iiyama ProLite E2407HDSV
  • tama4tama
    • Nov 2006
    • 56
    Dear friends,
    I have this monitor, iiyama ProLite E2407HDSV
    It came on but nothing on the screen, I have checked all the caps on the both inverter and psu board and the entire caps look ok no bulging or leaking as far as I can see.
  • tama4tama
    • Nov 2006
    • 56
    Re: iiyama ProLite E2407HDSV
    This are pics
    • PlainBill
      • Feb 2009
      • 7034
      Originally posted by tama4tama
      This are pics
      Thanks for the excellent pictures. They make it much easier to help.
      Red circles in lower left: With monitor plugged in, CAREFULLY!! measure the DC voltage between the two points. Should be about 1.4 times your AC line voltage.
      Yellow circle in upper left. Ground point for following tests. Measure the DC voltage on the points circled in blue. Also note their is one more half way across the board to the right.
      PlainBill
      • tama4tama
        • Nov 2006
        • 56
        Thank you Plain Bill, I am back to ground zero, before I could do the testing the fuse has blown, I replace it and gone again so by the troubleshooting I found that the power mosfet 2764I (Q801) has shorts between all the legs, I have google it but I did not find it. Please is there an equivalent part to use.
        • PlainBill
          • Feb 2009
          • 7034
          It's an AP2764I-A The datasheet is available, and the parts are available here.
          PlainBill
          • tama4tama
            • Nov 2006
            • 56
            PlainBill I did not see the datasheet for the FET and please can I was get this bridge rectifier (GBU 4KL) from the same campany?
            • PlainBill
              • Feb 2009
              • 7034
              I have no idea.
              <Rant mode ON> I am a human being. I do not carry the inventory records of every distributor in my head, nor am I a mind reader. Heck, I don't even know where in the world you are! <Rant mode OFF>
              I took the part number you gave, figured that it was a partial number, and was able to determine the full part number. Googleing the full part number found a company that claimed to have some in stock. It is up to you to determine if they will sell in acceptable quantities and what other items they have in inventory.
              Neither the power FET nor the bridge rectifier are unusual components. With the datasheet you should be able to locate a suitable replacement. No, I can't help you with that, I don't know which parameters are critical.
              PlainBill
              • tama4tama
                • Nov 2006
                • 56
                Please I am very sorry if I have upset you with my questions, please forgive me. I always look upon you as one of my masters when it comes to repairs.
                • mikey5791
                  Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
                  by mikey5791
                  Got this working ips led monitor by the brand of
                  Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
                  Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
                  09-04-2023, 03:50 AM
                  by momaka
                  03-15-2023, 10:17 PM
                • wattage
                  AOC AG493UCX 49-inch monitor - Firmware request
                  by wattage
                  Hello Badcaps Community,
                  The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                  07-13-2025, 04:41 PM
                • ant3202
                  HP 27es - LED monitor - Monitor Flashing On - Off
                  by ant3202
                  Hi Everyone
                  Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                  https://www.badcaps.net/forum/troubl...lashing-on-off
                  The monitor is HP 27es LED Monitor
                  https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                  The monitor will randomly blackout and display no signal and will recover again.
                  Sometimes need to power and off again to restore the display but...
                  03-20-2025, 07:30 PM
                • Rick_1234
                  LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                  by Rick_1234
                  Good evening, gentlemen.
                  I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                  To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                  https://drive.google.com/file/d/1L6S...ew?usp=sharing
                  Things I tried
                  - Bought a new AC adapter thinking that was the problem but the problem...
                  06-22-2024, 04:44 PM
