HP w20 LCD Display Inverter, running out of options.
  • CapBlown
    replied
    Re: HP w20 LCD Display Inverter, running out of options.
    Here are the voltages (pin):
    start time
    4.83 (2)
    1.21 (5)
    3.02 (7)
    4.78 (10)
    10 minutes
    4.85 (2)
    1.22 (5)
    3.04 (7)
    4.81 (10)
    35 minutes
    4.87 (2)
    1.23 (5)
    3.04 (7)
    4.82 (10)
    45 minutes
    4.87 (2)
    1.23 (5)
    3.05 (7)
    4.82 (10)
    1h 4 minutes, just after lights went off
    4.96 V (2)
    0.00 V (5)
    3.11 V (7)
    4.91 V (10) (Lights are off but there is still almost 5 volts here)
    restarting (off/on)
    4.87 V (2)
    1.22 V (5)
    3.03 V (7)
    4.80 V (10)
    Voltages for 10 & 7 when switched off
    0.12 V (10)
    0.19 V (7)
    Looks good to me. What should I do next? All I can see is that ISEN and VSEN drop to 0 when lights go off.
  • PlainBill
    replied
    Originally posted by CapBlown
    Thanks PlainBill.
    For the CCFL's to get back on I need to push Power button twice to get lights back on. First push shuts down the monitor, second lights it up. Image and sound are there even if I don't shut it down, just lights are missing.
    Usually when I turn monitor off and on again, lights are immediately turned off again. But sometimes they lid back up and may stay on for some 10 to 20 minutes. There is no clear pattern and behaviour seems pretty random to me.
    I was reading electrical characteristics of this IC chip, I noted that ISEN is on it's Max level (1.23 V) all the time (except when shit happens) while VSEN is not even close to it's minimums (2.78)? see page 4. I might be wrong though, these are the things I don't really understand.
    I quess my next step is to measure pin 10. Should I check preset voltage at pin 7 too?
    The voltage at ISEN is normal. The inverter is a constant current source, so the current will stay at the regulation point. If you reduce brightness on the monitor, the voltage at ISEN should drop.
    Go ahead an check the voltage at pin 10. I suspect it will be either well above 2 volts (on) or below 1 volt (when turned off from the front panel). I am also interested in the voltage at pin 7. I had expected to see Vsen much higher.
    PlainBill
  • CapBlown
    replied
    Excellent job of testing, thanks for the data.
    Forgive me, I haven't read the complete thread. Please verify this - the CCFLs suddenly turned off, then back on without any action on your part?
    Thanks PlainBill.
    That is very interesting, and would really limit the number of possible causes. The OZ9939 uses a standard technique for regulating the outputs. The current through the CCFLs' return lines are measured, and the total current fed back to pin 5. It adjusts the output drive to maintain a constant CCFL current, based on the brightness setting. If a return line is suddenly shorted to ground, it appears this would not cause a fault condition.
    The output voltage is also monitored. These are 'ored' and pin 6 senses the highest voltage across any CCFL. If this rises above the threshold, the inverter shuts down and stays down until the control input is cycled to off, then on.
    It appears the ONLY way the CCFLS could go dark, then come back on again is if the voltage at pin 10 drops below 1 volt, then rises above 2 volts.
    PlainBill
  • PlainBill
    replied
    Thanks PlainBill. I did as you suggested and measured also voltage from pin 2, which seems to stay at 4.98V when monitor is on.
    Here are the results on pins 5 & 6. Seems that I get overvoltage at some point if I understood this correctly? What could cause this sort of peak?
