Acer AL2423W: Recapped, Still Dead!
  • CleanSC
    EnthusiastFixer
    • May 2010
    • 91
    Hey all... My Acer AL2423W (24" LCD monitor) died on me. No LED, no power, nothing. Completely lifeless.
    Googled the issue, and learned it has cheap caps in it, so I recapped the entire secondary side with Nichicons. The caps looked fine, sans two 100uF'ers that had spit the bottom plug out (lead end).
    Still dead.
    I took the PSU to a local TV repair joint... They were not interested in diagnosing it. They just want to replace. Are there no more real old school local corner electronics technicians anymore? Just parts swappers?
    A month of fighting this thing and now I've taken it as a personal mission to fix it. It's a sweet monitor and I simply don't want to throw it away. I've even replaced it already with a Samsung 2333hd but I still want my old monitor back.
    So let me know what else to check on this one. I really want to fix it to bring this monitor back to life and sell off the Samsung.
    Already checked the fuse, the power cord, and switch. Verified there is 120VAC in the board after these components. All the diodes seem okay, as well as the resistors altho I did check everything in-circuit and surely didn't check all the SMD components on the greenside.
    Thanks for the help, fellas! I'm new here and I like the get-it-fixed attitude on here as opposed to the usual just-chuck-it guys that keep turning me away.
    Successfully Saved Various TV's and Monitors from the Landfill:
    Acer AL2423W (Fixed in 2010, Still in use today), Panasonic TH-37PD25 (Twice), Panasonic TC-P55GT30 ($100 CL Score), JVC 27" LCD Television
    Repair Equipment: Fluke 88V, Hakko 936
    Skills: Measure/solder at component level. Light IC replacements (Chip Quik)
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Acer AL2423W: Recapped, Still Dead!
    https://www.badcaps.net/forum/showthread.php?t=9210
    Check that thread, there's some useful info there on the same monitor that other people had similar issues as you.
    Might desolder the ground shield on the bottom of the PSU and see whats under it.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • pedro
      • 199
      • AUSTRALIA
      I'm presuming you have checked that you are getting a DC voltage reading across the large cap ~ 1.4x the line voltage (measure with care, both leads are hot), and that you have verified that all three fuses are intact.
      Friends don't let friends buy Samsung ....
      • dondrusco
        • Apr 2009
        • 89
        https://www.badcaps.net/forum/showthread.php?t=6995
        See that thread, too.
        • CleanSC
          EnthusiastFixer
          • May 2010
          • 91
          Thanks for the replies, fellas.
          Topcat, I will have a look under the ground shield and see if anything pops out at me. Will take pics.
          Pedro, I have not checked voltage at C1 but will and report back. Should be a little over 160 VDC, right?
          The only fuse I checked was the obvious F1 main fuse. Where are the other two?
          Dondrusco, yes I have seen your thread and wish I had your success rate, haha Nice pics and fixes!
          I have not looked much at my video board as the caps look fine on it. Then again, I didn't have any bloaters on my PSU, just 2 pushed out plugs on C13 and C16. Everything else seemed fine. Maybe I need to replace the remaining 5 caps on the primary side? (C22, 23, 25, 30 & 32) They look fine visually.
          Could the video board be causing a no power issue?
          Thanks for all the tips! Will get on it and report back.
          • Bobdee
            • Jun 2008
            • 461
            Hello
            I think THere are 4 fuses
            As you have seen F1
            There is FS3 black box fuse by connector CNS1
            Also FS2 black box fuse by lower H/Sink on right side of board
            As well as red box fuse by connector CNS2
            • pedro
              • 199
              • AUSTRALIA
              Originally posted by Bobdee
              Hello
              As you have seen F1
              Good spotting. I missed one.
              • CleanSC
                EnthusiastFixer
                • May 2010
                • 91
                Quick update...
                All four fuses are good. .3 ohms or less thru each.
                Input voltage of 118VAC gives me 154VDC at C1.
                Did not have time to fire up the soldering iron today to check under the ground shield. Will do that tomorrow.
                What should I look at next?
                Thanks, all!
                • CleanSC
                  EnthusiastFixer
                  • May 2010
                  • 91
                  Okay got the ground shield off. Don't see anything obvious there. See pic.
                  I'm out of things to check. What should I look at next?
                  • CleanSC
                    EnthusiastFixer
                    • May 2010
                    • 91
                    Any other help, fellas?
                    If not, does anyone want to buy this otherwise perfect monitor?
                    Better yet, anyone want to fix my PSU? I'll pay obviously.
                    Thanks!
