me, without flat on main or panel
                                • falcontech
                                  • Oct 2013
                                  • 477
                                  • italy
                                  I did some tests on the main, all the voltages are ok, except for pin 8 which theoretically should receive 3.3 volts but only 3.10 arrive, based on the lotas scheme what could I control?
                                  • R_J
                                    • 9594
                                    pin8 is o/f which is a control line to turn the power supply on and off 3.1 volts is fine. 0.2 volts is not going to make a difference.
                                    • falcontech
                                      • Oct 2013
                                      • 477
                                      • italy
                                      do you say to replace main directly or is there something I could check?
                                      • R_J
                                        • 9594
                                        As you can see there is not much to the main board, if the regulators are ok, it may be a firmware issue? but I think the boards are quite cheap to replace.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
                                          09-07-2024, 05:50 AM
                                        • nh2
                                          Samsung SyncMaster 215TW buzzing / lightning in power board socket
                                          by nh2
                                          This is my first post here. I just fixed my first 2 broken displays by replacing broken capacitors (Samsung SyncMaster 226BW, and Samsung SyncMaster 213T). But I have a third one I'm unable to fix, and am eager to fix as well:
                                          My Samsung SyncMaster 215TW makes a buzzing / hissing sound when turned on.
                                          The sound is louder the brighter the monitor is, e.g. in the "Game" preset is is even louder than in a softer preset.
                                          Opening up the monitor and unplugging the small socket cables that run from the power board to the LCD, I can see a small blue...
                                          08-31-2021, 02:23 AM
                                        • Nicktronic
                                          Samsung Power Supply Board BN44-00874F
                                          by Nicktronic
                                          Hey everyone,
                                          This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                          Anybody...
                                          03-17-2025, 06:20 AM