    Powers on 20% brightness (Or=Orange/Ow=orange/White):
    Ow 5 ISEN: 0.52 V
    Or 6 VSEN: 0.52 V
    Set brightness to 90% (at 15 mins on)
    Ow 5 iSEN: 1.23 V
    Or 6 VSEN: 0.84 V
    (30 mins on)
    Ow 5 iSEN: 1.23 V
    Or 6 VSEN: 0.84 V
    (Lights go off at 40 mins)
    Ow 5 ISEN: 0 V
    Or 6 VSEN: 0 V
    Turned off and on again, lights turned on immediately:
    Ow 5 iSEN: 1.23 V
    Or 6 VSEN: 0.84 V
    (Lights go off 13 mins)
    Ow 5 ISEN: 0 V
    Or 6 VSEN: 0 V
    Turning on gets these peak values and lights go off immediately
    Ow 5 ISEN: 0.83 Vpeaks
    Or 6 VSEN: 2.11 V peaks
    Suddenly turns back on:
    Ow 5 ISEN: 1.23 V
    Or 6 VSEN: 0.84 V
    (still 15 mins on)
    Ow 5 ISEN: 1.22 V
    Or 6 VSEN: 0.85 V
    Lights go off... turning on gets these peak values and lights go off
    Ow 5 ISEN: 0.47 V
    Or 6 VSEN: 1.85 V
    Couple of minutes off, and here we go again (15 mins on)
    Ow 5 ISEN: 1.23 V
    Or 6 VSEN: 0.83 V
    PlainBill
  • CapBlown
    replied
    Cowabunga!!! We have a winner!!!
    We're going to try working on this a little bit differently. Hopefully you can access IC1 while the monitor is in operation. The datasheet for the OZ9939GN is located here. This design appears to have both voltage and current protection, so let's monitor pins 5 and 6 to see which one changes and causes the shutdown. Use pin 14 as the ground point.
    PlainBill
    Ow 5 ISEN: 0.52 V
    Or 6 VSEN: 0.52 V
    Ow 5 iSEN: 1.23 V
    Or 6 VSEN: 0.84 V
    (30 mins on)
    Ow 5 iSEN: 1.23 V
    Or 6 VSEN: 0.84 V
    Ow 5 ISEN: 0 V
    Or 6 VSEN: 0 V
    Ow 5 iSEN: 1.23 V
    Or 6 VSEN: 0.84 V
    Ow 5 ISEN: 0 V
    Or 6 VSEN: 0 V
    Ow 5 ISEN: 1.23 V
    Or 6 VSEN: 0.84 V
    (still 15 mins on)
    Ow 5 ISEN: 1.22 V
    Or 6 VSEN: 0.85 V
    Ow 5 ISEN: 0.47 V
    Or 6 VSEN: 1.85 V
    Ow 5 ISEN: 1.23 V
    Or 6 VSEN: 0.83 V
  • PlainBill
    replied
    Thank you very much for your comprehensive explanation to my questions PlainBill. It's always great to learn new terms and things.
    That would be great, to me this is beginning to look like rocket science.
    IC is (attached):
    OZ9939GN
    A542E2.1G
    0551A
    If you can't reach those points while the monitor is working, solder fine wires (wire wrap wires would be excellent) to the pins and run them to an accessible point. (Avoid high voltage points like the inverter output and the AC input).
    PlainBill
  • retiredcaps
    replied
    I would need to solder them out of the board when they are "hot", but that takes at least 2-5 minutes while the problem may have disappeared already.
    I'm *guessing* you should be able to measure them in circuit after the shutdown occurs, but this test is not as comprehensive as the ring tester.
    Let's see what PlainBill says before you go down this "rabbit hole". It could be a "red herring".
  • CapBlown
    replied
    What is the part number of IC1 - the 16 pin IC in the inverter area? Perhaps it will be possible to determine what is triggering the shutdown.
    PlainBill
    IC is (attached):
    OZ9939GN
    A542E2.1G
    0551A
    Originally posted by retiredcaps
    You can see a ring tester in action with this youtube video. 8 min 8 secs long
    http://www.youtube.com/user/preherte.../1/HMUazhb0bhc
    You can try this test with a multimeter... ...that would indicate a problem.
    Nice video, thanks retiredcaps.
    I did measure transformers some time ago and they were pretty much identical, but would it be possible that they are ok when they are "cold" and after board is heating up for an hour, one of them gets heated enough to be shorted? That might explain why everything is working fine until... I would need to solder them out of the board when they are "hot", but that takes
  • retiredcaps
    replied
    P.S I have only cheap multimeter.
    You can try this test with a multimeter, but it won't find what PlainBill is talking about.
    I can't make out the part number of the transformers, but measure the resistance between the secondary pins. Since I don't know which one is the secondary pin, you can do this.