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      So just to confirm, have you changed EVERY cap on the PSU board (small and big)?
                      Thanks!
                      --- begin sig file ---
                      --- end sig file ---
                      • CleanSC
                        EnthusiastFixer
                        • May 2010
                        • 91
                        Good question...
                        I have replaced every cap small and big on the primary side.
                        The secondary caps all look fine. Funny you should ask because at the moment I am about to pull the trigger on Digikey for the 6 small caps on the Secondary side. Might as well do those before I give up completely.
                        I'm also debating replacing all the video board caps but there's 28 of those. Maybe I'll do just the 8 330uf ones and the 100uf (the same ones TopCat changed) I have most of these on hand so I might as well order the last three with this current order and swap 'em out.
                        That should put me in a pretty sorted spot to finally figure this out.
                        Thanks for the response! I will report back after I install all the new caps.
                        • lucky13
                          • Aug 2007
                          • 412
                          CleanSC
                          Please update your profile to show what country (at least) you are in.
                          So exactly which caps did you replace? The two by CNS1? Can you circle them on your pix?
                          • lucky13
                            • Aug 2007
                            • 412
                            Man, I type too slow...
                            Did you check if you get the 5v back? (see the pinout near CNS1)
                            • CleanSC
                              EnthusiastFixer
                              • May 2010
                              • 91
                              Hey Lucky...
                              Sorry about the profile, it's updated now.
                              I changed all the caps on the secondary side (I mispoke earlier), which are all the caps to the right of the dividing line. They run along the right perimeter of the board down to the lower right corner.
                              The primary caps are the 6 clustered on the center of the board and are on order.
                              All the output pins are dead. I'm testing them by probing each of the +v pins and the ground pin. Nothing. Is this the proper procedure?
                              • Dgtech
                                E. Technician
                                • Apr 2009
                                • 1462
                                • Steeler
                                Something caught my eye on the solder side of the inverter board. Is there a burn mark in the upper left hand corner coming down from the screw ground points to the heatsink near the red fuse? What is the writing on the part attatched to the heatsink?
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Hey Lucky...
                                  I've avoided this thread on the theory 'Too many cooks spoil the broth'. Here's a couple of points. This monitor supply appears to have a PFC front end. IC6 is the controller for that. Because you have approximately the correct voltage on C1 we will assume it is working correctly. IC2 appears to be the controller for the standby supply, IC1 is for the main supply. What are the part numbers for those two ICs? By looking up the datasheets we can see what voltages to expect on the pins.
                                  PlainBill
                                  • CleanSC
                                    EnthusiastFixer
                                    • May 2010
                                    • 91
                                    Nope, it's just some flux. It scrapes off clean.
                                    What part on what heatsink are you referring to? There are 5 heatsinks.
                                    PlainBill
                                    IC1:
                                    EA1532A
                                    5K9M824
                                    Hn65471
                                    IC2:
                                    EA1532A
                                    5R0E622
                                    Hn66041
                                    WOW those are the smallest numbers I have ever had to look at. I used a pretty strong magnifying glass and it's still possible I got a few of them wrong. They weren't very clear due to the size. Hope it's what you need!
                                    Thanks so much, fellas!
                                    • Dgtech
                                      E. Technician
                                      • Apr 2009
                                      • 1462
                                      • Steeler
                                      Plainbill, I may be mistaken but I think this may be the datasheet on this link.
                                      http://pdf1.alldatasheet.com/datashe.../TEA1532T.html
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        No, I don't think you are mistaken. That certainly looks like a possible candidate. Thanks for the assist.
                                        CleanSC, in the first picture of the bottom of the board, it appears pin 1 is at the upper right corner of IC1 and IC2. Pin 2 is the pin to the left of pin 1, while pin 8 is at the lower right corner. With the monitor plugged in, what is the voltage from pin 2 (gnd) to pin 8?
                                        Oh, if you get a chance, a closer picture of that area would help.
                                        PlainBill
                                        • bripoll
                                          Acer Veriton N4670GT Dead
                                          by bripoll
                                          Hello, I have an Acer veriton n4670GT that, due to a fall to the ground, only started if I did a BIOS reset.
                                          The power button ar ok, and when power off windows, then if press power button, this power on, but goes to boot loop, like press power button forever
                                          It crossed my mind to try a BIOS update and when I finished it turned off and no longer starts in any way.
                                          I have a flash programmer, but the file you download from the Acer website has a .CAP extension, it is not a .BIN
                                          I have programmed it, but it still won't start, it is dead
                                          Before programming...
                                          11-23-2023, 02:56 PM
                                          09-06-2024, 05:27 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
