Re: HP w20 LCD Display Inverter, running out of options.
Here's the way this was designed to work, and my current theory as to the nature of the failure. The brightness is controlled by pulse width modulation - PWM. CCFLs work much like standard fluorescent lights - current flow through the lamp generated ultraviolet light which causes phosphors coating the inside walls of the tube to glow. They don't respond well to reducing the voltage; rather the duration of the 'on' time is varied. At 100 Khz, they are turned on every 5 microseconds. If they are on 1 microsecond out of every 5 they will be much dimmer than if they are on 4 microseconds out of 5. The current sensing circuitry is really responding to the peak current, not the average current, just like the voltage sensing circuitry is responding to the peak voltage.
Now, repeating what I wrote yesterday: The ... the voltage at the right end of R32 goes through R51, Q17 (actually a dual diode where the negative transistions are clipped), and on to the Isen input of the inverter controller. That signal ALSO goes to R46 and Q22, which I believe is a true transistor. When the spikes get high enough to turn on Q22, it reduces the Vsens threshold and causes the inverter controller to shut down.
You bring up a very good point. Q22 appears to be SMD code RKM; Q23 certainly is. That is a RK7002 MOSFET. Because of the way it is wired, it certainly changes the voltage on the OVP input of the controller. Because of the tests you did with jumpers we know that reducing the voltage on the Vsens input will prevent shutdown.
What I don't know - yet - if Q22 is triggering on increased or reduced current. And I'm having an absolute block when it comes to figuring out how to change the trigger current WITHOUT changing the current at the Isens input. One part of figuring that out is to really understand the differences between P-channel and N-channel mosfets, and between depletion and enhancement mode.
PlainBill
What if it's not overvoltage that causes shutdown? Could it be undervoltage or undercurrent?
I was looking post #69 mine and noticed that AC drops over time. That's also what happened when I adjusted brightness down from 95% and it caused shutdown when brightness reached about 50% level.Leave a comment:
That looks like that would be the location for the other (right hand) side.
As an aside, nearly 30 years ago I interviewed a tech for a job. His knowledge of most areas of electronics was good, but he knew very little about transistor circuits. His explanation: The instructor said transistors were passé, in a few years everything would be done with op-amps and digital ICs. Seems to me the designers are still doing a heck of a lot with transistors.
PlainBillLeave a comment:
I assume treshold reducement happens in circled area? Am I even close?Leave a comment:
OK, I've figured out a little bit of what is happening with the transformers. Some of this is a guess because I don't have the board in front of me, but it makes a good working theory AND it explains some earlier measurements. Since I don't have a good picture of the top of the board, I'm going to be using the resistors attached to the transformers.
One of the CCFLs is attached to R34 and the associated transformer winding. The other side of the winding (and resistor) is grounded. Another is attached to R36 and the associated transformer winding. Again, the other end of the winding is grounded.
What had me baffled was the other windings on the two transformers. The third CCFL is attached to R32 and the associated transformer winding. That means the voltage at the other end of the winding is the sum of the voltage at the left end of R36 + the left end of R32. That is passed to R33, and the associated transformer winding. The result is the voltage at the right end of R32 goes through R51, Q17 (actually a dual diode where the negative transistions are clipped), and on to the Isen input of the inverter controller. That signal ALSO goes to R46 and Q22, which I believe is a true transistor. When the spikes get high enough to turn on Q22, it reduces the Vsens threshold and causes the inverter controller to shut down.
But that's only part of the story. The signal that goes to R51 also goes to D4, and then to R39/C32. I'm not sure what that is for.
And that's still only half of the story. The identical thing is happening with the other three CCFLs, two transformers, etc.
Now to figure out how to block part of the circuit.
That would be changing the wrong input.
Let's see if I can explain this properly. A CCFL inverter is a constant-current AC source. The usual design takes the sum of the currents through the CCFLs and uses that to adjust the output voltage. In this design, that is the Isen input.
In addition, there are two safety features that may be used. The first is an over-voltage detection. Simply put, the output voltage of the transformers is monitored, and if it exceeds some predetermined value, the inverter is shut down. This is often referred to as OLP (Open Lamp Protection). This design uses the Vsen input to monitor the output of each transformer; it cannot determine if a single CCFL is bad.