    Number the pins on the transformers anyway you like.
    black probe on pin 1, red on pin 2 - record ohm
    black probe on pin 1, red on pin 3 - record ohm
    black probe on pin 1, red on pin 4 - record ohm
    etc
    black probe on pin 1, red on pin last - record ohm
    black probe on pin 2, red on pin 3 - record ohm
    black probe on pin 2, red on pin 4 - record ohm
    etc
    black probe on pin 2, red on pin last - record ohm
    black probe on pin 3, red on pin 4 - record ohm
    etc
    finally,
    black probe on pin last-1, red on pin last - record ohm
    I'm guessing the secondaries should read 950 ohm. The primaries should read 1.3 ohm. Some will be 0L. If one secondary is 950ohm and the other is 750ohm, that would indicate a problem.
  • PlainBill
    replied
    PlainBill
  • PlainBill
    replied
    I have to admit that I have no idea what is ring meter or what "output transformer are going south" means.
    Please explain.
    'Going south' is a slang term for failing (see below for the history of this).
    One possible cause of an inverter failure is an open or a short in the inverter transformer. A 'ring tester' tests a transformer by hitting it with a pulse and determining the number of oscillations (rings) that occur after each pulse. A transformer with shorted turns will have fewer oscillations; an open winding will have none.
    The origin of 'Going south' is fairly recent. When making a line chart of sales of a product, the line rises toward the top of the chart with increasing sales, and of course drops with decreasing sales. By convention, maps are drawn with North on the top and South on the bottom. Thus if product sales are dropping, they (and the viability of the product) are 'Going South'.
    PlainBill
  • CapBlown
    replied
    Please explain.
  • retiredcaps
    replied
    Originally posted by lucky13
    Well then, the other possibility is that the output transformer are going south. Do you have a ring meter to test?
    That was what I was thinking to try next too. He has already resoldered everything on the board (more than once I believe).
  • lucky13
    replied
    I think in post #36, he moved the inverter into another LCD and it fails too. So it looks like he narrowed down the problem to the inverter.
    My bad! Yes he did all that already to narrow down to the inverter board.
  • retiredcaps
    replied
    Did you manage to get another set of CCFL lamps to swap in to rule out the lamps?
    Your description sure sounds like a dying lamp to me....
    On a similar note, I finally was able to get 2 identical LCDs and figured out by moving power/inverter board into the other LCD that the original LCD panel is likely dying. One LCD had similar problems with it working for 15 to 20 minutes and then shutting off. If you let it cool, it will work again.
  • lucky13
    replied
    You don't need 20" lamps. Even 17" will do as you are only testing them.
  • CapBlown
    replied
    That's what I thought I measured... Yellow is now 0.62 V at the beginning. Tested it also with power off now and it's 4.51 V... Maybe I made a mistake last time. I better measure these several times in case there really is some strange variation.
  • Aruba
    replied
    After letting it rest for 15 minutes, Yellow gets now to 0.61 V and lights lid up.
    I am confused. On your previous post you mention that the "yellow" 3.05V
    turns to 0.58V when the monitor shuts off. On this post you say the 3.05V
    goes to 0.61V and yet the monitor turns on. Am I reading this right ?
  • CapBlown
    replied
    I measured all wires between logic and inverter board. Voltages change when lights go off (or because they go off)
    Yellow 3.05 V -> 0.58 V
    So I guess yellow line is the one that keeps monitor going? Something causes it's voltage to drop down.
  • CapBlown
    replied
    Brown 1.67 V -> 1.60 V
    Blue 5.11 V -> 4.91 V
    Red 12.76 -> 14.10 V
    Extra Black 0.01 V -> 0.01 V
  • x_orange90_x
    by x_orange90_x
    01-29-2025, 09:24 PM
    by momaka
    03-15-2023, 10:17 PM
  • lostone
    Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
    by lostone
    Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
    First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
    When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
    05-19-2024, 11:40 AM
  • wattage
    AOC AG493UCX 49-inch monitor - Firmware request
    by wattage
    Hello Badcaps Community,
    The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
    07-13-2025, 04:41 PM
  • ant3202
    HP 27es - LED monitor - Monitor Flashing On - Off
    by ant3202
    Hi Everyone
    Lately I am experiencing the deja-vu incident on one of the led monitor like this.
    https://www.badcaps.net/forum/troubl...lashing-on-off
    The monitor is HP 27es LED Monitor
    https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
    The monitor will randomly blackout and display no signal and will recover again.
    Sometimes need to power and off again to restore the display but...
    03-20-2025, 07:30 PM