The second is a current sense feature. At the end of it's life, the current through the CCFL will increase. Also, if a CCFL is broken, there will be no current through it. This particular design seems to use the current through each CCFL to detect a bad CCFL. And it does this by changing the set point for the Over-voltage protection. As far as I can see, there is no 'end of life' detection for the CCFLs.
PlainBill
I think I'm getting some of it, but I can honestly tell that I need to do some serious reading before I really get it.
This is getting curiouser and curiouser. I'm waiting
for the flash of inspiration telling me what is actually happening. So far it's been rather dim.
Would you measure the following resistors in circuit, please?
R21, R22, R25, R35
R32, R33, R36, R34
These appear to be across the windings of each transformer. Also, what are the numbers on each transformer?
PlainBill
R21 91.8 Ω
R22 91.9 Ω
R25 92.5 Ω
R35 92.5 Ω
R32 91.9 Ω
R33 92.5 Ω
R36 92.6 Ω
R34 92.6 Ω
(small differences seem to happen when measuring them several times, less than 1 ohm)
All 4 transformers are similar:
5212-0626-0
LSE M14I S
Curious as I am, also measured some resistances from those return lines to ISEN, VSEN and OVP (attached).Leave a comment:
This is getting curiouser and curiouser. I'm waiting for the flash of inspiration telling me what is actually happening. So far it's been rather dim.
R21, R22, R25, R35
R32, R33, R36, R34
Meanwhile I further investigated how CP1 would affect on ISEN. I have not done these calculations for several years so please correct if I'm wrong here.
ISEN is currently measured as 1.23 V when monitor is on as earlier stated in this thread. I measured that it's 242 ohms from ISEN to ground. That would give us the current of 0.0050826 A from ISEN to ground?
Should I add 4600 ohms (R45) in parallel with above resistance by soldering CP1 in, it would drop total resistance from ISEN to ground to approximately 230 ohms:
1 1 1
-= --- + ----- = 230 ohms
R 242 4600
Should that happen, total current from ISEN to ground would be increased to 0.0053478 Amps. I'd say that is safe to try on DC point of view?
Are there any AC powers to consider too? Or would that capasitor C30 let them pass directly to ground?
1 1 1
R 242 4600
Are there any AC powers to consider too? Or would that capasitor C30 let them pass directly to ground?Last edited by CapBlown; 08-08-2010, 06:36 AM.Leave a comment:
Wow, what a flashback!
Thanks for the updated picture. I've got a pretty good idea of what to look for now. Just trying to decide if I should try to draw up a schematic...
Thanks PlainBill,
I studied that reference circuitry of OZ9939. It seems that on this rev 2 board resistor which is identified as R28 near C22 on reference circuitry is missing from ISEN line.
Is it possible that it is not needed at all?
I don't even dare to ask this again... or... I do: CP1 would connect ISEN with kind of "reference look a like" resistor to ground...
Wonder what it might do...
I'm not going to wreck my board trying it anyway so I'll wait your further judgement.Leave a comment:
In one way, this makes sense. In another way, it is a stupid design change. Instead of having 6 high voltage capacitors at about $.08 each they replace them with more expensive transformers.
ANYWAY, I am going to have to figure out how to figure out what exactly is going on with this circuit and how to locate the offending section. This could be a day or two.
Image seems to be missing. I'm glad to help by keeping you inside ;-). I would not consider going out at those temperatures either. Might catch skin cancer in the long run...Leave a comment:
Both jumpers on, diplay don't turn off.
- tested 4 hours
One jumper on, one off, display don't turn off.
- tested with either for 4 hours.
After soldering last jumper off (display still hot) and
turning it back on after this, 2 secs to black.
So both sides are required without jumpers for failure
By the way, I really appreciate this. Currently the temperature is 101°F, heading for 110°F. We are under an Ozone alert; it is suggested that anyone with respiratory problems stay indoors. If I wasn't helping you I'd be outside cleaning the pool.
by x_orange90_xI just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
I don't know how exactly to test the inverter itself. Is it... -
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by lostoneHello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...-
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
by ant3202Hi Everyone
Lately I am experiencing the deja-vu incident on one of the led monitor like this.
https://www.badcaps.net/forum/troubl...lashing-on-off
The monitor is HP 27es LED Monitor
https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
The monitor will randomly blackout and display no signal and will recover again.
Sometimes need to power and off again to restore the display but...-
- Loading...
